Old 08-28-2012, 12:35 PM   #2801
climbhigh09
Member#: 254163
2011 WRX 20GXTR
They threw a probe on during tuning for the temps, its not part of my driving setup. It was 100+ in the shop that day, even with 4 fans blowing on the motor, we just couldn't get it cool. Even let it set for 30 min, heat soak just got worse. That's when we pulled the plot above; the best was about 10 ft-lbs better but we didn't save it.
Boost was tuned to 20.5, though I've edged my MBCS up a little from there so it's around 21/21.5 now. I tried pretty hard to have it come on early as possible, full "boost" by 3.6k under even crappy conditions, but obviously the torque doesn't really hit till later.
What are you using to pull your street dyno numbers? Looks like the AP does it, doesn't seem reliable tho.
climbhigh09 is offline   Reply With Quote
Old 08-28-2012, 01:01 PM   #2802
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I see 20psi by around 3,750rpm's but I don't see peak boost until around 4,500rpm's. The higher you push it the later it will be (basically a linear ramp).
The AP's peak numbers are pretty useless. I use Virtual Dyno for the road dyno plots. It seems to be pretty spot on with the Dynojet I've been on. You need to find a good road to do a log and then load it into the software.
http://forums.nasioc.com/forums/show....php?t=2389720
http://forums.nasioc.com/forums/show....php?t=2157391
xluben is offline   Reply With Quote
Old 08-28-2012, 01:15 PM   #2803
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by themaus View Post
I don't feel those are realistic numbers, especially considering the fact that you have an external wastegate with dump pipe. I could see a 5-10 whp loss but saying you lost 60 WHP is bull****, imo.
Yah no problem. Keep believing the bull**** that you spout. Such as making more power than your turbo is rated for.
The rated crank horsepower for your turbo is 440HP. You should sign up for a vendor account here to sell the bull**** that comes from your mouth.
Haha. I just realized this troll is the same guy who created this "hilarious" build thread
http://forums.nasioc.com/forums/show....php?t=2398102
I hope he keeps going. It looks like he'll fit right in around here...
Old 08-28-2012, 02:16 PM   #2804
aeion
Member#: 182114
1996 Nissan HARDbody
1931 Ford Model A
Zomg bro sick build u so funnay fullhomoiloveyou dude your beer mod is ill
He's not even funny.
It's not even a build thread.
aeion is offline   Reply With Quote
Old 08-28-2012, 02:24 PM   #2805
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's a little bit entertaining, but it seems like that's what everyone on NASIOC is doing these days to try and make fun of others or to get a rise out of people.
Old 08-28-2012, 02:26 PM   #2806
climbhigh09
Member#: 254163
2011 WRX 20GXTR
That's your FMIC and built block talking. ::
I'm a little jealous of the latter.
Old 08-28-2012, 02:32 PM   #2807
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I ran it down at similar boost to you until the block went. I was on E85 though (maybe you are?). It was quick, but cranking up the boost really made the torque go through the roof. Sometimes I'm curious to see how the response would be with a TMIC, but I am guess it would hurt my performance overall.
Old 08-28-2012, 04:31 PM   #2808
climbhigh09
Member#: 254163
2011 WRX 20GXTR
^seems to be the theory at your power levels. I figured that mid 300s would be plenty top end and was trying to pull those numbers to the left; so I went the with Process West TMIC.
I can't get E85 in my hood, or I'd have stuck with the VF.
I'm a Mac... VD is a PC thing (hehe... pun).
Old 08-28-2012, 04:37 PM   #2809
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Once in a while I'm tempted to buy a PW to see what it would do, but curiosity isn't worth $1000 when I'm pretty sure it would hurt power. The VF on E85 was an awesome setup. Perfect for most people. Spools like stock (even seems faster sometimes) and has plenty of power. Here's a little graph I made on that topic:
I don't have it on the plot, but the 20G XTR (or similarly sized turbo) running 20-22psi on pump gas wouldn't compare very favorably to the VF on E85. It would probably have a little more top end (but could even be about the same), but it would spool a heck of a lot slower (for the small increase in power).
If you want to send me logs, I would be happy to run VD for you. I'll send you a PM
Old 08-28-2012, 05:04 PM   #2810
Jdub.csu
Member#: 283784
2013 EVO X GSR
If you lived by me I'd let you buy it then do your testing and then buy it from you if you didn't want it as that's what I plan on going to.
Jdub.csu is offline   Reply With Quote
Old 08-28-2012, 08:18 PM   #2811
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Well you could ship it to me, and then I'll send it on to you
Old 08-28-2012, 09:14 PM   #2812
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Thats a nice accurate graph, on my e85 set up i made slightly more 360/410 with the addition of Tomei headers. Good info.
smeerone is offline   Reply With Quote
Old 08-28-2012, 09:17 PM   #2813
Jdub.csu
Member#: 283784
2013 EVO X GSR
You just need a pump gas 20G in there now
Old 08-28-2012, 09:26 PM   #2814
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Actually only need some pistons.. Shhhhh
Old 08-28-2012, 09:41 PM   #2815
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If you meant the plot, here is my best guess of what that would look like:
It is my VF52 E85 graph compared to an "estimated" 20G XTR on pump gas. I estimated it by using one of my lower boost 20G XTR plots and changing the delta weight to 0lbs to simulate a pump gas tune.
May not be perfectly accurate, but I think it shows kind of what to expect. Pretty big hit in spool for similar peak torque, but a decent bump in top end.
It's a tough choice, but if you have E85 available, I would go for the VF52 on E85. Spool vs. power is great with that combo.
Old 08-28-2012, 10:36 PM   #2816
Jdub.csu
Member#: 283784
2013 EVO X GSR
I am E85 just need to buy a process west top mount (cant push the car more because the wrx top mount blows) but I started a second business so money is tight right now
Old 08-29-2012, 11:31 AM   #2817
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's a fun plot I made of all the changes I've made to my car:
It's nice to be able to see it all laid out like that!
Old 08-29-2012, 11:46 AM   #2818
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
it looks like a sideways map of a ski resort.
I think I would rather have power delivered like that than that surge and fall off you get with the stock turbo
Celery GT-5 is offline   Reply With Quote
Old 09-02-2012, 10:54 AM   #2819
Jdub.csu
Member#: 283784
2013 EVO X GSR
The ethanol plant in windsor here temporarily shut down =\ prices are going up up and away
Old 09-02-2012, 11:51 AM   #2820
d.o.b 2.5i
Member#: 268284
2008 2.5i impreza
spark silver
I have always see your thread and looked at all the pics and the mod list, But never really took the time to really look at all you put into the car. Amazing work and great looking wrx. Just impressive. Congrats
d.o.b 2.5i is offline   Reply With Quote
Old 09-02-2012, 12:05 PM   #2821
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
They have gone up close to .60 in the last 3 weeks here in miami. Yikes
Old 09-02-2012, 03:53 PM   #2822
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I heard on on MN shut down temporarily too. Prices haven't jumped up too much yet though. I'll be on E85 as long as it's still available!
Thanks! There's been a lot of time spent in the garage, but probably nearly as much taking photo's and posting info online!
Old 09-02-2012, 04:19 PM   #2823
dstorm
Member#: 329237
2013 WRX
CBS
Originally Posted by xluben View Post
A couple more from tonight:
This one was made from blending 10 photos with the circular polarizer rotated slightly for each one, in order to minimize reflections as much as possible. I really like how it turned out!
Have you ever looked at doing the sport mesh grill? Just curious.
dstorm is offline   Reply With Quote
Old 09-02-2012, 08:03 PM   #2824
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I never really looked into it. I haven't made it a point to change how the car looks.
Old 09-02-2012, 08:37 PM   #2825
Ultimateone
Member#: 48025
15 Mustang GT
I hope this hasn't been asked to much, but what front lip spoiler is that? Thanks
Ultimateone is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
