Old 10-09-2012, 08:17 PM   #3326
Jdub.csu
Member#: 283784
2013 EVO X GSR
Originally Posted by INKMAN
I prefer the put the car on a lift and use air tools method.
Dos haha helps when I have them readily available to me...
Also power air tools ftw
Jdub.csu is offline   Reply With Quote
Old 10-09-2012, 08:22 PM   #3327
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Air ratchet would probably work since all the hardware is new and not seized at this point. They take a lot of air to constantly work at full power so you need a decent size compressor. A 3/8 impact gun works perfect for that kind of stuff too. Not everyone obviously has this stuff but it makes a world of a difference if you do.
ye I have a big compressor :P. Annoys my mom and scares my sister. I wish I had access to a lift though...
Navendra94 is offline   Reply With Quote
Old 10-09-2012, 09:34 PM   #3328
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by Navendra94 View Post
CRAP! Thanks for the info lmao. I'll switch the gaskets tomoro after I run a quick errand. Looks like the entire exhaust has to get adjusted. Shouls take 15 minutes to fix.
Thanks man, real life saver!
I don't know why it wouldn't work but there are definitely two sizes.
My car has never been on a lift or had air tools used on it
xluben is offline   Reply With Quote
Old 10-09-2012, 09:46 PM   #3329
Jdub.csu
Member#: 283784
2013 EVO X GSR
How many miles are on your car?
Old 10-09-2012, 09:46 PM   #3330
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Consider me spoiled. Being a flat rate technician it's a way of life! And come on....it's never ever been on a lift? Not once? Just for a little ride?
INKMAN is offline   Reply With Quote
Old 10-09-2012, 09:52 PM   #3331
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Around 29k.
I was thinking real hard and it actually has been on a lift at least once that I can remember. It was for a tech inspection before a track day. Lol.
I'm pretty sure 100% of the work has been done on stand in my garage, with hand tools. If I was a mechanic by ready I don't think I'd want to work on my car this much. Lol.
Old 10-09-2012, 10:25 PM   #3332
Jdub.csu
Member#: 283784
2013 EVO X GSR
Around 29k.
Trust me sometimes it's the last thing I want to do and sometimes I wonder why I don't leave it stock lol but then I remember =D
So are you going to do all the 30K fluids yourself?
Old 10-09-2012, 10:26 PM   #3333
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What fluids am I due for?
Old 10-09-2012, 10:33 PM   #3334
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Around 29k.
You don't know how true that statement is sometimes. After working on cars all day I don't want to work on mine. After working for Honda for 6 years I can honestly say I would never , ever, work on Subaru as a career.
Changing spark plugs is one of the most annoying things on the planet.
Old 10-10-2012, 09:47 AM   #3335
Navendra94
Member#: 327495
Plasma Blue
Fixed gasket rattle. Only rattle left is the occasional rattle in low rpms due to vibration making mid pipe tap some metal under car.
It doesn't annoy me that much but I'll have to do that on weekend. Nothing a little fiddling around with the hangers couldn't fix eh?
Old 10-10-2012, 10:29 AM   #3336
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, it is quite a pain compared to a Honda!
That is odd, but it's probably minor.
Old 10-10-2012, 10:29 AM   #3337
Jdub.csu
Member#: 283784
2013 EVO X GSR
That or XL hangers or bending the heat sheild
Old 10-10-2012, 10:42 AM   #3338
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I hate long hangers. IMO they should not be necessary.
Old 10-10-2012, 10:45 AM   #3339
Navendra94
Member#: 327495
Plasma Blue
Yea looks like the heatshield needs a bend...
Old 10-10-2012, 10:47 AM   #3340
Jdub.csu
Member#: 283784
2013 EVO X GSR
I agree I just made a divit on my heat shield when I had the q300. It would only vibrate when running hard or cold start.
Old 10-10-2012, 10:55 AM   #3341
Lindyn11
Member#: 326221
2011 WRX
WRBP
Subscribed for awesome.
I ended up removing my heat shield and going with XL hangers on my '11 sedan. The midpipe was thrashing the driver side carrier bearing bolt. I put a big dab of permatex on the bolt while awaiting the hangers. All is well now though.
Lindyn11 is offline   Reply With Quote
Old 10-10-2012, 11:01 AM   #3342
Navendra94
Member#: 327495
Plasma Blue
I'm going to go Bend the heatshield in soon since the sun's out. Any suggestions? Screwdriver? Hammer?
Old 10-10-2012, 11:17 AM   #3343
Jdub.csu
Member#: 283784
2013 EVO X GSR
It doesn't take much to bend. Screwdriver + your hand is enough
Old 10-10-2012, 11:20 AM   #3344
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, I think I bent mine by hand for one of my exhausts. Probably why I didn't have any issues with the Greddy (already was bent).
Old 10-10-2012, 11:34 AM   #3345
jhmr
Member#: 313217
2013 STi Sedan Stg 1
Plasma Blue Pearl
I'm guessing it will help transfer more power to the ground, and take some strain off everything else that get pulled out of position when the motor/tranny moves that much. I'm sure the stock mounts would have totally failed eventually anyways.
What I'm wondering is where does all that force go? I mean, from the looks of the engine jiggles as a result of the inertial force generated by the the sudden drop in power. If this is the case, then I would say that the force is already making its way out of the engine and into your mounts. Stiffening up the mounts would only result in more load transfer into whatever the mounts are connected to. The real question then becomes, what is the new weak link and can that new weak link take the additional force being added to it?
Same logic would apply to things like installing new sway bars and end links...
jhmr is offline   Reply With Quote
Old 10-10-2012, 11:43 AM   #3346
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think a simple way to think about it is to consider Newton's 3rd law, every force has an equal and opposite force acting against it. If the mounts are soft and squishy, then this could ultimately be the limiting factor in the power output (or at least reduce the efficiency of putting it to the wheels). The same is the case with adding stiffness in other areas.
When you see the motor bounce all over when the throttle is lifted, you can think about the opposite happening (although over a longer time scale) when power is applied. You should be able to see how this is inefficient. Holding the motor firmly in place, you reduce the energy that is wasted by moving the motor around, and allow this energy to be transferred to the wheels instead.
Yes, it does put the strain on other components, and probably could lead to earlier failures in some cases. But usually the subframe mounting points are more than strong enough and mushy factory parts are merely for NVH concerns.
Old 10-10-2012, 11:54 AM   #3347
jhmr
Member#: 313217
Plasma Blue Pearl
I think I see what you're saying. It's kind of like if you were to compare energy transfer between swinging a ball attached to a rubber band vs. a ball attached to a rigid shaft. Energy transfer is more efficient through the rigid shaft since its stiffness is higher. Assuming your subframe mounting points can take the extra force, seems like you could make more power. Are you going to go to a dyno? hahaha
Old 10-10-2012, 11:56 AM   #3348
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, that's a good analogy too. I don't plan on doing a dyno. I've changed a few other things too, so it wouldn't be apples to apples. The other big change with mounts is getting rid of the slop (ie. during hard shifting). You can obviously see this in the dyno video, but you wouldn't see it in dyno results.
Old 10-10-2012, 12:58 PM   #3349
Jdub.csu
Member#: 283784
2013 EVO X GSR
I think slop during hard shifting kills things more than adding harder mounts will over time
Old 10-10-2012, 02:42 PM   #3350
PearlRex11
Member#: 284420
2011 WRX Sedan
I'm very interested to see how much noise those mounts cause. I wouldn't mind stiffening up things myself if the noise is tolerable.
PearlRex11 is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
