Old 06-22-2011, 12:37 PM   #501
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by JerseyKid View Post
Car looks great, loving how clean it is. Are you still on stock rear control arms by any chance? If so how bad is the camber actually if your that low?
I have a set of BC's in my room waiting, but my control arms haven't come yet. The wait is killing me.
Stock rear control arms. I'd have to look at the printout from my alignment, but I think the rears ended up at 2.5deg or maybe a hair more.
Originally Posted by axleon2 View Post
Love the car, love your taste in mods too but put the plate where it goes or take it off unless your state requires it. In my opinion it takes away the cars potential image where it's at right now.
Either way beautiful car man I can't wait to get an '11!
Thanks. The front plate is required, or I would definitely ditch it. In the stock location about half of the plate would be blocking the intercooler. So for now it will have to stay where it's at.
xluben is offline   Reply With Quote
Old 06-22-2011, 02:16 PM   #502
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Is there any worry long term as far as wheel bearings or ball joints or some other parts regarding the 25mm spacer? I remember back when I had my '02, people would scorn you for using a wheel that was less than 42mm offset because of this reasoning. Since coming back, I see everybody on low offset wheels or running spacers and now I'm like
02BlueSuperRoo is offline   Reply With Quote
Old 06-22-2011, 02:30 PM   #503
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
people just care about how their cars look in pictures now..lol
no offense xluben
Celery GT-5 is offline   Reply With Quote
Old 06-22-2011, 03:05 PM   #504
JerseyKid
Member#: 135901
2011 WRX
Satin White Pearl
Thank you, thats not so bad. I have mine set at -1 on stock suspension. I think i could deal with 2.5ish until the arms are in.
And F all the spacer haters, i know lots of people who track/drift their 240's,miatas,subarus,evos with spacers and dont have issues. Plus they look sweet!
JerseyKid is offline   Reply With Quote
Old 06-22-2011, 03:25 PM   #505
Celery GT-5
Member#: 98210
2002 WRX SRP
no one said you couldn't race with spacers. the complaint is that they wear out your wheel bearings prematurely if you daily drive with them...not sure how true it is.
Old 06-22-2011, 03:30 PM   #506
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Same concerns for increased wear still apply. But it's not any worse than running a wide aftermarket wheel with a low offset.
no offense xluben
Yep, pretty much. I'd love to have new wheels with the offset I actually want, but for now I like the spacer look on the stock wheels/tires.
Yeah, I think -2.5 is perfectly fine for me.
I went to a road course in MN on Monday and the car was great. No issues from the spacers either
I think it probably is true. Purely from a geometry standpoint it is putting more stress on certain parts. The other risk is putting another interface/failure point in the system. Cheap spacers could shear off and cause some major issues. With a quality, hub centric spacers the risks are minimal. IMO, similar to running a low offset wheel.
Old 06-22-2011, 03:55 PM   #507
Celery GT-5
Member#: 98210
2002 WRX SRP
yeah pretty much. I like the 2011 stock wheels better than a lot of aftermarket options
Old 06-22-2011, 04:27 PM   #508
ofspunk7
Member#: 249401
2005 LGT and 91 MX5
Ben i think they need to be yellow
ofspunk7 is offline   Reply With Quote
Old 06-22-2011, 04:43 PM   #509
Ruz4life
Member#: 258261
2011 WRX 5-door
Obsidian black pearl
Car looks beautiful Ben!! I really like the aggressive stance that it has now.
I do wish it still had the hood scoop though in my opinion makes it look even meaner but it looks great none the less!
Adam
Ruz4life is offline   Reply With Quote
Old 06-22-2011, 04:54 PM   #510
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No way. I saw a guy with yellow wheels on his WRX and it looked horrible!
Adam
Thanks. I do still have the scoop. I might swap back and forth sometime.
Old 06-22-2011, 07:27 PM   #511
ofspunk7
Member#: 249401
2005 LGT and 91 MX5
No way. I saw a guy with yellow wheels on his WRX and it looked faster than my car....
Fixed.
Old 06-22-2011, 08:01 PM   #512
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No way. I saw a guy with yellow wheels on his WRX and it looked way more ricer than my car....
Fixed x2
Jk, I like your batmobile
Old 06-22-2011, 09:19 PM   #513
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My engine bay. Don't mind the water drops. It started drizzling as I went to take the photos.
Old 06-22-2011, 09:19 PM   #514
gregroot198521
Member#: 280844
2006 STi
Yep, like xluben said, it's a minnesota state requirement. Here's mine with the grimmspeed plate relocater:
It's weird at first but it grows on you, plus I hate the plate in the center.
gregroot198521 is offline   Reply With Quote
Old 06-22-2011, 09:36 PM   #515
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Your ****s too clean!
96accord is offline   Reply With Quote
Old 06-22-2011, 09:44 PM   #516
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
And for those that didn't notice, I moved the OEM coolant overflow tank over to the passenger side of the engine bay and got rid of the tiny, crappy tank that comes with the FMS FMIC. Here's a close up photo:
To do it, all you have to do is unscrew the hardline from the radiator fans. Then remove the hoses and flip the hardline. I bent the mounting brackets 180 degrees, so I could use them to remount the hardline after flipping it. I drilled 4 new holes for mounting. Two for the hardline, and two for the OEM coolant overflow tank. I attached everything with zip ties. After I flipped the hardline I just hooked the hoses back up. Everything fit quite well.
Here are the 4 holes that I drilled:
There are plenty of reasonable ways to do the mounting. This is just the one I chose. If you wanted you could probably mount the hardline with nuts and bolts. Just make sure they clear the fan blades. The tank could also be mounted with nuts and bolts, but you would need custom brackets or spacers. I did this because the FMS (and TurboXS) coolant overflow tank is waaay undersized. I went to the track on Monday and I was blowing coolant all over my engine bay because it was overlowing the tank. The OEM coolant overflow tank is 2-3 times larger and should provide plenty of room for expansion.
Thanks to synolimit for the idea. His install may have been a little cleaner than mine, but I'm happy with my setup. Here's his original post:
http://forums.nasioc.com/forums/show...4#post33883784
http://i1108.photobucket.com/albums/...521/Mine03.jpg
Where'd you get the mesh for the lower grill? My FMIC is already starting to wear pretty badly (and I've only had it for 2 weeks!). The black finish really doesn't seem very strong. I'm thinking of repainting it, and then maybe the mesh might help it last bit longer, or at least made the wear more hidden.
See here:
http://forums.nasioc.com/forums/show....php?t=2200790
My engine bay was covered with coolant and E85. I blew a fuel line last week and then had coolant spray all over while I was at the track. It was pretty gross. I did a rinse, Simple Green, and rinse (like the Civic thread I posted), and it came out looking good as new!
Old 06-22-2011, 09:47 PM   #517
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
nevermind.
Old 06-22-2011, 10:23 PM   #518
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What are you rolling your eyes about?
Old 06-22-2011, 10:51 PM   #519
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
I tried posting that below gregroot198521's picture whoring but I hadn't refreshed and those other posts got in first, making it look like I was rolling my eyes at your sweet engine bay.
Old 06-22-2011, 10:54 PM   #520
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Haha. I guess that's OK then
Old 06-23-2011, 01:55 AM   #521
gregroot198521
Member#: 280844
2006 STi
Meh, stop hating on my beautiful dirty car, it's undignified. I was showing xluben other people do it too.
Xluben, they are from grillcraft. Think you can get them off rallysportdirect now. Got the center one too, just haven't installed since it came after the surgery.
Old 06-23-2011, 07:54 AM   #522
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'd honestly rather not have people posting photos of their cars in this thread, but it's really not that big of a deal. I don't think the Grill Craft mesh will work because my bumper is pretty hacked up from in stalling the FMIC.
Old 06-23-2011, 12:16 PM   #523
gregroot198521
Member#: 280844
2006 STi
It fits right in the very front of the hole, but you cut out the side parts if I recall. Theres always the DIY method with the gutter bottom material. I'll see if I can find the link for it later this weekend. It's a lot cheaper than the grillcraft, quality & price.
Old 06-23-2011, 02:04 PM   #524
Joker_927
Member#: 267865
2020 WishIHadMySubby
Imaginary Blue
I see you're still sporting the silver BPV. Is it growing on you? Also did you protect it from the simple green when you sprayed your engine bay? I have heard simple green dulls aluminum.
Speaking of the Forge BPV, I'm interested in knowing how many (if any) shims you used. I got my Forge today and I'm finding shim information to be scarce.
Joker_927 is offline   Reply With Quote
Old 06-23-2011, 02:08 PM   #525
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Xluben knows other people do it too, otherwise nobody would sell a part for it.
And I wasn't hating on your car, although most people relocate their license plate because they have a FMIC. Just sayin'...
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
