Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 07-14-2011, 04:42 PM   #576
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Originally Posted by Entaille View Post
thanks for the clarification. I was curious if you were doing a rear sway bar only upgrade for some reason - just wanted to scope it out.
this car understeers like a mofo. I would love to bring it closer to neutral, will definitely be doing sways and end links at some point.
I did run the car with the stock front sway bar and upgraded rear sway bar for a while. It's not something I would recommend. I'm no expert driver, but this is how I would break things down in a highway on-ramp-type test (ie. drive around a curve at a speed that pushes the limits of traction and see how the car reacts):
  • Stock front sway bar, stock rear sway bar: Car is predictible and the front slides out very easily. Classic understeer. Hard to hold speed because you're basically sliding off the road.
  • Stock front sway bar, 22mm rear sway bar: Car holds together for a while, but once you push the speed up enough it will snap it's tail end out rather unpredictably. Not something I would consider safe. I never spun out or anything, but when pushed to the limits it will be very tough for an inexperienced driver to control.
  • 22mm front sway bar, 22mm rear sway bar: More neutral throughout. Easier to hold speed. Tires break loose predictably. Understeer is possible if on power during a turn, but oversteer is also possible if you really toss it in hard.
A 24mm front sway bar would probably feel similar. I really have no idea if the stiffer front sway bar would actually be faster around the track or not, but I do like how I have it set up now. I supposed I could play around the with adjustment holes on the sway bars, but I don't think I'm a good enough driver to feel the slight differences.
xluben is offline   Reply With Quote
Old 07-14-2011, 05:19 PM   #577
wishing4cobra
Member#: 115774
03 Subaru
Looks good, I like the touch of red on the FMIC piping.
wishing4cobra is offline   Reply With Quote
Old 07-14-2011, 05:41 PM   #578
mattw278
Member#: 276165
2013 BMW 328i Sport
You've inspired me, my next car will be a black hatchback! Extremely clean build, great work.
mattw278 is offline   Reply With Quote
Old 07-14-2011, 09:15 PM   #579
rehanna
Member#: 137830
2005 WRX
looks super sick! nice work
rehanna is offline   Reply With Quote
Old 07-15-2011, 01:35 AM   #580
Joker_927
Member#: 267865
2020 WishIHadMySubby
Imaginary Blue
Whether you are capable of getting a faster time or not, it would be really great to read what you have to say about the feel after changing the front sway to 24mm. Hard data like this is so rare.
PS. Your posts are always succinct and informative. I google for specific questions I have and after much digging I usually find a post or thread of yours on this or other forums that provides the exact answer. Thanks for being such a contributing member of the community, xluben.
Joker_927 is offline   Reply With Quote
Old 07-15-2011, 08:33 AM   #581
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Thanks all!
If someone wants to buy my 22mm front sway bar, then I would make the switch the the 24mm
Old 07-15-2011, 03:42 PM   #582
wongjonsilver
Member#: 262683
2011 WRX base
Default 24mm Whiteline Front Sway Bar
you have a PM
wongjonsilver is offline   Reply With Quote
Old 07-16-2011, 06:11 PM   #583
Joker_927
Member#: 267865
Imaginary Blue
I'm assuming you have your 22mm rear set to 22mm, correct? Have you tried adjusting it to 23mm and observing the difference?
What do you have your 22mm front set to? Apparently you can't set it to 22mm and the only options are 21.5 and 22.5mm.
Old 07-17-2011, 12:51 AM   #584
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
They're both set to their "normal" setting. I suppose I could try stiffening up the rear.
Old 07-17-2011, 02:31 AM   #585
Bizarre11
Member#: 196910
2011 WRX
are you running spacers?
Bizarre11 is offline   Reply With Quote
Old 07-18-2011, 08:50 AM   #586
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Yes. 25mm front and rear.
Old 07-18-2011, 04:28 PM   #587
611X
Member#: 287428
2011 WRX Hatch
dude, luv ur thread, love how externally u kept it mostly stock and have a monster hiding inside!
I hear all the issues and negative stuff about spacers, but love how 25mm spacers made ur car look, from what I've read in ur thread u have no issues so far, one question tho, If I want to put those on my stock wrx do I need to do any camber adjustments or any other settings changed? or just putting the spacers are fine
thanks
611X is offline   Reply With Quote
Old 07-18-2011, 06:00 PM   #588
nospin
Member#: 238802
I Love The All Black Look!!!!
nospin is offline   Reply With Quote
Old 07-18-2011, 06:51 PM   #589
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
thanks
It would be the same as having a wheel with a different offset. In short, no adjustments to your alignment, just use the spacers and go.
bicycle_wreck is offline   Reply With Quote
Old 07-18-2011, 08:20 PM   #590
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Thanks!
thanks
The spacers bolt up with no other changes on a stock WRX. If you are lowered, you will start running into fender rubbing issues.
Old 07-20-2011, 06:32 PM   #591
bigdakota
Member#: 89471
xluben - Amaaazing. I just started reading this thread. I have a 2011 WRX limited hatch in white. I have a stage 1 tune via torqued performance. Other mods to come.
So the spacers are still running good? I think I'm going to go the same 25mm H&R's. The wide fender but no flush look is killing me. My concern is safety of part breakdown etc.
bigdakota is offline   Reply With Quote
Old 07-20-2011, 08:21 PM   #592
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
thanks
Whether or not it causes problems will depend on the tolerances of the exact part that is in your car (wheel bearings and possibly ball joints?) and how hard you drive it over the long term (75k+ miles) especially with on throttle cornering.
02BlueSuperRoo is offline   Reply With Quote
Old 07-21-2011, 12:04 AM   #593
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Yeah, with quality spacers, of the proper size, it is more of a long term issue. As long as you get something that is the right fit for your car, and isn't going to snap off, then the overall wear issues should be the just like if you ran a wheel with very low offset. They will both accelerate wear on certain items. How much it accelerates the wear isn't really documented.
Old 07-21-2011, 12:05 PM   #594
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Well put.
Old 07-21-2011, 12:14 PM   #595
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Check out my SMY Clustermaker t-shirt!
Old 07-21-2011, 12:37 PM   #596
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
^ someone is leaning on your Subie!!
96accord is offline   Reply With Quote
Old 07-24-2011, 01:04 PM   #597
jim prashker
Member#: 156972
11 WRX
SILVER
Wow that's as nice as the cluster!!
jim prashker is offline   Reply With Quote
Old 07-25-2011, 02:09 AM   #598
Joker_927
Member#: 267865
Imaginary Blue
Xluben, can you provide more info on your spacers? I have searched all over for spacers for the 08+ (specifically for the 11) and the only solid finds I have is ichiba which I don't even know will fit and perrin which sells the H&K spacers but only the 5mm and 10mm.
Do you have a model number or something similar?
Old 07-25-2011, 02:24 AM   #599
protoballer823
Member#: 243002
2008 LGT
OBP...sortaflush
love the car! swapping to the 2.5i hood was a nice touch.
protoballer823 is offline   Reply With Quote
Old 07-25-2011, 05:25 AM   #600
krisobe
Member#: 267041
2011 WRX 5dr
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
krisobe is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 07:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 02:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 09:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-14-2010 12:37 AM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 05:02 PM
