Old 10-14-2011, 01:21 AM   #826
Entaille
Member#: 217875
2011 WRX
WRBP
wow that sounds like quite a job man. what are the odds you can snap some videos of you driving around?
Entaille is offline   Reply With Quote
Old 10-14-2011, 01:23 AM   #827
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
I'll definitely try. I did one with my cell phone, but the sound really does the EWG no justice, so I will have to try again with a real camera sometime.
xluben is offline   Reply With Quote
Old 10-14-2011, 01:25 AM   #828
Entaille
Member#: 217875
2011 WRX
WRBP
yeah I hear that. it's really hard to capture car audio. I've tried it on my phone and on a go pro and it just doesn't do it justice. I really want to hear what that EWG setup sounds like though! :]
Old 10-14-2011, 01:34 AM   #829
xluben
Member#: 261612
2011 WRX 5 Door
Yeah, I had the windows down, so it ended up being mostly outside noise. I think with the windows up and a real camera I might be able to get some decent audio.
Old 10-15-2011, 10:28 AM   #830
xluben
Member#: 261612
2011 WRX 5 Door
Uploaded two videos
The first is my car on the dyno (before the EWG install):
The next one is a quick clip of the EWG opening up:
Old 10-15-2011, 12:44 PM   #831
Celery GT-5
Member#: 98210
2011 SWP WRX 5 Door
TorquedPerformance Stage2
so you think there is any chance your car wont blow up from that amount of power or do you want it to so you can rebuild and make more power?
Celery GT-5 is offline   Reply With Quote
Old 10-15-2011, 01:59 PM   #832
xluben
Member#: 261612
2011 WRX 5 Door
I want it to last long enough so that I can get a built short block finished and drop it in on my own time (instead of being forced to do it when it blows up). We'll see if it lasts that long. Right now I am running it pretty conservative. Around 20psi of boost. Probably is making similar peak torque to the VF52, possibly even less. The high end is definitely stronger, but hopefully not too much more so.
Old 10-15-2011, 02:01 PM   #833
xluben
Member#: 261612
2011 WRX 5 Door
Here are some installed shots of the EWG. As you can see, there isn't a lot of room, but the GrimmSpeed uppipe makes it all fit perfectly!
Old 10-15-2011, 02:45 PM   #834
NaStIc
Member#: 289898
2012 WRX Sdn SWP
TP Stage 1
That is awesome! There's no way the video does the EWG any justice compared to real life. Any concerns in MN w/ the atmospheric dump? I know here in CA you'll get pulled over and refereed in no time.
NaStIc is offline   Reply With Quote
Old 10-15-2011, 02:53 PM   #835
armadatilem
Member#: 252270
2011 WRX 5dr Premium
Now we need some fly by !
armadatilem is offline   Reply With Quote
Old 10-15-2011, 04:07 PM   #836
xluben
Member#: 261612
2011 WRX 5 Door
I knew I forgot something. I don't really have any friends to help me make a flyby video, so you might not see one for a while...
Old 10-15-2011, 04:32 PM   #837
Roamrex
Member#: 171487
06 WRX Wagon
SGM
Any problems degrading life of the cv boot with so much heat around?
Roamrex is offline   Reply With Quote
Old 10-15-2011, 06:45 PM   #838
xluben
Member#: 261612
2011 WRX 5 Door
It is not super close to the CV boot, it kind of goes next to it. And all the dumped exhaust will already be past the boot when it exits, but I do agree that it probably adds more heat than it would normally see. But people have been running GrimmSpeed EWG uppipes for a long time without any problems, so I think it should be fine.
Old 10-15-2011, 07:42 PM   #839
Stu_Gotti
Member#: 270392
2011 WRX Limited
WR Blue
Dude loving the progress and videos.
Stu_Gotti is offline   Reply With Quote
Old 10-17-2011, 09:18 AM   #840
xluben
Member#: 261612
2011 WRX 5 Door
Thanks. Hoping to get speedo videos eventually...
Old 10-17-2011, 09:52 AM   #841
RicersWetDream
Member#: 245581
2009 WRX
Spark Silver Metallic
Just wrap the dump tube... I would have wrapped the up-pipe too, especially since you don't have the ceramic coat on it (mine was ceramic coated, then I wrapped it, and then coated the wrap with some high temp sealant). You don't need to worry about keeping your TMIC cool since you went FMIC, but the more heat into the hot side of the turbo the better.
RicersWetDream is offline   Reply With Quote
Old 10-17-2011, 08:18 PM   #842
psmBoXer
Member#: 90354
2011 STI
That dyno run is with E85 right? Do you have headers?
psmBoXer is offline   Reply With Quote
Old 10-17-2011, 08:22 PM   #843
ImprezivHokie
Member#: 256578
2011 WRX
SSM - Agile Protuned
Great work, love the setup... I think you're fine due to the inherent knock resistance using E85, more-so over a similar 93 tune. Are you making boost significantly faster from the EWG or was it more peace of mind? Good work... I'm definitely Jealous!
ImprezivHokie is offline   Reply With Quote
Old 10-17-2011, 08:35 PM   #844
xluben
Member#: 261612
2011 WRX 5 Door
Yes, E85. Yes, I have headers, stock ones. And the GrimmSpeed crosspipe.
EWG was mainly to deal with boost creep issues. Spool seems similar? I think it does make more top end with the same boost though
Old 10-30-2011, 04:41 PM   #845
xluben
Member#: 261612
2011 WRX 5 Door
Removed the backseat to head to the track for the last Sport Compacts Drag event of the year. Removal is quite easy. Probably takes 10-20 minutes or so. Only 5 bolts and 1 nut to remove.
Did one shakedown pass at the track and everything seemed to be going to fine. Went for the real deal on the second pass and the car blew up. Went home on a flatbed. I don't think the car liked the redline launches
Old 10-30-2011, 04:45 PM   #846
NaStIc
Member#: 289898
2012 WRX Sdn SWP
TP Stage 1
Oh man, that blows. Engine or tranny failure?
Old 10-30-2011, 04:57 PM   #847
jockeygolfs
Member#: 260868
2011 STI
Build time!!!!!!!
jockeygolfs is offline   Reply With Quote
Old 10-30-2011, 05:14 PM   #848
08WhiteRex
Member#: 187453
2012 Mulletmobile
Yeah, they don't like launches in general.
08WhiteRex is offline   Reply With Quote
Old 10-30-2011, 05:33 PM   #849
Celery GT-5
Member#: 98210
2011 SWP WRX 5 Door
lol 390whp and redline launches...you were really itching to build something
Old 10-30-2011, 05:44 PM   #850
rsutton1223
Member#: 280744
2011 WRX 417whp
AMG Magno Alanite Grey
Tranny or motor? Sorry to hear about the break.
rsutton1223 is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
Message Board Statistics All times are GMT -4. The time now is 01:58 AM.
