Old 03-06-2012, 10:46 AM   #1126
jockeygolfs
Member#: 260868
2011 STI
I think you should give the dealership a try. I was lucky. I told them that I was probably screwed from all my mods but to check the car anyways. SOA decided to swap my motor. Although I had my built block ready to go I decided to just ride out another stock block.
jockeygolfs is offline   Reply With Quote
Old 03-06-2012, 10:48 AM   #1127
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
always something interesting going on here. GL with the rebuild.
pretty sure upgrading the turbo voids your warranty if he did take it to the dealer he would get charged diagnostic labor hours
Celery GT-5 is offline   Reply With Quote
Old 03-06-2012, 10:49 AM   #1128
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That's not always a good thing. Lol.
xluben is offline   Reply With Quote
Old 03-06-2012, 10:51 AM   #1129
arf80
Member#: 125580
2011 WRX 5dr
This makes me rethink going stage 2 in the spring.
arf80 is offline   Reply With Quote
Old 03-06-2012, 10:54 AM   #1130
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
LOL. I wouldn't let this scare you off. This was considerably more power than Stage 2.
Old 03-06-2012, 11:02 AM   #1131
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I'm surprised you broke it with E85. The lower cylinder temps and high knock resistance usually make it pretty safe. It'll be interesting to see if it really is a cracked piston.
bluescoobywagon is offline   Reply With Quote
Old 03-06-2012, 11:27 AM   #1132
Spin1200
Member#: 250286
09GR phatbottiPowrd
T.S.P.'s test mule
EWG with stock mid-pipe and EL headers, spt axl-back FTW ! My noise comes from the front! hahaha
Spin1200 is offline   Reply With Quote
Old 03-06-2012, 11:29 AM   #1133
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Damn what tipped u off there was an issue ?
smeerone is offline   Reply With Quote
Old 03-06-2012, 11:33 AM   #1134
lickitysplitwrx
Member#: 276859
I'd guess a sudden loss in power.
lickitysplitwrx is offline   Reply With Quote
Old 03-06-2012, 11:42 AM   #1135
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, I have the stock exhaust, so it's even quieter than the SPT. Definitely makes a lot of noise from the front once the EWG opens up though.
I noticed the turbo was spooling really slowly (like 5-5.5k) and it wasn't hitting peak as high as it should. The idle was very slightly rough and vacuum was about 19inHg, compared to 21inHg normally.
I noticed this all on the drive home from work one day. At first I thought it was just a boost leak, but I couldn't find any leaks. My tuner suggested it could be a cracked piston, and when I opened the oil filler cap with the car on it was chuffing, so I did a compression check and the results were low compression on cylinder 2.
Old 03-06-2012, 11:46 AM   #1136
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Sorry to hear, are u ready for a build?
Old 03-06-2012, 12:03 PM   #1137
arf80
Member#: 125580
2011 WRX 5dr
My car usually shows 24-26inHG (Defi gauge) on startup/idle, what's the normal range?
Old 03-06-2012, 12:14 PM   #1138
Celery GT-5
Member#: 98210
2002 WRX SRP
lol I don't even know what mine is, I think I will start paying attention
Old 03-06-2012, 12:15 PM   #1139
Spin1200
Member#: 250286
09GR phatbottiPowrd
T.S.P.'s test mule
cold obviously, when your car is up to temp it should be 20-22, 20 is acceptable.
Old 03-06-2012, 12:16 PM   #1140
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Stay tuned!
That's a bit odd. Most I've seen are around 21-21inHg (or about 10psi).
That's one of the main purposes of a boost gauge. Vacuum readings can tell you a lot about leaks, etc.
Old 03-06-2012, 12:21 PM   #1141
Celery GT-5
Member#: 98210
2002 WRX SRP
I'm such a noob, gonna go obsess about it
Old 03-06-2012, 12:25 PM   #1142
Spin1200
Member#: 250286
09GR phatbottiPowrd
T.S.P.'s test mule
Originally Posted by xluben View Post
Stay tuned!
the best tools in my car are wideband/boost gauge, my first mods too, you dont want to be romping on these cars if there's an issue..
X, your lucky you have E85 by you, I have to travel for it, making it not practical for my dd, the power that can be made is ridiculous!
Old 03-06-2012, 12:53 PM   #1143
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Looking more at the cost/labor/downtime, I'm starting to consider parting out or selling as is...
Old 03-06-2012, 12:54 PM   #1144
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
Sad news man. Of course...this does mean it is motor build time.
I am going under the same assumption you basically did. Run the stock block until something goes wrong - then build it up. I'll be running a DD tune on 93 most of the time though...not sure if that will make a difference one way or another. E85 is pretty safe.
rsutton1223 is offline   Reply With Quote
Old 03-06-2012, 12:58 PM   #1145
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
If ure going to sell any parts pm me the list.
Old 03-06-2012, 01:55 PM   #1146
Celery GT-5
Member#: 98210
2002 WRX SRP
you should just find a cheap stock engine, throw that in and drive around at low boost while you build your engine then sell one when you are done
back to the inHG thing. Mine is right around the 22 line when its warm. That arf80 guy said his is 24 to 26 at start up, that seems backwards to me, the number is lower when your revs are higher.
you probably don't care at the moment
Old 03-06-2012, 03:19 PM   #1147
jockeygolfs
Member#: 260868
2011 STI
Selling the car totally?? Oh no!!! Your not the only one though lol.
Old 03-06-2012, 03:31 PM   #1148
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
LOL. But I do agree that it should go closer to 0 when you rev it higher (or at cold idle).
You're selling yours?
Old 03-06-2012, 03:37 PM   #1149
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Simplest explanation? His gauge is off. Double check it through the OBD-II or pull a vacuum line and put a mechanical gauge on it.
bicycle_wreck is offline   Reply With Quote
Old 03-06-2012, 03:46 PM   #1150
arf80
Member#: 125580
2011 WRX 5dr
Good idea, I'll log via the Accessport. The gauge does measure boost perfectly though, it hits 16.5 PSI exactly where my map says it should.
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
