#126 |
Member#: 267118
Vehicle:2011 WRX 4 door World Rally Blue |
Great job, xluben!
Same winter tire/wheel combo here, too. Subscribed.
#127 |
Member#: 186536
NESIC
Vehicle:2002 Impreza WRX WRB |
excellent job so far....I have the same wheel and tire setup for winter as well.
#128 | ||
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
Awesome!
You need a thread like this for your car. I'd love to ogle all the stuff you have for it ![]() You'll enjoy it. I love black cars. Had to get OBP when I got my WRX. Quote:
Had steelies on my last car for winter as well. I actually kind of like the look. |
#129 | |
Member#: 260868
South East
Vehicle:2011 STI White |
#130 |
Member#: 269794
NWIC
Vehicle:2011 WRX Premium DGM |
Really digging the murdered out look.
Do your mods void warranty? or are you not worried about it? I'll probably follow you on the steelies. tint? |
#131 |
Member#: 267118
The mods won't "void" the warranty but they do open the door WIDE for the dealer to DENY warranty coverage.
In all honesty, the part(s) you install should be proven to have caused the failure of the item you're trying to warranty. But OH the battle that would insue over that! Unless you're REAL tight with the dealer somehow or other, ANY performance mods (other than SPT) are playing with fire, warranty-wise. Chose your mods carefully and don't expect your dealer to fix what a bunch of HP/TQ increases break. |
#132 |
Member#: 261612
#133 |
Member#: 261612
I have mine installed with a Defi boost gauge on the right side, and a gauge pod blank on the left.
Actual view (wheel adjusted as I actually use it): ![]() Left Side: ![]() Right Side: ![]() Which one is OEM? ![]() The pod looks excellent. The finish is a near perfect match. Unless you told someone it was a new piece, there's no way they'd notice on their own. Even after being told 99% of people would say it looks identical. The gauge placement is very good. From where I sit the "MPH" is partially blocked on the speedometer, and a little bit of the temp gauge is blocked. The blinker/wiper levers do get in the way of the gauge pods a little bit depending on where you have the wheel adjusted to. Moreso on the left side where I have the blank. On the right side the wiper lever blocks a little bit of my boost gauge, but nothing that I need to see. Overall I am 100% happy with the pod, and would recommend it to anyone! |
#134 |
Member#: 246640
South East
Vehicle:'11 WRX WRB |
That cluster looks great, looks like oem.
#135 |
Member#: 261612
#136 |
Member#: 261612
Walbro 255 fuel pump went in on Thursday. Needed to do the double o-ring trick to get any fuel pressure at all. Took me a while, but everything is in and working well. Little bit louder than stock, but not bad with the rear seat back in place. The only time you can really hear it is when you turn the car on, once you're driving it's not noticeable.
More info on getting the pump to properly seal up can be found here: http://forums.nasioc.com/forums/show....php?t=2130397 Last edited by xluben; 03-26-2011 at 11:46 AM. |
#137 |
Member#: 261612
Kartboy Shifter Bushings finally went in today. I've had them for months, but never got around to putting them on. Turns out it is very, very easy on the newer WRX's. Jack up the car on jack stands, remove rear tranny brace, unscrew bolt holding in the stock bushing, pop out the bushing, and then install the new bushings and put it all back together.
Bolts all came out easily. Rear brace slides out, even with the COBB downpipe in place. And I had absolutely no trouble getting the old bushing out, or the new bushings back in. This install was really a piece of cake. Didn't take me more than 30 minutes. Real quick and easy. The difference in shifting feel is incredible. Much more firm and crisp. Notchiness is up a bit, but it feels great. Absolutely no question when you put the car into gear. Seems much easier to shift quickly and accurately. The bushings are a great pair with the MODE short shifter. Both are highly recommended. ![]() |
#138 |
Member#: 261612
Updated thread title. Thanks Ferg!
#139 |
Member#: 183361
NWIC
Vehicle:2008 STi DGM |
May I ask what gauge pod you purchased and where you purchased it from? Also, I see the Defi gauges you bought, where did you purchase those from?
Thanks for your time |
#140 | |
Member#: 261612
http://www.smyclustermaker.com/ The gauge is a Defi Red Racer that I bought from Rally Sport Direct: http://www.rallysportdirect.com/ |
#141 |
Member#: 53217
Great thread! I hope to pick up a 2011 WRX towards the end of summer after I graduate from nursing school. I can't wait, and reading threads like this is making the wait that much more difficult.
#142 |
Member#: 33174
RMIC
Vehicle:We are Open Late! 888-457-2559 Every day! |
Ben,
Cant believe I have missed this thread. The car is looking great, and as always your photography is amazing. Keep up the good work ![]() Kirill RallySportDirect.com |
#143 |
Member#: 242657
pretty sick
#144 | |
Member#: 261612
Thanks! RallySportDirect, and you particularly, have been great to work with. Highly recommended vendor! |
#145 |
Member#: 65856
Vehicle:2000 S4 Black 1992 Miata Red |
You have a great looking '11!
Keep up the clean work ![]() |
#146 |
Member#: 261612
#147 | |
Member#: 183361
NWIC
#148 |
Member#: 261612
#149 |
Member#: 178811
Vehicle:2013 WRB BRZ :banana: |
Might want to consider an oil temperature gauge instead.
#150 |
Member#: 261612
| Thread Tools | |
| Display Modes | |
| xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch | xluben | Car Part Reviews | 26 | 11-08-2012 06:55 PM |
| My first post and my first Subaru, a 2011 WRX 5 door in white. | Decade240 | Newbies & FAQs | 25 | 06-20-2012 01:48 PM |
| 2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? | BretCutler | Tire & Wheel | 4 | 01-14-2011 08:05 AM |
| 2011 WRX 5 Door | Ruz4life | General Community | 55 | 10-13-2010 11:37 PM |
| 2011 WRX 5 Door | Ruz4life | General Community | 10 | 10-04-2010 04:02 PM |
