Old 03-28-2012, 06:21 PM   #1501
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Which clutch setup?
xluben is offline   Reply With Quote
Old 03-28-2012, 06:24 PM   #1502
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
ACT hdss5 and stock flywheel. Dreading the install . I'm surprised the clutch went so fast with only 330hp. I do t beat on it and literally drive once a week.
smeerone is offline   Reply With Quote
Old 03-28-2012, 06:29 PM   #1503
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
How many miles? My stock clutch was doing fine at 22k miles (with 6k at 400+ WHP and 8k at 350WHP). After the motor swap and turning up the boost it started slipping and has been giving me issues since. It works fine around town pull rolling into WOT from a lower RPM causes it to slip. As long as I downshift it works fine. Going with a sprung puck disk next. That should hold (and make quick work of breaking my tranny).
Old 03-28-2012, 06:41 PM   #1504
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
It's a 2010 with 17k miles.
Old 03-28-2012, 06:45 PM   #1505
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yikes. And it's slipping with 300HP? That's not good.
Old 03-28-2012, 06:47 PM   #1506
blame
Member#: 226359
2006 WRX
obp
and then 6-speed time?
-sean
blame is offline   Reply With Quote
Old 03-28-2012, 06:53 PM   #1507
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Eh, who knows. I'd rather spend money on track days than a new tranny...
Old 03-28-2012, 06:55 PM   #1508
blame
Member#: 226359
2006 WRX
obp
but if you buy the tranny once, it will take you to all the track days and back. your 5 speed might only take you there ha ha
-sean
Old 03-28-2012, 07:04 PM   #1509
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Yes totally sucks, it is what it is.
Old 03-28-2012, 07:48 PM   #1510
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
The six speed will be better for road racing anyway. Go blow up the 5 speed at the drag strip with a 7k rpm launch, post a killer time( If it makes it to the end) and trailer her home to recieve her racing tranny
INKMAN is offline   Reply With Quote
Old 03-28-2012, 09:55 PM   #1511
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
-sean
Yeah, but a 6 speed costs as much as 3 years of track days. Lol.
Lol. I like the 5 speed...
Old 03-28-2012, 10:00 PM   #1512
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
I like the gearing of the 5 speed too. It took a while to get use to it coming from a 6 speed. With the power you're putting down I'm sure the gears feel short though, mine do not.
Old 03-28-2012, 10:03 PM   #1513
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah. The more power I get, the more I like it. Right now I feel like it has plenty of pull well above 100mph. Nice for daily driving too.
Old 03-28-2012, 11:34 PM   #1514
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
yeah I'm fine with the gearing, I don't miss having 6 gears, it was annoying
Celery GT-5 is offline   Reply With Quote
Old 03-29-2012, 10:41 PM   #1515
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I decided to try Plasti Dipping my Forge BPV tonight. It turned out pretty good. It looks nice now, but I really don't think the Plasti Dip will hold up to much mounting/remounting or opening of the valve. If you just paint it, mount it once, and never touch it, I think it will look OK, but if you have to take it on and off, or open it often, I don't think it will last. Anyways, here are the photos...
Before:
During:
After:
Old 03-29-2012, 11:04 PM   #1516
blame
Member#: 226359
2006 WRX
obp
nice. makes it look a little more oem kinda
less blingy anyway
-sean
Old 03-29-2012, 11:06 PM   #1517
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, that was the plan. I originally ordered a black one, but it came with the older o-ring style seal, so I had to swap it out for this one (I was on the stock TMIC at the time). When I swapped they only had the silver in stock. I've been wanting a black one ever since!
Old 03-29-2012, 11:08 PM   #1518
Wirtz
Member#: 286408
WFC #952
Function:error!
Looks nice!
Wirtz is offline   Reply With Quote
Old 03-30-2012, 04:00 AM   #1519
nighthawk06si
Member#: 267490
2011 WRX Hatch S2+SF
Looks good Ben! Good work! How does the forge bpv sound btw? Anything like the stock bpv?
nighthawk06si is offline   Reply With Quote
Old 03-30-2012, 08:52 AM   #1520
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
I'm probably going to end up with the Tial QR in black. How are you liking the Forge?
rsutton1223 is offline   Reply With Quote
Old 03-30-2012, 09:42 AM   #1521
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by Wirtz View Post
Looks nice!
Thanks! The Forge sounds very, very similar to the stock BPV. It is a quiet valve for sure. Similar size/form factor as well.
I like the Forge. It is a simple design, that will hold as much boost as you can throw at it. My only concern is that it is apparently designed to be open at idle (I have tested and confirmed this). I think that just about all recirculating BPV's are designed this way, but I could be wrong. Being open at idle isn't necessarily a bad thing, I think it serves to eliminate compressor surge (flutter) on partial throttle lift off. But in my mind it means that it takes a split second longer to close and allow boost to build. I haven't done anything to confirm whether this is really a noticeable difference or not (probably isn't), but it "seems" better to be closed under vacuum.
Recently I've thought about trying out some other stuff. I actually put a GFB hybrid BOV on the other day. It is closed at idle and vents 50/50 recirculating and to atmosphere. It is much louder than the Forge. Unfortunately I was getting flutter during partial boost lift off no matter how I adjusted the spring. I'm told this isn't really a bad thing, but I don't really like it. I've gone back to the Forge now (after painting it). Nice and quiet, and no flutter. I think I might try the TurboXS 50/50 next.
All the Tial stuff looks really nice. The QR BOV looks pretty big though. And you need an adapter
http://www.ultimate-racing.com/Produ...-TIAL-BOV2.JPG
I also think the TurboSmart Hybrid looks very nice. The Tial and TurboSmart are a bit more expensive though. I'm going to try the TurboXS first, and then maybe the TurboSmart Kompact BPV next. Then possibly onto the more expensive ones. Hopefully I find something I like. I think it may just come down to the fact that you either get a valve that is open/leaking at idle OR a valve that has some flutter. It may be impossible to get what I want. I'm not sure though.
Old 03-30-2012, 07:23 PM   #1522
blame
Member#: 226359
2006 WRX
obp
the idea of they synapse synchronic bov appeals to me, and you can get it with the subaru flange and recirc nozzle
-sean
Old 03-30-2012, 07:33 PM   #1523
noside
Member#: 241254
2015 Scat Pack
A positive to the recirc DVs are open under almost all vacuum conditions to allow intake air to bypass the turbo. At this point nothing is pressurized so it aids in off boost driving since cooling the air is not needed.
Air is going to take the path of least resistance which is from the dv return line in the intake straight to the manifold when the dv is open. It's not leaking at idle there's nothing to leak with no pressure.
Paint job looks good. Did you talk to forge directly about getting the valve in black or a distributor?
Would you be interested if forge offered a dual port hybrid type vta/recirc valve, with a dual piston design that is closed under vacuum and only lifts to vent boost?
noside is offline   Reply With Quote
Old 03-30-2012, 08:43 PM   #1524
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
-sean
As much as I like plug and play parts, I also like to fiddle with things. The Synapse looks like it has a lot of adjust ability options. It might be fun to try out.
Very good point about an open valve at idle. For some reason I didn't consider that it would actually be injesting air during idle. So maybe it would be best to have a hybrid that keeps the recirculating portion open at idle, but keeps the VTA portion sealed until it blows off (I think some exist like this). It still seems like that sacrifices response though. For response it seems that completely sealed would be best.
When I got the valve, the WRX flanged version (diamond seal) was not out yet. When it came out, it was only silver so that's what I ended up with. RallySportDirect handled the swap. If Forge had a hybrid valve I would love to try it! Do you work for Forge?
Old 03-31-2012, 02:40 PM   #1525
noside
Member#: 241254
2015 Scat Pack
No I don't work for them but I've worked with them in the past on a lot of things. I was working on design for a new hybrid type sti valve but it seems what I have thought out should be able to put into design onto the wrx valve as well. Give me a couple weeks I'll get back to ya.
Unfortunately the US director isn't to fond of EJ's. It was easy before to get things into swing since we had the same cars!
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
