Old 04-19-2012, 12:56 PM   #1801
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by olazy View Post
lol, i knew it. looks almost identical to the forge bpv, similiar sound-wise too?
Similar form factor, but I think the TurboSmart is actually smaller. The piston design is completely different though. The Forge has a much larger area on the top of the piston than the bottom. The TurboSmart has a piston that is essentially straight up and down (similar to most VTA and 50/50 BOV's). I think the TurboSmart might be a bit quieter.
xluben is offline   Reply With Quote
Old 04-19-2012, 01:13 PM   #1802
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Originally Posted by xluben
Yesterday I also installed the TurboSmart Kompact BPV. It looks very nice. It is really quiet.
I love the TS Konpact, I went with it just because it's quiet. How do you like it compared to the hybrids?
Overland04 is offline   Reply With Quote
Old 04-19-2012, 02:32 PM   #1803
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It appears to be the same piston design as the hybrids that I had (but different than the Forge). The only difference is that it has a lighter spring that allows it to be open at idle. It also only has one vent (recirculating) so it vents air approx twice as slowly as the hybrids.
I think if you want the ultimate in response (closed at idle, and vents a lot of air when it opens) then a BOV is the way to go. Especially ones with large vent ports like the Tial Q or TurboSmart Race Port. But even most 50/50 valves will flow a lot more than the recirculating valves.
The downsides are that the car usually has some compressor surge (due to the valve being completely closed at idle) and also backfires and possible stalling. With proper valve tuning you can minimize this, but it is always there to an extent. If I were blow through MAF or speed density I would probably use a BOV.
It's kind of a double edged sword. If you want response, you have to deal with some of the downsides (flutter and rich shifts). For most people, I still think the Forge is probably the best choice. But I think the TurboSmart Kompact does just as well, and has a similar price. I could see it getting more and more popular.
Old 04-19-2012, 06:35 PM   #1804
vinz0r
Member#: 154112
08 STi
^^ Nice car! Subscribed due to extreme details and reviews. Love it!
Btw, have you considered the Synapse DV? I'm running it on my 08 STi and I love it. Great sound, not too loud, fully recirculated, and has an extremely fast response time. Synapse Engineering makes great products IMO. I'm also considering their EWG.
vinz0r is offline   Reply With Quote
Old 04-19-2012, 06:46 PM   #1805
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I just looked at their site and saw the new DV series. I hadn't seen that one before. I'll have to look into it. I had looked into their older version for a while, but everything seemed more like a marketing pitch than real info. The design seems interesting, though.
Old 04-19-2012, 06:52 PM   #1806
vinz0r
Member#: 154112
08 STi
The marketing thing seemed to have occurred in recent videos. They have a pretty cool older video of testing the DV:
Also there's other older videos where their lead engineer disassembles the valves and explains their mechanism. I dug around for a while and I saw dyno graphs on EVO forums (the evo guys are all over them) where someone dynoed before and after install. And it turns out that he made more top end power after install due to a leaky stock BPV. Now I know that our BPVs aren't very leaky by nature and its use on a Stage 2 setup is limited. I still like their design. I mounted mine in Pull Mode. You probably would have more use their BOV, though.
Old 04-19-2012, 09:55 PM   #1807
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, those videos are still just marketing, IMO. They don't really show anything. 15hz with basically 0 lift doesn't impress me much. All you can hear is the control solenoid clicking. Coming from an engineering background and also a lot of experience with paintball, this seems pretty mundane. Paintball guns operate at pressures 5x-25x higher than most turbo'd cars, have valves that move ~1" per cycle, cycle 15-25 times per second, and last just as long as this "test".
The options for connecting that valve seem like they'd be fun to play with. I wouldn't mind toying around with one. I don't think I'd spend $250+ on it though. But maybe someday...
Old 04-20-2012, 04:37 PM   #1808
olazy
Member#: 263322
2011 WRX Limited
WRBP
Originally Posted by xluben View Post
With the help of ofspunk7, happyfeet, and my brother, we installed StopTech SS lines, StopTech pads and ATE SuperBlue fluid. I was worried about the brake line fitting stripping out, but I purchased some 5 sided flare wrenches and didn't have any problems. It was bit nerve wracking but it went pretty smoothly. Pads were simple and bleeding the fluid went well with four people
any tips on doing this? did you use a bleeder kit or just have someone pump the brakes? stock brake lines wrenched off easy peasy?
olazy is offline   Reply With Quote
Old 04-20-2012, 04:51 PM   #1809
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I bought a hand pump bleeder kit, but since I had so much help we just did it the old fashioned way pumping the brakes. It went fine. Nice and easy.
I was really worried about the stock brakes lines. I did buy a set of 5 sided flare nut wrenches for $10 and they made it really easy. It took a good amount of force but the nuts broke loose without rounding off or anything. No issues. Went very smoothly. Here's the wrenches I got:
http://www.harborfreight.com/5-piece...:referralID=NA
Old 04-20-2012, 05:58 PM   #1810
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Can't beat that. I don't know if I've ever bought a tool for 10 bucks! Actually I had to buy a 10mm 1/4 inch socket for 10 bucks. Damn Mac Tools.
INKMAN is offline   Reply With Quote
Old 04-20-2012, 09:47 PM   #1811
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
OK. Sounds like a waste of money.
Old 04-21-2012, 12:00 AM   #1812
vinz0r
Member#: 154112
08 STi
If I may ask, where did you source the new block? Did you assemble it from all the diff listed parts or did you buy it pre-assembled?
Old 04-21-2012, 07:08 PM   #1813
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Not really when you use something 20 times a day. If I used those wrenches you bought at work they would probably last a week. Just like car parts, you get what you pay for.
Old 04-21-2012, 09:03 PM   #1814
lickitysplitwrx
Member#: 276859
He bought it used.
lickitysplitwrx is offline   Reply With Quote
Old 04-21-2012, 09:25 PM   #1815
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, to a point. I'll have to admit, 95% of my hand tools are cheap-o crap from Harbor Freight. I wrench on my car a bit, but I'm no full time mechanic. Harbor Freight has a lifetime warranty and they're stuff costs a fraction of the big name brands. So far all the tools have done their job well. On things other than hand tools, I will generally opt for higher quality.
Originally Posted by lickitysplitwrx View Post
He bought it used.
Yep, bought one that was already assembled and then the guy parted out.
Old 04-21-2012, 10:18 PM   #1816
DeadGeneration
Member#: 313753
2012 WRX
TSM Tuned - 310whp/340wtq
nice car
DeadGeneration is offline   Reply With Quote
Old 04-21-2012, 10:19 PM   #1817
Fpgreen04 wrx
Member#: 317394
Hey guys I'm new to this and just had a question. I was just wondering around what kind of whp I would be looking at on my wrx?2004 2.1 liter Manley stroker kit, stage 3 clutch, grim speed boost controller, hta green turbo, ap uel headers with up pipe,turbo xs fmic, dw 850 cc injectors,turbo xs turbo back, Perrin underdrive pulley set,and Perrin intake. Oh and on 93 oct.???no e85 or race gas.
Fpgreen04 wrx is offline   Reply With Quote
Old 04-21-2012, 10:24 PM   #1818
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Ummmm.... I'm going to go ahead and say you posted in the wrong section.
Old 04-21-2012, 10:28 PM   #1819
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by DeadGeneration View Post
nice car
Thanks!
Yeah, I'll just go ahead and pretend that never happened....
Here's a shot of my car from today:
Old 04-21-2012, 10:28 PM   #1820
Fpgreen04 wrx
Member#: 317394
What section do I post in cause I do not know. But am very curious to know what kind of power my wrx will put out. If anyone knows
Old 04-21-2012, 10:29 PM   #1821
Fpgreen04 wrx
Member#: 317394
Sorry to offend anyone.
Old 04-21-2012, 10:30 PM   #1822
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
http://forums.nasioc.com/forums/show....php?t=1638314
Old 04-21-2012, 10:31 PM   #1823
Fpgreen04 wrx
Member#: 317394
Thanks
Old 04-21-2012, 11:19 PM   #1824
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Haha. that was awesome.
Old 04-21-2012, 11:28 PM   #1825
besthaticouldo
Member#: 279660
you wife (assuming) looks excited about that, lol.
btw. i'll have a package shipping for you by next friday or the following monday. my PC said they'll be done then.
also...its a satin, not matte and not glossy. i liked it. i may actually run the same one
besthaticouldo is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
