Old 07-11-2012, 02:18 PM   #2301
jhmr
Member#: 313217
2013 STi Sedan Stg 1
Plasma Blue Pearl
Does your wife mind the first gear whine? It almost sounds like the whine of a police siren.
jhmr is offline   Reply With Quote
Old 07-11-2012, 02:47 PM   #2302
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
Yeah, it does sound kind of like a siren. She doesn't like it much. She said it sounds like it's broken. But it's only in 1st, so normally you only hear it for a few seconds, and not at all while cruising.
xluben is offline   Reply With Quote
Old 07-11-2012, 05:10 PM   #2303
rsutton1223
Member#: 280744
2011 WRX 417whp
AMG Magno Alanite Grey
I'm clocking yours at about 5 seconds flat. Does that sound about right?
I tried to go out and get mine done today...not an easy task in Alpharetta, GA. I might try to go out later when I know there are no cars anywhere.
rsutton1223 is offline   Reply With Quote
Old 07-11-2012, 06:11 PM   #2304
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
SWP Bilstein'd COBB Stg2+
Just gotta explain that it's not broken, it's custom. And I wasn't cheap getting it to sound like that.
QwaktastiK is offline   Reply With Quote
Old 07-11-2012, 06:18 PM   #2305
xluben
Member#: 261612
2011 WRX 5 Door
I timed it at 4.8-4.9 seconds, but I didn't look too hard. In my older video when I revved it out to over 7k (and could make 100mph in 3rd gear) my time was 4.5 seconds. That extra shift costs me about 1/3 of a second it appears.
Here are some of my other times. My 5.3 second time did over 400WHP on Virtual Dyno, so I'm guessing you'll be around there or possibly slightly higher? I did have to shift into 4th for that one, so it should be comparable to yours in that regard (unless you rev over 7k).
1999 Accord - 4cyl - 5 speed - NA - 15.6 seconds
2011 WRX - Stock Turbo - E85 - 20psi - 7.5 seconds
2011 WRX - 20G XTR - E85 - 24psi - 5.3 seconds
2011 WRX - 20G XTR - E85 - 27psi - 4.5 seconds
Here you can see the Accord's run and the fastest of the WRX runs:
Old 07-11-2012, 06:18 PM   #2306
xluben
Member#: 261612
2011 WRX 5 Door
Yeah, that's not going to help. And she knows...
Old 07-11-2012, 06:26 PM   #2307
Celery GT-5
Member#: 98210
2011 SWP WRX 5 Door
TorquedPerformance Stage2
VTAK!!! its not that bad for an old accord..lol
Celery GT-5 is online now   Reply With Quote
Old 07-16-2012, 03:42 PM   #2308
xluben
Member#: 261612
2011 WRX 5 Door
rsutton - Where's that video?
I swapped back to my stock exhaust last night Going to sell the SPT. I'll be stock for now...
Old 07-16-2012, 03:43 PM   #2309
rsutton1223
Member#: 280744
2011 WRX 417whp
Trying. My area sucks for 50-100 pulls. Too many damn people and not enough straight, flat roads. I could cheat and pull down a downhill slope.
Old 07-16-2012, 03:48 PM   #2310
Jdub.csu
Member#: 283784
2012 SWP WRX HATCH
What made you decide to do that?
Jdub.csu is online now   Reply With Quote
Old 07-16-2012, 03:52 PM   #2311
Dale2011WRX
Member#: 304299
2011 WRX Sedan
You must be able to do that swap without looking by now.
Dale2011WRX is offline   Reply With Quote
Old 07-16-2012, 03:56 PM   #2312
xluben
Member#: 261612
2011 WRX 5 Door
Maybe you need to do one in both directions, lol.
Need some $$$.
With all the swaps, and taking it on and off for clutch and tranny swapping, I've probably taken it off close to 20 times now. It's pretty simple, lol.
Old 07-16-2012, 04:45 PM   #2313
Jdub.csu
Member#: 283784
2012 SWP WRX HATCH
I see why you did it not for money, just to ensure you don't get any seized bolts they can't seize if they are getting taken off all the time lol
Old 07-16-2012, 05:40 PM   #2314
Celery GT-5
Member#: 98210
2011 SWP WRX 5 Door
lol so many exhausts
Old 07-16-2012, 07:01 PM   #2315
xluben
Member#: 261612
2011 WRX 5 Door
I have broken two exhaust bolts and one for the turbo do downpipe. Maybe I need to swap more often.....
Old 07-16-2012, 07:07 PM   #2316
rsutton1223
Member#: 280744
2011 WRX 417whp
(A + B)/2 = C
Old 07-16-2012, 07:12 PM   #2317
xluben
Member#: 261612
2011 WRX 5 Door
(A + B)/2 = C
That's exactly what you do if you're going to do a road dyno and want to check if the road is flat. Do one run each way and see how they read compared to each other.
Old 07-16-2012, 07:16 PM   #2318
rsutton1223
Member#: 280744
2011 WRX 417whp
True. Not so good for running times though...well at least on the roads around here. Too much of a grade change.
Old 07-16-2012, 08:28 PM   #2319
xluben
Member#: 261612
2011 WRX 5 Door
That's even more reason to do two runs. Just to verify that they're at least close.
Old 07-17-2012, 08:36 AM   #2320
xluben
Member#: 261612
2011 WRX 5 Door
You jinxed me! I went to replace my header gaskets last night (thought I had a leak) and I snapped a header to uppipe bolt! What a pain. Car is running great now. Just stayed up a little later than I would have liked...
Old 07-17-2012, 08:38 AM   #2321
rsutton1223
Member#: 280744
2011 WRX 417whp
I just go throw it on the dyno.
Old 07-17-2012, 08:40 AM   #2322
xluben
Member#: 261612
2011 WRX 5 Door
Dyno's numbers can't be compared across the country. Road logs and 50-100mph times (and actual 1/4 mile times) can.
Old 07-17-2012, 09:00 AM   #2323
rsutton1223
Member#: 280744
2011 WRX 417whp
I meant for the tuning. Ideally, we would all need to run the same road at the same time just like a dyno comparison would need to be done. Outside temps, road conditions, elevation and other factors all play into a 50-100 mph pull and 1/4 mile runs just as they do with dyno pulls. It is fun to do though...and I need to get out and find a clean stretch of road to do mine.
I can tell you my car isn't as happy right now with 100 degree heat with 90+% humidity. I can't wait for that first crisp 70 degree day...I won't be getting out of the car other than to pump gas.
Old 07-17-2012, 09:42 AM   #2324
xluben
Member#: 261612
2011 WRX 5 Door
Outside factors certainly make a difference, but with 50-100mph and 1/4 you can tell who's car is actually faster, with that person driving it, in the climate that they drive in. It doesn't really matter though. It's just for fun. It's been 90-100F in MN for the last few weeks too. Not much fun, and not good for going fast
Old 07-17-2012, 10:14 AM   #2325
Jdub.csu
Member#: 283784
2012 SWP WRX HATCH
Do you use anti seize on the bolts for exhaust?
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
Message Board Statistics All times are GMT -4. The time now is 05:00 PM.
