Old 06-29-2002, 03:51 PM   #1
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Arrow Link2 hesitation fix
At least this worked for me.
I was having trouble with the car jerking at very low throttle (13-15% according to the Link) while cruising in lower gears (25 mph in 3rd). What I did that fixed it was to turn off the overrun vacuum fuel cut, as well as lean out my first row quite a bit. It's under the configurations heading, right under turbo. That fixed the problem that I was having, and now my car cruises smooth as silk now.
Now, I was also having the hesitation that other people were having (although at around 2500rpm, and driving around after making this change, I noticed that the hesitation was gone.
Will it cure the hesitation around 4500? I have no idea, but it might be worth a try.
Impreza Rider is offline   Reply With Quote
Old 06-29-2002, 04:00 PM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Thanx, I'm gonna go give it a try. I had this problem bad when I had the enrichment on tps. I have it on map enrichment now and it runs really smooth.
-Chav
Chav is offline   Reply With Quote
2007 STi Limited Hesitation Fix? LtdPilot Factory 2.5L Turbo Powertrain 113 03-18-2008 12:29 PM
Link Plus 3500rpm Hesitation fix (maybe) Chav Normally Aspirated with bolt-on Forced Induction Powertrain 10 02-23-2005 03:50 AM
Hesitation fix born2scooby Normally Aspirated Powertrain 15 01-22-2003 08:34 PM
How come SOA win't fix hesitation? Mike Smith Normally Aspirated Powertrain 8 05-24-2002 11:04 AM
k+n oil filter - fixes hesitation?! slater Normally Aspirated Powertrain 23 02-06-2002 10:40 AM
Message Board Statistics All times are GMT -4. The time now is 03:05 PM.
