Old 10-30-2010, 11:58 AM   #1
lwdavis
Member#: 261774
I've read a few threads on here and I just wanna make sure I got this right... I know the 2010 2.5i doesn't have a rear sway bar, is there a place to install the endlinks for them or would there be welding involved?
lwdavis is offline   Reply With Quote
Old 10-30-2010, 08:26 PM   #2
dharel0bs11
Member#: 258998
2011 Outback Sport
Blue Pearl/Steel Silver
All you need is the sway bar, end links and installation hardware. There is no welding involved. Everything bolts right into place.
dharel0bs11 is offline   Reply With Quote
Old 11-07-2010, 07:27 PM   #3
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
im looking into rallitek sway bars
SUBIESROCKUKNOW is offline   Reply With Quote
Old 11-08-2010, 11:37 AM   #4
moltenbykes
Member#: 260372
2012 OBP STI 5-Door
The rallitex sway bars seem to the the one to get for the 2.5i, I'm looking into putting a set on my 2011 OBS.
moltenbykes is offline   Reply With Quote
Old 11-08-2010, 11:52 AM   #5
08imprezahatch
Member#: 247867
08 2.slow
Default swaybars
I just put the rallitek 22 mm front and 19 mm rear sway bar on my 2008 2.5i hatch. The hardest part of the whole installation was definitely getting off the original front sway bar. After that the rallitek ones were really simple to put on.
08imprezahatch is offline   Reply With Quote
Old 11-08-2010, 01:56 PM   #6
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
The Outback Sport and 2.5i are, pretty much, identical for everything except the wheels and the paint. When you look for aftermarket parts, look under the 2.5i, you will almost never find anything specifically for the OBS.
I have the Rallitek sways for the 2.5i on my '09 Outback Sport and they are great!
Ogden is offline   Reply With Quote
Old 11-10-2010, 01:02 PM   #7
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
i got the cobb 22mm for the front and perrin 19mm adjustable for the rear and rallitek endlinks
i think the total cost for parts from subaru for the rear was like 14 dollars for the mounts and all the bolts
thegonz is offline   Reply With Quote
Old 11-11-2010, 07:31 PM   #8
nomas81
Member#: 262602
2010 impreza 2.5i
black
You mind posting some pics?
nomas81 is offline   Reply With Quote
Old 11-14-2010, 09:04 AM   #9
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
sure ill post some today i gotta go out to the garage first haha
Old 11-14-2010, 09:16 AM   #10
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
i hope that helps
Old 11-19-2010, 10:19 PM   #11
Ckuchta
Member#: 260193
Does it handle a lot better with just the rear ralliTEK sway bar? Or would you recommend the front and rear kit?
Ckuchta is offline   Reply With Quote
Old 11-20-2010, 02:41 PM   #12
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
my car handles alot better with the bigger sways front and rear and the endlinks
all depends on what you are going to be doing with your car too
Old 11-28-2010, 11:30 PM   #13
keylay
Member#: 260382
2011 Impreza OBS
Spark Silver
For daily driving, would you say the 22mm front/ 19mm rear would be suitible? I saw track spec that were 25mm front/ 22mm rear for a WRX.
I have the option of going with a rear only at 19mm with the stock, and I rear/saw on NASIOC that the 2011 OBS had a front at around 17-18mm? Or I can do the front at 22 and rear at 19? What is more geared toward better handeling daily driver?
keylay is offline   Reply With Quote
Old 11-30-2010, 04:21 PM   #14
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
I really like my 22F/19R set up from Rallitek on my car. Prior to the Rallitek set up, I had an OEM WRX rar sway bar (i think it was 18mm?) on there and it alone was a BIG improvement over stock handling. If you don't want to invest a ton of money, then I would go with a used WRX rear sway.
Old 11-30-2010, 07:15 PM   #15
keylay
Member#: 260382
2011 Impreza OBS
Spark Silver
I guess I'll try that set up...$300 isn't that bad compared to other projects I could be doing. Thanks for the reply.
Old 11-30-2010, 08:13 PM   #16
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
i have 25mm in the front and 19mm in the rear
Old 12-19-2010, 03:20 PM   #17
bill_?
Member#: 255530
Default install cost?
Any ideas what it would cost to have sway bars and endlinks installed at a garage?
bill_? is offline   Reply With Quote
Old 12-20-2010, 10:20 AM   #18
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
whatever the garage charges per hour
but to be honest its not very hard to do this at home i did all the work on my car without any help and im a noob haha
Old 12-23-2010, 08:10 AM   #19
luisv
Member#: 266098
2011 Outback Sport
Steel / Spark Silver
i hope that helps
Isn't this bushing bracket installed upside down? The tab should be pointing up and inserted into the hole above the bolt... no? The G on the bracket should be right side up...
luisv is offline   Reply With Quote
Old 12-26-2010, 11:41 PM   #20
Wrencher86
Member#: 250463
2010 Impreza 2.5i
^^^ Yep
Wrencher86 is offline   Reply With Quote
Old 12-27-2010, 12:25 PM   #21
ejhayes76
Member#: 267923
2011 Impreza 2.5i
+1.
I can't be bothered doing the install myself either. I live near Rallitek and emailed them for an install quote. I'll let you know they come back with. I'm going to be installing both front and back in my '11 2.5i. -Ed
ejhayes76 is offline   Reply With Quote
Old 12-27-2010, 02:42 PM   #22
bill_?
Member#: 255530
thanks ejhayes76 --- look forward to hearing the price quote for installation --- I probably don't have the right tools and I might install it wrong -- sounds like it's 2 hours at most.
Old 12-27-2010, 03:13 PM   #23
ejhayes76
Member#: 267923
2011 Impreza 2.5i
Reply from Rallitek:
Cost for the install labor for sway bar kit 40-1023 is $125. We are out of stock of the sway bar kit at this time but should have them available after the first of the year.
Thanks for the inquiry -
Jeremy Sells
Service Manager
ipd / RalliTEK
Old 12-27-2010, 05:20 PM   #24
luisv
Member#: 266098
2011 Outback Sport
Not a bad price, but if the install is anything like I've seen in various videos on line, it's 20-45mins tops to do the rear bar with basic hand tools and a torque wrench. Here's a video on how to do the front and rear bars:
Oem wrx wagon rear sway bar, driver control arm, and front/rear endlinks mywaganiswhite SCIC Private Classifieds 12 01-24-2011 02:20 AM
wrx front/rear brake calipers, wrx a-arms, stock front/rear sways/endlinks snowcrzy SCIC Private Classifieds 4 11-02-2009 10:11 AM
wrx front/rear brake calipers, wrx a-arms, stock front/rear sways/endlinks, snowcrzy SCIC Private Classifieds 6 09-14-2009 12:22 PM
FS socal: wrx front/rear calipers, wrx a-arms, stock front/rear sways/endlinks, snowcrzy Suspension/Brakes/Handling 2 09-01-2009 11:55 AM
Control arm and rear sway bar JM530 Brakes, Steering & Suspension 10 11-08-2005 10:09 PM
