Old 01-16-2015, 06:06 PM   #1
Bloodshot
Member#: 141149
2015 STI
Dark Grey Metallic
Default 2015 STI Grill Debadge Help
Do I have to pop the grill off to debadge the front of my 2015 STI? I've been trying to figure out a way to get behind there to look at how it's attached without taking everything apart. Has anyone else already done this?
Bloodshot is offline   Reply With Quote
Old 01-18-2015, 11:50 PM   #2
Bloodshot
Member#: 141149
2015 STI
Dark Grey Metallic
I'm not usually one to be annoying and bump my own thread, but has anyone else debadged their STI grill? this? Any help would be appreciated. Thanks!
Old 01-19-2015, 02:42 PM   #3
theturtleguy
Member#: 387113
2015 Launch Edition
Taking the front bumper is not too difficult. https://www.youtube.com/watch?v=jHocqtDqSNI
The badge is secured by 2 screws behind the grille. See this picture
theturtleguy is offline   Reply With Quote
Old 01-19-2015, 03:50 PM   #4
Bloodshot
Member#: 141149
2015 STI
Dark Grey Metallic
I've seen that video, while not "difficult", that is a lot of work just to take a badge off. Kind of disappointing there's no other way to access the back of the grill.
Old 01-19-2015, 07:42 PM   #5
haloseven
Member#: 34683
2015 WRX Premium
Ice Silver
I have no clue but if you're going to take the subaru emblem off then I will buy it from you.
haloseven is offline   Reply With Quote
Old 01-19-2015, 07:53 PM   #6
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
G-r-i-l-l-e
Don't Forget The "e"
Old 01-19-2015, 10:54 PM   #7
acemastr
Member#: 400510
2015 WRX Limited CVT
World Rally Blue
Originally Posted by Big-E View Post
G-r-i-l-l-e
Says Big-E
acemastr is offline   Reply With Quote
Old 01-19-2015, 11:40 PM   #8
Bloodshot
Member#: 141149
2015 STI
Dark Grey Metallic
I just want to get rid of the STI badge on the front, keeping the Suby logo.
Old 01-19-2015, 11:41 PM   #9
Bloodshot
Member#: 141149
2015 STI
Dark Grey Metallic
G-r-i-l-l-e
I didn't realize A-S-S-H-O-L-E was actually spelled B-I-G-E! But I do now remember why I stopped browsing these forums pretty quickly after I got my old WRX a few years ago!
Old 01-20-2015, 10:40 AM   #10
Constantfix
Member#: 410969
curious if you took off the back emblems and if so, how that went.
Constantfix is offline   Reply With Quote
Old 01-20-2015, 02:35 PM   #11
theturtleguy
Member#: 387113
2015 Launch Edition
Not a lot of work at all. Took me 5 minutes. There is no reason for the back of the grille to be "accessible". You don't even have to remove the front bumper completely if you want to de-badge it.
Old 01-20-2015, 03:55 PM   #12
Bloodshot
Member#: 141149
2015 STI
Dark Grey Metallic
I traded trunks with a WRX owner to get rid of the wing and he had already de-badged it. However I have de-badged other cars in the past and it's really easy. Just heat up the badge with a hair dryer, set on low so you don't screw up your paint, and peel it off. If there's any adhesive residue left over use WD-40 or goof off to remove it.
Old 01-20-2015, 04:05 PM   #13
dandingus
Member#: 387874
2015 WRX
Galaxy Blue
The STi badge on the front grille is two pieces connected with two screws. No way to get at the screws from the front, so you'll need to remove the bumper at least partially. Alternatively, if you don't care about saving the badge you could probably cut it off pretty easily with a dremel.
dandingus is offline   Reply With Quote
Old 01-21-2015, 11:22 AM   #14
Eraghast
Member#: 411484
2015 WRX
Crystal Black Cilca
Kinda unrelated but is the rear trunk Subaru logo badge easy to remove? Will it leave an indention if I remove it and is it connected by bolts like on the hawkeyes? I'm considering removing it but I'm not sure of the outcome.
Eraghast is offline   Reply With Quote
Old 01-21-2015, 12:59 PM   #15
Bloodshot
Member#: 141149
2015 STI
Dark Grey Metallic
I believe the Subaru badge is bolted through the trunk. Even if it's not, it will leave an indentation if you remove it. Personally I think the car looks TOO plain and generic without the center Subaru badge, but I like to remove the rest of them.
Old 01-22-2015, 02:50 AM   #16
daquattro
Member#: 411555
don't think so should be pretty easy, get a heat gun to lossen the adhesive and should pop off without too much trouble
daquattro is offline   Reply With Quote
