Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 05-12-2011, 06:14 PM   #101
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Nice! I think it would be cool to have this just for the reflective purpose and to add a bit more business to the back end.
Did you guys know that rallysportdirect.com sells this kit for $200 now?
Old 05-12-2011, 06:30 PM   #102
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Thats where I bought mine from.
Louie is offline   Reply With Quote
Old 05-31-2011, 01:06 AM   #103
littlewhitewagon
Member#: 103068
11 STI sedan
Ok, bump after some poking around since my front fog light kit finally came. The stalk switch in our cars are not regular switches. They are actually logic switches, so without reprogramming the BIU, we can not have the rear fog light work like it's supposed to via a European stalk. Sucks...
We also have a difficult time to bypass the need to have the headlights on to have the fog lights on for the same reason.
littlewhitewagon is offline   Reply With Quote
Old 05-31-2011, 01:41 AM   #104
J.biz
Member#: 191825
2009 WRX Hatch
Anyone know where I can find or order the fog light for the hatch/ 5 door?
J.biz is offline   Reply With Quote
Old 05-31-2011, 01:43 AM   #105
littlewhitewagon
Member#: 103068
11 STI sedan
European country that uses lhd cars.
Old 06-23-2011, 10:27 PM   #106
NemoSuby
Member#: 205091
11' WRX 10' XT
For those that have this kit, is it even reflective at night? Thanks.
NemoSuby is offline   Reply With Quote
Old 06-23-2011, 10:37 PM   #107
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I don't think so.
Old 07-07-2011, 04:44 PM   #108
moby1
Member#: 259359
Scott - thanx for the excellent post - can't wait to install this on my '11
moby1 is offline   Reply With Quote
Old 08-04-2011, 10:52 AM   #109
WillieGSTi
Member#: 272876
2011 Subaru STI
I wired mine as reverse light only.
WillieGSTi is offline   Reply With Quote
Old 08-04-2011, 08:56 PM   #110
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
so, it's white lens?
irish44j is offline   Reply With Quote
Old 08-04-2011, 09:37 PM   #111
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Heel boy! Heel!
Sit.....
Good boy.
Old 08-04-2011, 10:52 PM   #112
irish44j
Member#: 191290
09 OPB SM WRXsedan
Originally Posted by Louie View Post
Heel boy! Heel!
Sit.....
Good boy.
Shouldn't you be over on the .org arguing with Jason?
Old 08-04-2011, 11:09 PM   #113
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
No, he is too fragile.
Old 12-12-2011, 11:57 PM   #114
Sticow
Member#: 278382
2011 STi / GC8
13 Evo X
Anyone know where is a good place to order the rear fog light ?
Sticow is offline   Reply With Quote
Old 12-13-2011, 12:05 AM   #115
Midevil
Member#: 175065
2011 SWP WRX
INTERNET TOUGH GUYS? LOL
Have you tried reading the posts in this thread? Try the top of the page.
Midevil is offline   Reply With Quote
Old 12-13-2011, 12:54 PM   #116
WinterSubie
Member#: 243234
2009 Hatch
It'd probably be expensive because you would need a whole new taillight, you can see how it's in one of the tails in this pic
I'm probably going to pick up these though http://shop.jwmotoring.com/product.s...&categoryId=94
Or do you just mean the normal fog light kit up front? just order from subaru.
WinterSubie is offline   Reply With Quote
Old 12-13-2011, 01:24 PM   #117
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
To be fully proper you'd have to get a LHD rear foglight (left tail would be red), change out the stalk, run wiring, and convince a Suby dealership to enable the feature in the BIU.
jonklein611 is offline   Reply With Quote
Old 12-28-2011, 03:32 AM   #118
cubiculus
Member#: 305161
2011 STI 4-door
I have installed the rear fog light on my '11 STI 4-door recently. I tried to keep expenses down so I got the light assembly only (not the whole kit) from RallySportDirect for $110.
http://www.rallysportdirect.com/STI-...n-WRX-STI-2011
The rest of parts I got on eBay for the fraction of the cost - bulb socket, fog light switch, and front fog light extension harness (not necessary if you don't mind to tap factory harness in the vehicle). The instalation hardware (2 screws and 2 threads) is from OSH or Home Depot just for a few bucks. I also needed a spool of wire, a few connectors and a heat shrink tubings from RadioShack.
1. I installed the light assembly into the place as described in previous posts. I used a socket for 7440 bulb. The tabs on that socket needed minor modification with a cutter knife to fit into the light assembly.
2. I wanted to keep existing factory wiring intact to get the juice for the rear fog light. I got the juice from the front fog lights so the rear fog can be on only when the front fog lights are on. I spliced (soldered) the aftermarket extension harness and plugged it in between factory front fog harness and the front fog light. If you don't mind to splice or tap the factory harness you don't need this harness extension. This way you don't need an extra relay or a fuse for the rear fog light. The additional 21W rear fog bulb doesn't make any significant extra load to the front fogs circuit.
3. I routed the wires from the rear fog light to the dashboard and I did the same from the front fog lights through the firewall. I didn't want to drill the dashboard to install the rear fog light switch but I still wanted to have it on a visible spot. That's why I got the small fog light switch from Airtex that fits perfectly into the small panel right above the dimmer and headlights aiming knobs. This way you have to drill the hole only into this small plastic panel
4.The very good guide how to disassamble the interior to route the wiring from the rear fog light to the dashboard is here: http://techinfo.subaru.com/proxy/638...H630SFG300.pdf
5. Job done:
cubiculus is offline   Reply With Quote
Old 12-28-2011, 04:39 AM   #119
Midevil
Member#: 175065
2011 SWP WRX
Thats a pretty clean install. Looks good!
Old 12-28-2011, 11:09 AM   #120
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I wants the switch...where who I get it
Old 12-28-2011, 12:14 PM   #121
olazy
Member#: 263322
2011 WRX Limited
WRBP
Wow nice job cubi, I may have to revisit this mod.
olazy is offline   Reply With Quote
Old 12-28-2011, 09:12 PM   #122
cubiculus
Member#: 305161
2011 STI 4-door
I had a hard time to find the switch that is small enough to fit that spot. Beside that I didn't want to use an universal switch, I wanted one with a fog lamp symbol and an yellow light in it. The plastic material of the switch is almost identical to the plastic panel on the dashboard. When carefully installed (perfect round hole and no scratches) it almost looks like an OEM setup.
This is the webpage of the manufacturer: http://www.airtexve.com/homepage.html
This is the link when you can get it on eBay right now:
http://www.ebay.com/itm/Airtex-1S413...item2c61665179
Old 12-28-2011, 10:46 PM   #123
J.biz
Member#: 191825
2009 WRX Hatch
Thanks guys. But I found one on here from a forum member! I just wired it up to run with the stock fog light switch.
Old 12-29-2011, 09:37 AM   #124
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
^^Awesome. Can you take a picture at night?
Old 12-29-2011, 09:46 AM   #125
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
I wired-up a friend's 2008 hatch using a red LED bulb and a separate switch.
We did not color/tint the reverse lamp because there is no need to do so when using a red LED bulb. In this manner, the rear of the vehicle retains its original look - two white/clear back-up lenses.
We utilized the existing socket whereby I cut the power wire and installed a bullet-connector so that if he ever wanted to, he could return the socket to its original use as a back-up lamp. I also wired it so that when the car is off, it is off and thus the battery could not be inadvertently drained.
Please note that in this picture, my friend used a filtering lens to obtain this 'star' effect.
I installed a Hella-Toyota switch into one of the blanks in the center-console. Here is a picture of the switch in my car for reference:
B9 Tribeca amber rear signals and rear fog light DomozitoLK Tribeca Forum 4 02-01-2007 01:42 AM
Rear Fog Light Mod, Anyone done it? wrxEMT Interior & Exterior Modification 4 11-23-2001 01:21 PM
('93-'01) Rear fog lights on 2002 WRX US models ?? ginowrx Impreza Forum 15 06-15-2001 07:34 AM
Rear Fog Light Kit HRE | giulio Interior & Exterior Modification 19 05-12-2001 07:48 PM
Rear Fogs lights-uk Subarus come with? MichiganRS Interior & Exterior Modification 9 12-15-2000 10:03 PM
