Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 10-30-2010, 02:46 PM   #1
Draco Performance
Vendor Sales Rating: (7)
Member#: 111202
2004 STi
Blue/Gold
Default Gtspec | Kw | Stoptech | Endura-tech | Bc Racing | CUSCO
*More products to be listed soon* Draco Performance carries a full line of parts from the manufacturers below....
__________________
[B]Tuning*Suspension*Engine Builds*Quality Performance Parts* Race Track Prep*Enthusiast Educational Classes[/B]
[COLOR="Red"][B]For Draco Performance Merchandise -
[/B][/COLOR]
Draco Performance is offline
Old 10-30-2010, 02:47 PM   #2
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track.
What’s included?
* Calipers
* 2 piece floating directional AeroRotors with hats (pre-assembled)
* Stainless steel brake lines
* Caliper mounting brackets
* Street performance pads
* Caliper Color Options
Calipers are available in the following colors:
Rotors are available slotted, drilled or plain.
StopTech now offers an anti-corrosion gold zinc coating for all AeroRotors. The coating benefits customers who live in cold climates where snow and road salt are commonly encountered, and customers who would prefer to not have visible surface rust on the vanes and outer circumference of their rotors. Zinc coating does not have a negative environmental impact like other coatings.
Standard Pads
The performance pads included with kits are suitable for both street and light track use such as Autocross (1 lap at a time). For more aggressive track use or race use, it is very important to select pads appropriate to the type of driving.
The manufacturers below all make pads to fit StopTech calipers. Please see the compound descriptions in the “High Performance Pad” section of this web site to help you select appropriate street, track day or race pads.
Other Options-
- High performance brake fluid - Higher boiling point than stock fluid
- Rear slotted or drilled rotors for front kits - Add bite and match the aesthetics of the front kit
- Rear stainless steel lines for front kits - Provide quicker pedal response and better feel
- Rear performance pads for front kits - Increase maximum operating temperature compared to stock
Quality Assurance of Parts
All parts are bench tested prior to shipment. Each caliper is 100% pressure tested to 2,500 PSI. Every brake line is 100% pressure tested to 4,500 PSI. Every assembled two-piece rotor is tested for runout. Hats and brackets are made by StopTech to exacting standards on our own CNC machines. Since StopTech has complete control over our entire design and manufacturing process, we are able to deliver completely integrated kits with a very high standard of quality.
StopTech was the first aftermarket brake upgrade company to offer Balanced Brake Upgrades and is the only company offering optimized kits for over 277 applications. To our knowledge, no other brake upgrade manufacturer takes these design and test steps.
For the most in depth information regarding KW Coilover systems, visit the link below... see why KW Technology is the best on the market.
http://www.kw-suspension.com/us/kw_t...y_overview.php
__________________
[/B][/COLOR]
Old 11-04-2010, 07:22 PM   #3
Member#: 202645
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Includes:
Front Control Arm Bushings
Front Sway Bar Bushings - 20mm
Rear Sway Bar Bushings - 20mm
Rear Trailing Arm Bushings
Manual Transmission Shifter Stabilizer Bushing
Performance Polyurethane Master Bushing Sets
Get real performance, for both on the road and off.
Popular performance car, truck and SUV applications.
A real must for competition use, or just for that "seat-of-the-pants" fun!
Increases vehicle stability and control as well as durability.
Reduces wheel hop and traction loss.
Proven for many years, by both professional and amateur racers alike.
Both restores and improves better than new!
Made of Energy's HYPER FLEX performance polyurethane.
Heavy duty metal components are used, for increased strength, when applicable
An excellent choice in coilovers for your Subaru Impreza, WRX or STi. We offer 10-way dampening adjustability for your driving demands, lower bracket height adjustability, twin-tube gas shocks for steady handling and durability.
Strut Tower Bars
The Endura-Tech Subaru WRX/STi strut tower bar offers a more rigid chassis and better handling performance. Teamed up with the Endura-Tech coilovers for your Subaru, you won't be disappointed.
Sales@Draco is offline
Old 11-15-2010, 11:45 AM   #4
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
CUSCO CHASSIS SUPPORT BRACES - (4dr GVB Impreza)
__________________
[/B][/COLOR]
Old 11-19-2010, 09:08 AM   #5
Member#: 202645
Under chassis brace included braces that reinforce various position of the vehicle. We split them into front, rear and mid chassis. Most of our chassis reinforcement products are make of of 6061 aluminum with the exception of the fender brace and a few other braces. We will replace aluminum with stronger material such as steel or forged 7075 aluminum in places where we think aluminum will be too weak.
PM me or Email [email protected] for Pricing and Availability!
[/center]
Old 11-20-2010, 06:50 PM   #6
Member#: 202645
Weekend BUMP!
Old 11-23-2010, 09:39 AM   #7
Member#: 202645
Bumpssss
Old 11-24-2010, 09:00 AM   #8
Member#: 202645
Last bump for the holidays!
Old 11-29-2010, 08:13 AM   #9
Member#: 202645
Hope everyone had a good holiday!
Old 11-30-2010, 10:15 AM   #10
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
added some new CUSCO support braces!
__________________
[/B][/COLOR]
Old 12-01-2010, 02:32 PM   #11
Member#: 202645
PMs Replied!
Old 12-02-2010, 03:25 PM   #12
Member#: 202645
b u m p
Old 12-07-2010, 08:52 AM   #13
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
Cool photo bump!
__________________
[/B][/COLOR]
Old 12-08-2010, 04:45 PM   #14
Member#: 202645
Bump.....
Old 12-11-2010, 05:51 PM   #15
autoponicz
Member#: 239733
07 wrx limited
wrb
pm me price for front and read strut bars for a 07 wrx!
gt spec/tein/endura brands...thanks
im in 11377
autoponicz is offline
Old 12-12-2010, 08:47 PM   #16
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
PMed!
__________________
[/B][/COLOR]
Old 12-14-2010, 03:47 PM   #17
Member#: 202645
BUMP!!!! Check Out www.Draco-Forum.com
Old 12-17-2010, 10:27 AM   #18
Member#: 202645
bump.......
Old 12-20-2010, 12:55 PM   #19
Member#: 202645
bump*****
Old 12-27-2010, 03:09 PM   #20
Member#: 202645
Bump!!!!!!
Old 12-30-2010, 07:49 AM   #21
Member#: 202645
www.Draco-Forum.com Check it out! New suspension packages coming soon!
Old 12-31-2010, 08:01 AM   #22
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
Bump for the New Year!
__________________
[/B][/COLOR]
Old 01-03-2011, 08:13 AM   #23
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
__________________
[/B][/COLOR]
Old 01-04-2011, 08:21 AM   #24
Member#: 202645
Club racers get ready! A new season is right around the corner!
Old 01-05-2011, 08:56 AM   #25
Member#: 202645
Bump!!!!
Closed Thread
** Get the Most from Your AWD ** Tein Megan KW Stoptech Rotora Perrin & More ** AssaulTECH Suspension/Brakes/Handling 295 01-25-2013 11:36 AM
Bc Racing, ISC n1's, Megan, Tein, Whiteline, KW, Stoptech, Hawk, DBA DEALS INSIDE! IMPORTIMAGE Suspension/Brakes/Handling 1108 11-30-2011 10:33 AM
Cusco chassis Supports v8bware Suspension/Brakes/Handling 2 10-31-2009 02:55 AM
effective chassis support... [email protected] Brakes, Steering & Suspension 2 01-18-2008 11:13 AM
Whiteline Chassis Under Brace Install?? UM-WRXer Brakes, Steering & Suspension 50 06-23-2004 08:58 PM
