Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 11-01-2010, 07:57 PM   #1
Member#: 251848
Default Compression Tester - Extension fange
I bought this kit at autozone and tried to do a compression test on my 03' wrx and it was almost a catastrophic failure. The flange got stuck what I think to be in between the value covers/head walls. I didn't even get how I got it in because I manged to do a compression test of 130 in the chamber closest to the driver side firewall. When I went to use my 13mm socket I couldn't get a bite on the flange bolt head for the life of me, the only thing I could do to get it out was a bolt extractor kit.
I need some recommendations on were to get a longer flange i've looked everywhere autozone doesn't carry it and on amazon they appeared to be the same size. I'd say needs to be roughly twice as long.
1 7/8" Flange
ScoobieSnatch is offline   Reply With Quote
Old 11-01-2010, 08:22 PM   #2
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Don't even use the adaptor, it will only get stuck. I tried to use the adaptor, luckily I did not screw it in all the way, but my 5/8 spark plug socket was too thick, it wouldn't get in between the spark plug wall and the adaptor, so I just had to twist it out with my finger. (Much blood and a scratched up finger, I was burning red out of the exhaust when I started it up )
I just screwed the hose in until it seemed tight enough and cranked my engine over a few times and did it on each cylinder. My readings came out accurately, I had between 140 - 150 on each cylinder.
Some people say that some of the compression might escape through the little rubber rings, but from my experience, it is fine to just use the hose without the adaptor. And... if it doesn't work, then you don't have a stuck adapter in the spark plug hole.. that thing is a PITA to get out.
Just try it with the hose and see what happens. Like I said I got accurate results that way. Using the adapter, you are just looking for trouble.
Jessekrs123 is offline   Reply With Quote
Old 11-02-2010, 01:48 AM   #3
Member#: 134272
Chapter/Region: HIIC
2007 Sti, UGM
Rotated EFR 6758
I took an extra spark plug socket and ground it down to fit. Think thin wall socket, like really thin ones. Then its no problem getting the adapter out.
Krang is online now   Reply With Quote
Old 11-02-2010, 01:52 AM   #4
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
mine fit in my rs no problem. there is a 6 inch extension you can buy from the same company that you screw in the block, and then the hose onto that!
bue car is offline   Reply With Quote
Old 11-02-2010, 09:39 AM   #5
Member#: 232012
i just twisted the hose around till it felt tight, crank the motor... check results.. all my cylinders came to 152 and i just let it sit and it help pressure for 5 mins... so i knew it was escaping
Deathclutch is offline   Reply With Quote
Compression tester? Rally Monkey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-19-2006 09:12 AM
Anyone in the Houston area got a compression tester? jefersun Texas Impreza Club Forum -- TXIC 3 12-31-2004 05:22 PM
compression tester Rickyh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-08-2004 11:09 PM
Which compression tester do you guys use? mtb_dude Service & Maintenance 9 05-03-2004 01:22 PM
Anyone with Compression Tester??? blkwag Mid West Subaru Owners Club Forum -- MWSOC 1 09-04-2002 07:14 PM
