Old 11-01-2010, 09:01 PM   #1
makopolo
Member#: 260046
2011 WRX Hatchback
Default Difference between 2011 wrx and 08 impreza brakes
Looking into buying winter tires mounted on cheap steel wheels that came of an 08 Impreza.
Are they the same brakes?
makopolo is offline   Reply With Quote
Old 11-02-2010, 01:15 AM   #2
Jakubgt
Member#: 233051
Yes....
Jakubgt is offline   Reply With Quote
Old 11-02-2010, 09:48 AM   #3
makopolo
Member#: 260046
2011 WRX Hatchback
thanks...is it also the same hub?
Sorry I've never been interested in wheels so am fairly clueless.
Old 11-02-2010, 09:53 AM   #4
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
The 2.5i/OBS has different front brakes (and rear brakes on the 08...08 2.5i had rear drums....09 2.5i has rear discs) than the WRX so be careful. But if the wheels clear the calipers, yes the base Impreza and WRXes have the same hubs/bolt pattern.
09rexwagon is offline   Reply With Quote
Old 11-02-2010, 10:37 AM   #5
Mechoption
Member#: 246469
NO, they will not fit !! The 2008 Imprezza is a 5x100 bolt pattern and the 2011 WRX is a 5x114 bolt pattern. Here's the reference: http://www.cars101.com/subaru/tiresa...s.html#impreza The offset is 2mm different as well, but that's a moot point.
It's also not clear to me if all 16" wheels will fit over the larger breaks on the 09+? WRX's.
I found this all out the hard way when I tried fitting 2005 STI wheels on my 2010 WRX - doesn't work either (wrong bolt patterns)
Mechoption is offline   Reply With Quote
Old 11-02-2010, 10:41 AM   #6
09rexwagon
Member#: 216135
2011 Civic SI
Please ignore this post. The 2011 WRX still has 5x100.
I'll email Joe to update that mistake.
The 02-05 16" WRX wheels will fit the 08+ WRX brakes.
Old 11-02-2010, 11:04 AM   #7
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Might want to check your info. 05 STI wheels were 5x114 i thought. 04 STI's were 5x100 (i think).
2002 WRX wheels are 5x100 and WILL fit the 2011 WRX:
jonklein611 is offline   Reply With Quote
Old 11-02-2010, 01:57 PM   #8
Mechoption
Member#: 246469
Yes they will fit Apparently the cars101 page is wrong
Old 11-02-2010, 02:06 PM   #9
09rexwagon
Member#: 216135
2011 Civic SI
Ok we have some competing information in this thread.
The OP wants to know 3 things:
Do the 08 base Imprezas have the same brakes as the 08+ WRX: no, the front calps are bigger on the WRX and the 08 2.5i has rear drums and 09+ 2.5i has rear discs
Do the base Imprezas have the same hubs as his 2011 WRX: yes
Finally, will the 16" steelies from an 08 Impreza fit his 2011 WRX: he will have to make sure they clear the front calipers. BUT there is definitive proof the 2.0L WRXes 16" wheels fit the 08+ WRX brakes, so that is a known. The 08+ 2.5i steelies may or may not depending on the clearance to the front calipers.
Old 11-02-2010, 02:10 PM   #10
jonklein611
Member#: 117776
WR Blue Pearl
Assuming the 16" steelies are 16x6.5 and have a decent offset, then life is good. You'd need to get the specs on the steelies. Tire Rack has 16" steel wheels that will fit the 2011 WRX, you could ask them what the dimensions are and then compare those to the dimensions given for the 08 steelies.
Old 11-02-2010, 02:15 PM   #11
09rexwagon
Member#: 216135
2011 Civic SI
Not necessarily, there is a guy with an 09 WRX in our rallyx club who got some 16" steelies from an earlier Subaru and the offset was the standard issue +55, but due to the curving towards the outer circumference of the wheel, it would rub on the front caliper. So he ground down the edge of his caliper and it worked fine. But not everyone wants to take the angle grinder to their brand new car.
Old 11-02-2010, 04:35 PM   #12
Jakubgt
Member#: 233051
I thought he was talking about 08 wrx vs 11' wrx
differences between 04 downpipe and 08+ for the wrx/sti WRrexu General Community 11 05-17-2010 09:26 AM
08 WRX and 08 Impreza brake pads the same? VDMTom Brakes, Steering & Suspension 0 06-08-2009 05:26 PM
Differences between 02 WRX and 01 RS brakes? Texas25RS Brakes, Steering & Suspension 7 02-19-2006 04:19 PM
difference between 04 WRX and 05 WRX opramwew Southern California Impreza Club Forum -- SCIC 10 06-13-2004 12:29 AM
