Old 11-03-2010, 04:57 PM   #1
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Default What are the symptoms of a faulty fuel pump, FPR, and injectors?
I'm getting crazy IAM fluctuations from 16 to 4 along alot of FLKC and intermittent FBKC correction
I talked with my tuner and he provided a new map (based on all the logs i took).
After uploading the new map to the ECU and I went for an hour drive. The IAM is now down to 3.
The compression is good on the motor and I replaced the fuel filter (no effect).
What are the symptoms of a faulty fuel pump, fuel pressure regulator, and injectors?
Fierysun is offline   Reply With Quote
Old 11-03-2010, 08:10 PM   #2
quazimoto
Member#: 70395
Do you have a wideband? The symptoms would be gradually running lean at WOT.
Fuel pressure regulator is easy to diagnose.......get a fuel pressure gauge.
quazimoto is offline   Reply With Quote
Old 11-03-2010, 08:29 PM   #3
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
If this is on your 03 its most likely the fuel pump. Like quazimoto said get or barrow a fuel gauge and install it rite after the fuel filter B4 the fuel rails.
I seriously doubt it your regulator.
dangerousatom is offline   Reply With Quote
Old 11-03-2010, 08:31 PM   #4
dangerousatom
Member#: 70710
Old 11-04-2010, 03:10 AM   #5
Illicit1
Member#: 68372
Check for anything loose in the engine bay that might be banging on the motor, your knock sensor will read this as false knock. Happened to me, IAM wouldn't stay at 16 for very long but when i cable tied the offending loose tgv sensor left over from a manifold swap it fixed the problem.
Illicit1 is offline   Reply With Quote
Old 11-11-2010, 11:46 AM   #6
HTM WRX
Member#: 44463
2007 Impreza STi
World Rally Blue
a loose connector banging against the motor is enough to set off the knock sensor? wow!
I guess i need to zip tie my tgv connectors also.
HTM WRX is offline   Reply With Quote
Old 11-22-2010, 12:39 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
for the FP or FPR failing the ECU should start having +15% learnings in all ranges to account for the loss in fuel pressure.....
if a single injector is going the AFR may not swing enough......to check for a bad injector just let the car idle and start unplugging the injectors. If you unplug one and the idle doesnt change then you know that one wasnt spraying.
Old 04-09-2012, 10:02 PM   #8
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Thats a kick ass tip.
sackytar is offline   Reply With Quote
What are the symptoms of a bad injector timeless Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-14-2016 01:43 PM
What are the symptoms of engine damange hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 12-27-2005 05:21 PM
What are the symptoms of a leak before the turbo?? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-22-2004 02:18 PM
What are the symptoms of motor mounts? quickscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-15-2003 02:46 AM
what are the symptoms of a bad clutch? Keith Technical Forum Archive 6 09-18-2000 10:12 PM
