Old 11-04-2010, 09:58 AM   #1
silverbullet2006
Member#: 170933
2006 STI
SILVER
Default wiring eletric fan
well after my engine fire im gettin my 06 sti back on the road i just got the mishimoto x-line rad and fan set up. but now i have a problem the fan only has 2 wires and harness has 4 wires i have stock fan conectors but need to now what wires colors do i splice and hook up to the fan
silverbullet2006 is offline   Reply With Quote
Old 11-04-2010, 06:43 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If you have a white/blue wire on the harness connect that wire to the hot wire of the new fan and tie the other fan wire to the black or ground wire of the harness.
Old 11-04-2010, 07:52 PM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
the other two are basically speed sensors for the fans correct?
ProdriveDreams is offline   Reply With Quote
Old 11-04-2010, 08:16 PM   #4
Cougar4
Member#: 53443
Winestone
PD,
I think the OEM fans have two speeds. My info shows two power connections and two ground connections going to the fans that I assume are going to seperate coils in the motor.
Old 11-04-2010, 08:30 PM   #5
silverbullet2006
Member#: 170933
2006 STI
SILVER
colors are black yellow blue and green
Old 11-04-2010, 09:29 PM   #6
Cougar4
Member#: 53443
Winestone
Try the blue and black wires. You can also check the voltage on each wire with reference to chassis ground when the fan should be on. One wire should have voltage on it. Tie the fan hot lead to it and the other to the black wire.
eletric fan connection silverbullet2006 Newbies & FAQs 0 11-04-2010 04:10 AM
3 wire fan to 2 wire fan. ***Solved THANKs azn0boi04 Pre-2002 Factory Turbo Powertrain 4 03-19-2010 01:30 AM
Hayden fan controller or stock wiring for slim fans Twiztidunreal Electrical & Lighting 5 12-19-2008 12:42 PM
noob eletrical questions. wire has one side ribbed, the other dotted enozto Off-Topic 9 10-10-2007 09:56 PM
hard wiring my fans mcu81 Electrical & Lighting 1 01-26-2007 08:41 AM
