Old 11-04-2010, 01:46 PM   #1
WRCSubey6
Member#: 225030
Default Seam Welding?
If anyone feels they understand this area to the best of their own knowledge, to me it appears that there should be a seam welding FAQ for those who do not understand this to the fullest extent. Primarily there are so many applications to seam welding it feels that I only find bits and pieces of solid information and experienced drivers.
At the moment I am faced with researching about what the welding process to the unibody and critical points where "seams" are found? The car we are talking about is a true(making it 02) WRX drift build, weight-reduced(still more to go), and now seam welding and custom fabricated 8-point cage. Lets cut to the chase. The unibody and frame. Okay so I'm already down to the floor and have the cagebuilder at my disposal. Okay ready for seam welding....? We are talking drift. We are talking rigidity and long-term strain. We are talking GTWAW/TIG spot welds? Okay okay. Seam welding means there is a continuous line of welding right? A series of overlapping, inline spot welds. To stop, regroup, and quit asking one word questions. Who can point out where the seams on the unibody are and the important ones? About fully seam welding the entire body and undercarraige. What should I be getting ready to tell my welder to do?
Thanks to anyone who understands my situation and can look into this challenge.
WRCSubey6 is offline   Reply With Quote
Old 11-04-2010, 01:52 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
1.TIG is not necessary, and will prove to be a super tedious task. Go MIG w/ 75/25 mix.
2. do not do long, continous welds as it is very easy to warp the cheap metal
3. triangulate,triangulate,triangulate
eg33GC is offline   Reply With Quote
Old 11-04-2010, 02:11 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Take chassis, box it up, send to MSI. Write check, get car back and go. He's done this many times before, and is good at it. Hell, while it's there have him do the cage too.
Old 11-04-2010, 03:01 PM   #4
GhostRide
Member#: 3924
I owned a Subaru
once
Couple things off top of my head from doing this, yes it stiffens things up, undercoating is bane of existence, subaru floors are "thin" for welding, as stated no long beads, tig pointless, if building for drift dont bother as it just adds time in the repair after barrier meeting section (much harder to pull/bend back as everything is tied together). If I remember I did 2" bead and 1" gap, repeat as needed, move often to combat warping/have attack plan.
Find someone who has done this, has a rotisserie or a rig and let them do with the cage at same time to meet series specs.
GhostRide is offline   Reply With Quote
Old 11-04-2010, 03:54 PM   #5
MSI
Member#: 95419
I would not suggest 2" beads ever. Too much heat.
You can't tig seams on car unless the car has been acid dipped, forget about it. Too much contamination.
The type, position, and way you will do the welds whether in small beads, or stitches, or sports depends on a lot of things. an 8 point cage ... why not buy one that is already done from a company like custom cages? Will cost less and the engineering is done. You can simply do your own door bars if required (I am not getting into this one here) for various series.
Perhaps check out our build thread, we have a lot of photos of the chassis prep. For the record, we have 14 main anchoring points, and another 6 spots were the cage is welded to the chassis (dash, upper A-pillar, and mid-way up the main hoop / upper door bar)
8 points, were are you putting these points? How are you determining these?
Power, driver skill, and price point of the car? These all effect the level of prep.
No sense spending 40$k to prepare A SHELL if this is your first race car.
-mark
MSI is offline   Reply With Quote
Old 11-05-2010, 05:36 PM   #6
WRCSubey6
Member#: 225030
Have a Nice Day? Misconceptions
Alright, so this is great misconception A: that seam welding is always done by TIG. So I'm going to ASK, "should I tell my welder MIG?" What about say over the strut towers, and other critical stress points, do I need a "more durable" TIG Weld? Does this acid bath apply to a fully body seam weld or can it still be TIG in some places.
The 8 points (rear strut, A pillar, crossbar, to the firewall, dashbar) will involve this scheme. Any cage I look at online hasn't given me an idea of the full dimensions, so I don't feel very sound about getting a tight fit with one of these versus a custom fabricated. I wish I could find a weld-in cage online that makes more since to me, but I just figured get it in and get it in right. I have experienced a severe amount of struggle with cagebuilders and I am becoming very impatient. Otherwise I don't know.. the plan is to mimic one of these pre-constructed cages or one in another 02 and fit it tighter and stronger. The cage will be as open-ended as it needs to be until I figure out what it is about this seam welding that makes it so complicated. What do you think now?
I will do this, I am very curious in MSI now that I have learned a little more about your company. I have heard and known about MSI for some time but did not realize the level of expertise up to WRC, it's very cool. To go on though, chassis prep is definitely one of those other things in the back of my mind. If I cannot find your thread and you have gotten back to me by then and have time maybe go ahead and link that URL if you don't mind as I feel this would really beneficial and helpful as you have already been.
-mark
Old 11-05-2010, 05:58 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
Tig is not stronger, it is a large misconception. I will give TIG credit for being sometimes more durable, as it takes much more car to weld than Mig.
Tig hates any contaminants of any sort, whereas MIG will generally move the impurities to the top of the weld pool- creating a strong weld base.
Tig just is not an economical or feasible welding process on a unibody like the Impreza
Old 11-05-2010, 06:07 PM   #8
GhostRide
Member#: 3924
I owned a Subaru
once
I never stated it was 2" all at once, just mentioning the finished sizing for layout (that I did, not a mandatory number). If you want a cage order one from Custom Cages, maybe Autopower, OMP or take competition guidelines to cage builder.
Whatever you cage builder decides to use (mig/tig/braze/jbweld) should be in accordance with the guidelines for the cage build from the sanctioning body. Also, pricing can be a factor between tig/mig/material experience for some shops.
Basically, if your "cage builder" cannot answer these questions find a shop that can, ask to see completed work, maybe certified cages for competition use.
Start calling around to shops, maybe talk to competitors, get their builder info, talk to sanctioning body for trusted shops list if they have one. The more research the better.
Old 11-06-2010, 01:56 PM   #9
MSI
Member#: 95419
I would agree with the above stmnt. One process is not necessarily stronger than the other. The difference is the fit, finish, and precision required. You can't do small (1/8") seams with a MIG. Even if you use a .020" wire .. then there is spatter. However, you cannot TIG is impurities in the surface (I am speaking in generalizations here) Any contaminates (like silcon between panels on a car) must be removed to be able to TIG. The only way to get between the panels without removing them is to dip in acid. You can do it for sure, it will be a super clean weld, pretty, tight, and nice, then you simply have to re-seal all the joints after to keep dust and water from coming in once the job is done. Again, it will make a nicer job for sure, but will also add 10$k to the build for sure.
I personally have never TIG welded seams for the chassis prep. I remove as much debris as possible, then slightly heat the area I am to start welding, then spot weld 1/2" to 1" sections at a time PUSHING the melted debris out and scraping it away as I go.
However, we would choose to TIG weld on new, clean materials, thing wall tubing, and detail work. Question of looks as well as precision that cannot be as easily achieved with a MIG. Both tools at the end of the day are INDISPENSABLE. If I had a choice of one machine to do the most work, a quality MIG would be 1st, a TIG second.
A MIG can do everything, a TIG can't.
-mark
Old 11-08-2010, 10:20 PM   #10
WRCSubey6
Member#: 225030
-mark
Alright, so this has all been very helpful. I am going to speak with a moderator about making this a sticky. Whether or not EVERYONE, and in reality not many, the few that really do need to research this for their build. The only other input that I feel is needed, again as a reference, the definition of a seam, and where they exist. If someone doesn't mind giving some input on this matter as we have the welding type, style, and facts that support both of these, there is no explanation of the unibody.
WRCSubey6,
Old 03-20-2011, 01:06 PM   #11
Lurk
Member#: 222686
95 WRX Coupe
^MSI spot on.
Seam welding is a huge process. It's taking me a lot longer than I expected.
As far as cheap cage kits go, these are awesome. This is what I'm welding in my 93 Impreza rally car...
http://www.dirtyimpreza.com/forums/s...ht=safe+drives
here's their web and a few more cage options...
http://www.safedrives.com/products.asp?cat=103
Your welder should be able to weld that in for pretty cheap if he did MIG. All pieces of the cage come pre-bent, pre-cut, pre-notched and numbered instructions with layout.
Charles at Safe Drives hooked it up...this kit is awesome!
Lurk is offline   Reply With Quote
Old 03-23-2011, 05:09 PM   #12
side_show
Member#: 210921
1999 impreza 2.5rs
black
Hey MSI! are you welding with metal core or flux core??
side_show is offline   Reply With Quote
Old 03-23-2011, 08:15 PM   #13
MSI
Member#: 95419
Depends, but 90% of the time, solid core (no flux).
The flux is good for impurities, but welds are really nasty looking after.
Old 06-26-2014, 04:18 PM   #14
adrenalinejunkie
Member#: 204728
2004 STI
You guys flux some of your stuff? Do you use flux when doing cages? I don't know some of the sanctioning bodies allow that for cage construction.
WRCSubey6, you probably don't need this info anymore, but I will give my 2 cents for anyone else.
1. Prep will be a pain in the ass, but is possibly the most important part. Expect to spend lots more time on this than on the actual welding. Media blasting, sanding discs, or Polycarbide discs on a 4 1/2in angle grinder work very well. Freezing methods (Dry ice, liquid nitrogen), charcoal lighter fluid, and needle scalers can be used for underbody coating removal. You can get the discs cheap here http://www.harborfreight.com/4-1-2-h...eel-94017.html .The wire wheel is sometimes useful for the tight spots. Don't forget to use a prep(like a wax and grease remover) cleaner on all welding surfaces. I have good results with Prep-all. You can get it in gallon jugs to save on cost (home depot).
2. If you are really going to do this, A frame rotisserie is great. Propping the body up with a few 2x8s can be done , but is dangerous. It will not only make it easier to access the welding areas, but more importantly for average welders, it will prevent you from having to do lots of overhead welding. This will improve your weld quality. If you haven't tried overhead welding before, try it. Much more difficult for me at least.
3. Tack everything before you start any seams. Also, trying to avoid welding in one area for long periods of time. They will both help keep warpage down.
4. wear all the required safety gear- Mask, respirator, no exposed skin, etc... It is much easier to work when you are not burning or coughing up a lung.
5. Good areas to spend a little extra time might be the areas directly in front of front doors under the fenders. Around strut towers, near suspension pickup points, etc...
7. Realise what you are getting into before you start this. You are talking hundreds of dollars in just gas, wire, blades, respirator filters, etc.. Take for example the early 2000's WRC STI rally cars. Over 1,000 hours of welding was required for each each car. 1,000 hours. Sure they are doing more than you will, but it is still a lot of work.
All that said, I hope you did do or still will do it. Got to love when people go all out. Good luck and hope it helps.
adrenalinejunkie is offline   Reply With Quote
Old 06-30-2014, 11:57 AM   #15
Bansheeboy11
Member#: 182415
1999 RS
Im about 80% done stripping my car to seam weld. Aside from gas/wire, Harbor Freight is the best place for consumables like Roloc discs, sandpaper, blast media. Its super cheap and works just as good as name brand crap, especially roloc/sanding discs
Just gotta pull the glass and sound deadening.
Bansheeboy11 is offline   Reply With Quote
Old 06-30-2014, 12:00 PM   #16
adrenalinejunkie
Member#: 204728
2004 STI
Looking good! I doubt I need to tell you this, but a good windshield removal tool will be worth its weight in gold.
Old 06-30-2014, 01:00 PM   #17
Bansheeboy11
Member#: 182415
1999 RS
Yeh tell me about it. I tried a blade-pull tool, that didnt do anything but chip the glass. Im going to get a good wire tool from a friend and give that a go.
Old 07-01-2014, 06:34 PM   #18
Valkyrie
Member#: 210971
+1 for Mig, Ive done a number of chassis, and the difference between a successful seam weld and a line of bird ***** along a seam is always prep. While doing the Ford R2's for Team Oneil I dealt with many overlapping seams, with multiple layers of sealant. Similar to what mark said, I used a torch to heat the areas just enough to burn off the stuff I couldn't get, tap the seam closer together for a nice fit, then run a fast, uniform bead. Also worked on a acid dipped car years ago that was incredibly easy to weld, was super clean and gave awesome results, but I found that everything needs to be ready to install immediately because you end up with a nice coat of flash rust all over the car.
Ford Fiesta for Lucy Block:
and some stuff from the acid dipped chassis I mentioned
EDIT: Since this is a drift chassis, I highly recommend removing as much metal from the bumper/crush areas as possible. On the pro cars, the entire front and rear bumpers are made of aluminum, and meant to break away should their be an impact. Heres a more recent project of mine, this bumper was basically on there just to say it had a bumper beam, but was made of thin wall aluminum and barely welded so it would break away, and not correct the drift angle.
Dylan
Valkyrie is offline   Reply With Quote
Old 07-02-2014, 02:57 PM   #19
Bansheeboy11
Member#: 182415
1999 RS
For someone doing this at home, whats the best way to get old sealant out from the seams? I tried torching some of it but its hit or miss. I bought one of these and its the beez neez, the fingers get into the seams really well, skinny and long. But i cant get into corners like up by the cowl and in tight spots.
http://www.homedepot.com/p/Avanti-Pr...D01G/202830914
Old 07-02-2014, 06:05 PM   #20
69subaru360
Member#: 159682
1995 WRX
2015 F150
I can't see why anyone would seam weld a drift car. Contact with immovable objects is inevitable. You are making your life 10 times harder when it's time to replace crunched parts. Plus instead of parts crushing and/or breaking away, you now transmit all of the impact with said immovable objects into the chassis and your self who is strapped into a seat attached to a cage. Not smart at all.
Old 07-08-2014, 03:00 PM   #21
Bansheeboy11
Member#: 182415
1999 RS
Most of those cars make 600-1200 horsepower, if they werent welded together they literally would be wet noodles after a few events. Its mind boggling being in a 1000hp FRS, those cars get thrown around like rag dolls and they need all the chassis/suspension/steering response they can get.
Old 12-16-2014, 11:31 AM   #22
Bansheeboy11
Member#: 182415
1999 RS
Since i cant weld this whole car and get it to paint in a reasonable time, does anyone have suggesstions on what i can put on the metal to keep the rust away? I was thinking i can wetsand the area after the welding is done and spray down sealer. Ideas?
Old 12-18-2014, 07:12 PM   #23
wildmane
Member#: 408002
I'd suggest macropoxy... tough stuff, lots of people use it on rally car builds. And if you end up ready to paint, it's perfect for painting the underside of the car and the wheel wells.
http://protective.sherwin-williams.c...3Aproduct-6841
Check out the bottom of this post for some good pics of macropoxy in action:
http://www.rallyanarchy.com/phorum/read.php?5,34843
I've personally used KBS products, their metal primer works real well in conjunction with their urethane paints. Next time around though I will probably do macropoxy.
wildmane is offline   Reply With Quote
Old 12-22-2014, 09:30 AM   #24
Bansheeboy11
Member#: 182415
1999 RS
Wow thats pretty nice actually, and im assuming i can leave that as the outer coating instead of undercoating the car again? I think thats the same epoxy as their floor coatings, they use that for those fuel tanks and stuff outside as well. Think it'd be fine to use for a street car that gets lots of driving use? It literally cant be worse than factory 20 year old undercoating lol
Old 01-27-2015, 05:21 PM   #25
Bansheeboy11
Member#: 182415
1999 RS
Picked up a baller harbor freight oscillating tool and started the mundane process of stripping the coating off. It was moving slow so i deployed my special ops labor force with the crud-busters and wire wheels and we got almost have the car done. The remainder of the car might be prepped with a blaster if a business deal comes through, fingers crossed. But this stuff worked great, and uncovered lots of rust and rot, as well as smashed floor pans from me being a tool when i got the car...
Seam welding, how is it done? Ru fan Motorsports 6 02-25-2003 09:02 PM
Seam-welding questions dead-eye Normally Aspirated Powertrain 24 12-31-2002 11:35 AM
Seam welding XT6Wagon Motorsports 6 06-21-2002 11:20 PM
Seam Welding? ImprezedRS Motorsports 19 01-31-2002 09:53 PM
Self seam welding... tcs007 General Community 5 01-16-2002 03:19 PM
