Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 11-04-2010, 01:56 PM   #1
03 spec r1
Member#: 183864
03 wrx spec r1
yellow
Default P0302 misfire code
Hey guys,
so i changed my spark plugs last night, everything went well and the car performed great, nice and smooth and no hiccups last night.
this morning i go to start my car and notice its sounding a little rough, i pull out to go to work (2 km) and i have a harsh misfire from #2 cylinder. so i pull over, take the accessport out and clear ecu. start the car back up and it ran fine all the way to work even with boost.
has anyone ever experienced this before? its odd that it went away after resetting ecu.
03 spec r1 is offline   Reply With Quote
Old 11-04-2010, 04:14 PM   #2
03 spec r1
Member#: 183864
03 wrx spec r1
yellow
Update:
started the car to go for lunch, when the car is cold it seems to be misfiring, got blinking CEL and all!
once the car warms up fully there is no hint of misfire.. soo confused
Old 11-04-2010, 05:19 PM   #3
SuperooRexTeeEye
Member#: 263016
Platinum Silver
hmm...Do you have a TBE or an up-pipe installed? I know with my up-pipe,DP or intake that I am constantly throwing "misfire" codes. Only under WOT from 4500 up... More info would help out..
SuperooRexTeeEye is offline   Reply With Quote
Old 11-04-2010, 06:29 PM   #4
soob noob
Member#: 220158
02 bugeye
medamullet tuned
im getting this p0302 code too and cant figure it out! ive changed plugs, coil packs and swapped injectors and cant find anything.. so im subscribed to see if you find anything out
soob noob is offline   Reply With Quote
Old 11-04-2010, 06:52 PM   #5
03 spec r1
Member#: 183864
03 wrx spec r1
yellow
yes im stage 2 with up pipe, this has never happened before and once the vehicle is warmed up there is no misfire what so ever, even under high rpm, high load.
very confusing, im going to tear the car down tomorrow morning and see whats going on.
Old 11-06-2010, 09:19 AM   #6
03 spec r1
Member#: 183864
03 wrx spec r1
yellow
Update:
after resetting ECU a few times, the car has not acted up in two days with very cold starts and damp conditions.
Old 11-07-2010, 12:41 AM   #7
chrisjsledge
Member#: 226072
03 WRX
Sonic Yellow
i've thrown that error code a couple times, after cold starting. im also cobb stage 2 no cats. after clearing a couple times. i havent seen it for monthes. i moved from florida beach back to south carolina. slight elevation difference. but im pretty sure i flashed it since moving.
chrisjsledge is offline   Reply With Quote
Old 12-14-2010, 11:50 AM   #8
Swany
Member#: 142198
02 WRX
Always bet on black!
Just adding to the troubleshooting database....
I was cruising along at 45mph, when my car stuttered a few times, and then started shaking with a huge loss in power. The car would run, it would idle without dying, but it definitely had a problem. I read the code and it popped a p0302, cylinder 2 misfire, and that's it. So i changed the spark plugs, and no dice. Got ahold of a few working Coils, but decided before i put new ones in, i should swap the coil from cylinder 2 to cylinder 4 to see if the gripe followed. Started the car up, and the problem went away. My guess is there was a poor electrical connection somewhere, but i'm taking it easy for a bit just to make sure. Hope this helps everyone out there that comes up with this problem.
Swany is offline   Reply With Quote
Old 12-14-2010, 12:40 PM   #9
ecp_1991
Member#: 227163
03 WRX
wrb
Just to add, my cousins 06 wrx had a misfire on cylinder 2 and he just kept driving it like that for the rest of the day and now he has a blown motor.... when we went to do a compression test we noticed that the wire that clips into the coil pack was loose on cylinder 2... so that would be somthing to check
ecp_1991 is offline   Reply With Quote
Code P0302 misfire #2 Impwrxza Vancouver Impreza Club Forum -- VIC 4 06-21-2009 09:04 PM
P0302 and codes MadmanGenius Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-26-2009 10:26 AM
cel p0301,p0302 pending code ben c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-24-2009 06:45 PM
HELP! P0302 Misfire Detected in Cylinder #2 awd-box-turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-03-2008 02:05 PM
P0302 obd2 code harrity Newbies & FAQs 1 04-23-2007 08:53 PM
