Old 11-04-2010, 06:12 PM   #1
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Default The latest my EJ20 died now I'm rebuilding it thread full of semi-usefull information
Forward
Since someone asked if I was working on a write up of my build, and so Juan can have a thread to read I figured I will write a mini-saga of events.
Preface
My stock internal EJ20 died at 105k miles. All injectors checked out however. This was all on a ported TD04. I had already planned on building an engine to safely run in the 320~hp range on the side. This just made me start a bit early.
Let's Begin
In trying to combine the most budget minded build and reliability here's a list of what I decided to go with. I will also try and include costs of everything including labor and shipping.
Required
Short block and heads - $400
OEM Crank - $330
0 Mile STI rods - $150
Mahle .5mm Powerpak pistons/pins/rings - $450
ACL HX Race bearings - $110
11mm Oil pump - $120
OEM Gasket kit - $300
Valve cover gaskets - $20
OEM Oil cooler - $200
Various OEM hoses water/vacuum - approx $100
Group N engine mounts - $130
Replacement ACT clutch disc - $205
Gates timing/water pump kit - $400?
Lifter shims x 13 - $65
Permatex Ultra Gray - $7
Plastigauge - $4
Labor
Bore/ Hone - $100
Balance - $120
Valve job - $100
Pressure test of heads - $70
Clean block/ file rings - $50
For Free
Polishing of rod beams
TGV delete porting
Assembly
Advice on NASIOC
Optional
Witch Hunter injector service - $110
Walbro fuel pump - $80
Step colder plugs - $30
Blouch TD05-16G-XT - $905
Ceramic coating - $75
(soon to be tuned) - $400
Already installed
Catless up pipe and TBE
3 Port EBCS
Ebay TMIC
K&N short ram intake
Mishimoto radiator
ACT light weight flywheel
MRT straight cut 1-4 gearset
Cryo treated transfer gears
STI center and front LSDs
Notes and lessons learned
Make sure you have cleaned every possible spot after you get your parts back from the machine shop. There was metal left over from the honing we had to to clean. Pull all plugs to oil galleries and clean them out with compressed air/ a parts washer.
Use common sense when torquing bolts. I found out the hard way of the misprint in the service manual in regards to the front cam cap bolts
Not sure if anyone else has done this. But we primed the engine on the stand with a 1/2in drill instead of doing it in the car. Just to make sure everything was working before going through all that work. We hooked up a mechanical gauge to the block and spun it over, the drill could make it read 80 PSI, so that seemed good
Right now I'm waiting on the turbo/ inlet to finish it and drop it in the car and then on to the break in/ tuning. Here are all of the pictures I have taken over the course of the project http://www.flickr.com/photos/4913125...7624984952574/, which is taking twice as long as I expected. Anyone feel free to share questions, comments or cuss words
340Duster is offline   Reply With Quote
Old 11-04-2010, 07:17 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
haha great, I hope it all goes well.
Old 11-04-2010, 11:29 PM   #3
Csquared33
Member#: 198053
93 2JZ something
please add some headstuds to that list
**edit just read its already in
Csquared33 is offline   Reply With Quote
Old 11-05-2010, 08:22 AM   #4
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Head studs for 320whp?
Old 02-22-2012, 10:43 AM   #5
millerlite6633
Member#: 288223
would you need to have a new clutch and diff for 320 whp?
millerlite6633 is offline   Reply With Quote
Old 02-22-2012, 12:23 PM   #6
KpT KiM
Member#: 242422
Diff, no. Clutch, probably. Exedy Stage 1 should be good.
KpT KiM is offline   Reply With Quote
Old 02-22-2012, 01:10 PM   #7
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
What he said, and it depends on purpose and driving style
Old 10-17-2012, 08:40 PM   #8
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Bumping my thread here, mainly for Juan I've hit 40k miles on the engine with no issues. Still running strong with hardly any oil consumption. Just goes to show it's not how much you pay to have an engine built, it's in research and attention to detail (and talking to people who are experienced in engine building in general).
Old 10-17-2012, 09:03 PM   #9
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Did you assemble the engine yourself with just plastic gauges and no tq plate?
What kind of power does the car make and what do you do with the car.. Drag/autox/road race/dd/ect
Old 10-17-2012, 09:09 PM   #10
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Yep we clearanced the bearings with only plastigauge. It was honed at a shop with no torque plate.
It's a 16G-XT on E85. On 93 it put down 325 on a dyno. It's seen the track just a little bit, and a couple of autoX events. But it's been a DD for the rest of the time in all kinds of SC weather. Plenty of "spirited" driving, meaning it sees full boost and plenty of RPM every day.
Old 10-17-2012, 11:49 PM   #11
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I also learned that the hard way. Did you end up breaking the bolt or stripping the threads? I broke a bolt and had to drill it out and have a helicoil put in
geronimo81 is offline   Reply With Quote
Old 10-18-2012, 12:04 AM   #12
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
The part of the bolt that wasn't threaded actually stretched and they just didn't torque. So luckily I was able to back them out and just buy new ones.
Old 12-11-2012, 02:49 PM   #13
RL206
Member#: 231707
'97 OBS
2-Tone/Green
Great job, I will keep this bookmarked for references!
Holy wow, that piston... haha
RL206 is offline   Reply With Quote
Old 12-11-2012, 09:26 PM   #14
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
That's what detonation will do over the period of a week or so
Old 12-12-2012, 12:39 AM   #15
Cortiti
Member#: 340376
Cortiti is offline   Reply With Quote
Old 12-18-2012, 02:07 PM   #16
verve94
Member#: 78701
2004 WRX Wagon
WRBlue, of course
tagging to read later.
verve94 is offline   Reply With Quote
The Thursday thread full of stupid. Strider Off-Topic 85 09-20-2007 12:56 PM
I washed the car and now I'm giving it away. H.K. Phooey Texas Impreza Club Forum -- TXIC 21 04-08-2007 10:29 PM
So, I pulled a prank on my boss and now I'm worried boosted84wagonmonster Off-Topic 70 07-09-2006 12:34 AM
A whole thread full of n00bs who have never seen the STi in the ice... Sean Off-Topic 5 10-09-2005 02:42 PM
Now I'm angry. (the thread formerly known as 'Helmets DO work!') Kinsbane Off-Topic 18 08-11-2003 02:15 PM
