Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 11-04-2010, 10:16 PM   #1
BzY
Member#: 29741
Default what to look for when buying a gc8 with wrx motor
hello everyone. friend is buying a 2001 gc8 with a wrx motor. what do you think we should be looking for when inspecting the car?
thanks in advance.
BzY is offline   Reply With Quote
Old 11-05-2010, 10:32 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
what version of the ej20 is it
how many miles on engine
will it pass emissions - even if your state doesn't have it
is the obd-2 functional - needed for tuning (for 205/207/255s)
does the AC work
is the fuel pump controller wired in correctly (for 205/207/255s)
who did the swap
harness swap, partial harness swap, harness merge
source of the engine
maintenance done on the engine during swap
clean title
what transmission
what rear diff
what clutch
what boost has been run (factory vs mbc)
what tuning has been done
which front crossmember (Legacy Turbo, 92-01 jdm ,94-2004 jdm TT, 205/207/255/257 w/ washers, hack n smashed NA)
miles on the shell
what rear sub frame
what Rear hubs/brakes
what gas tank
engine modifications injectors/turbo/exhaust/EM
compression check
Old 11-05-2010, 11:38 AM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
I'd avoid buying any swap unless you personally know who did the swap and whether or not they knew exactly what they are doing. I'm assuming that whoever did the swap, swapped out the entire harness, so if they did not really know what they were doing, you can run into a lot of electrical problems which are such a PITA to deal with.
Jessekrs123 is offline   Reply With Quote
What to look for when buying an 03 WRX... SS/GNX Newbies & FAQs 6 07-14-2009 05:16 PM
what to look for when buy used sti or wrx ? slys13 Newbies & FAQs 7 12-04-2008 09:35 PM
What to look for when Buying a Used WRX EmeraldEclipse Newbies & FAQs 17 03-27-2005 12:33 AM
What to look for when buying a used 02 WRX? datchineseguy General Community 6 04-30-2004 07:01 AM
What to look for when buying a WRX w/ 17k miles. Kamil Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-26-2002 10:33 PM
