Old 06-30-2002, 06:07 PM   #1
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Default Aftermarket fuel pump
Seems Alan Adam (ASR) strikes again. The Walbro pump he sold me is completely wrong.
Were can I get the correct fuel pump 255 LPM? and the part number.
david2z4 is offline   Reply With Quote
Old 06-30-2002, 06:18 PM   #2
tranjo
Member#: 11745
2002 Rex cobb tuned
Thumbs up
go with the supra pump
tranjo is offline   Reply With Quote
Old 06-30-2002, 06:28 PM   #3
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
What year and engine?
Old 06-30-2002, 06:44 PM   #4
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Shucks wants $855 for it
Old 06-30-2002, 07:24 PM   #5
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
david2z4, have you been running turbo with the stock RS pump? What kind of psi and RRFPR are you using? Has it worked ok, or is that the reason for trying to get the new pump? I'm just starting on a low-pressure turbo setup for my RS, and trying to decide what kind of fuel delivery system I'll need. I already have a Vortech 6:1 FMU, and am only looking at running 5-6 psi, by the way. And does that Supra pump just replace the stock one? How does that work, being a Toyota part? Is it sourced from the same place that makes the stock RS pump? Sorry, not trying to hijack you, you just seem to be in a position to answer this stuff. Thanks!
HondaH8er is offline   Reply With Quote
Old 06-30-2002, 07:40 PM   #6
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Stock fuel pump
I never had a problem running with my stock fuel pump with 5psi of turbo boost. Even with a 50-60 shot of nitrous, everything seemed to work fine. I just upgraded to a higher flowing pump just for the safety. Fuel pressure and air/fuel ratio was never a problem. I do have a 2.2ltr though but still. I've no turbo now though.
Kevin Thomas is offline   Reply With Quote
Old 06-30-2002, 07:49 PM   #7
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
I am running no RRFPR just the 550 injectors and the Tec3.
Fuel seems to be fine with the stock at 7psi. Fuel press does not drop below 38psi.
Old 07-01-2002, 01:15 AM   #8
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
If you're running a steady 7psi of boost, you need to make sure that you are sustaining 50psi of fuel rail pressure all the way to redline. IIRC, the stock pump in my RS turbo could no longer supply enough fuel beyond 8psi. To play it safe, I'd say that anything more than 5psi requires some type of high-pressure/high flow pump upgrade. Pumps have a nasty habbit of failing slowly. Slow enough for you to never pick up on it until it's too late. They are also pretty sensitive to operating temps which can also effect the flow capacity.
my 2c,
shiv
Vishnu Performance is offline   Reply With Quote
Old 07-01-2002, 02:19 PM   #10
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Thanks, Shiv, that's good stuff to know. So maybe I'll just concentrate on the kit for now, since I already have the RRFPR, and after I get it running, I'll upgrade the pump. What do we need to look for in a upgraded fuel pump?
Old 07-01-2002, 11:19 PM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
i got the walbro gss317, and it fits like a glove
akcel is offline   Reply With Quote
best aftermarket fuel pump realitycheck3907 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 12-14-2009 07:55 PM
Anyone not running a aftermarket fuel pump with VF39 swap? breezeby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 01-12-2008 10:20 AM
WARNING. If you have installed an aftermarket fuel pump PLEASE READ. AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 48 11-12-2005 12:59 PM
bad fuel pump?? any aftermarket?? pearlblack2.5rs Service & Maintenance 2 11-15-2001 02:17 AM
