Old 11-05-2010, 05:30 PM   #1
05wrxozzyman
Member#: 191923
2005 wrx sti
Default MAke AVCS work in wrx
i have a full sti swap on my 2005 wrx is there a way to make the AVCS work on my 2005 wrx wire harness
05wrxozzyman is offline   Reply With Quote
Old 11-05-2010, 05:52 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
your ecu does not support avcs.
several options.
get jdm wrx ecu, but electrical harness could be different.
get sti ecu, but electrical harness could be different.
get a stand-alone that supports avcs, hydra
take your pick.
Old 11-05-2010, 07:15 PM   #3
prometheum
Member#: 92003
04 bicycle!
1 jdm sti V7 ecu is probably the easiest solution, but you will need to run 4 wires from the ecu to the avcs solenoids. iaperormance sells a harness you can patch in for this iirc
2 a usdm sti ecu with a full headlight to tail light wire harness
3 standalone ecu
4 get an sti
prometheum is offline   Reply With Quote
what is needed to make avcs heads non avcs nhsilversti Built Motor Discussion 9 11-02-2010 11:16 PM
sti tranny working in wrx? tylerrusso Transmission (AT/MT) & Driveline 1 01-04-2009 12:36 PM
avcs work on wrx heads? Red_Wrx Built Motor Discussion 2 03-24-2008 10:05 PM
legacy axles work in wrx? awd1320 Transmission (AT/MT) & Driveline 4 05-09-2003 01:52 AM
