Old 02-10-2014, 10:46 AM   #326
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
These are sand cast prototypes. The final product will have a better finish and use a somewhat different process (I don't want to give out all our secrets . It will be made from 347, which is commonly used in casting processes as it is another version of 304 that is alloyed with titanium VERY similar to 321. So similar in fact, when welding 321 you use 347 filler rod
KillerBMotorsport is offline   Reply With Quote
Old 02-10-2014, 10:47 AM   #327
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by A-man07 View Post
^^^That does look better. Schwing!
Thanks!
Old 02-10-2014, 05:23 PM   #328
gtasti
Member#: 152036
2004 Sti
I think being one of the first to use your killer header I should be the first when the next one comes with the killer collector gezzuss
gtasti is offline   Reply With Quote
Old 02-13-2014, 02:50 AM   #329
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
Any idea when those will be available? And how do the current collectors compare?
TROLL is offline   Reply With Quote
Old 02-17-2014, 08:23 PM   #330
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Maybe I missed it somewhere in the thread, but why does the O2 sensor mount towards the inside, unlike the stock one that points to outside?
Is it maybe so you can leave header/02 sensor in when pulling the motor? Thats only thing I could think of.
bswilmington is offline   Reply With Quote
Old 02-17-2014, 09:20 PM   #331
elevenbravo
Member#: 372475
2015 STI
CWP
I too am interested to know this. I'm assuming its a new version of the header?
elevenbravo is offline   Reply With Quote
Old 02-17-2014, 09:36 PM   #332
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
I was able to finally tune my 6466 setup in my 2012 STI this past weekend using the KB header.... Speachless.. My 6466 in 4th gear makes 20psi by 4100rpm
Car also put down 622whp on 33psi on the mustang dyno, a 2013 stg2 + tmic wrx I tuned directly before made 265-270whp/290ftlbs maxing out the fuel system just to give an idea of how the dyno reads.
Junior2JZ is offline   Reply With Quote
Old 02-17-2014, 09:45 PM   #333
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by Junior2JZ View Post
I was able to finally tune my 6466 setup in my 2012 STI this past weekend using the KB header.... Speachless.. My 6466 in 4th gear makes 20psi by 4100rpm Car also put down 622whp on 33psi on the mustang dyno, a 2013 stg2 + tmic wrx I tuned directly before made 265-270whp/290ftlbs maxing out the fuel system just to give an idea of how the dyno reads.
She's gotta feel good Jr! What did you make on pump gas? What CR and cams are you running on that motor? Head games heads?
Old 02-17-2014, 09:55 PM   #334
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Nice to see KB is working on that merge. That was my major concern with this header.
All4bSpinnin is offline   Reply With Quote
Old 02-17-2014, 10:01 PM   #335
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Stock compression with Headgames pocket ports and GSC s2 cams.
Car makes like 430-440 on pumpgas settings
I almost forgot the pics lol
The header/pan
The car
Old 02-17-2014, 11:12 PM   #336
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Single walbro 450? On e85?
Stock compression with Headgames pocket ports and GSC s2 cams. Car makes like 430-440 on pumpgas settings I almost forgot the pics lol The header/pan The car
spoolinsti05 is online now   Reply With Quote
Old 02-17-2014, 11:49 PM   #337
idratherbesurfing
Member#: 282972
2006 Sti
cgm
This is disgusting. Hahah 600+ love to see the video
idratherbesurfing is offline   Reply With Quote
Old 02-18-2014, 09:49 PM   #338
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You're not the first to say this!
Right now we're looking at mid-May. Although, we've got a 20+ backorder list going so 'stocked' availability will be later depending on how big the backorder list gets.
Using casting technology you can do things that just can't be done effectively by cutting and forming tubing. The gas flow will be smoother, less turbulent, a true high-velocity merge.
When you visualize gas flowing through a tube, picture it as water. You launch a slug of water into a bent tube and it flows mostly along the outside of the bend. Gasses do the same thing; highest velocity/energy is off center favoring the outside of a bend. Even when there are two bends with a short straight between them the energy continues to travel off-center. So, to make a short story long... placing the sensor on the inside of the bends causes the least flow disruption/turbulence while still providing proper feedback. An inconvenience, yes. An uncompromising approach for maximum performance, definitely.
Not a new version per say, the layout is near identical. The collector design is just changing some.
Awesome news Jr! I've got to get up your way soon.
Major concern?
The header/pan
Nobody look at the 2-bolt flange... yet
Old 02-18-2014, 09:53 PM   #339
Chasewrx
Member#: 290616
You're switching to a 2-bolt flange??
Chasewrx is offline   Reply With Quote
Old 02-18-2014, 10:24 PM   #340
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ No, but it is something we may offer.
Old 02-19-2014, 08:32 AM   #341
gtasti
Member#: 152036
2004 Sti
Old 02-19-2014, 01:27 PM   #342
JJ_Patterson
Member#: 99974
2006 WRX wrb
2011 STI 4door pbp
I'm ready for that 2 bolt
JJ_Patterson is offline   Reply With Quote
Old 02-19-2014, 02:34 PM   #343
bswilmington
Member#: 217563
You not the only one.
Old 02-19-2014, 04:43 PM   #344
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I though 4-1 is mostly ideal for all motor nitrous setups
It looks cool for sure. How's it sound any clips?
Old 02-19-2014, 04:49 PM   #345
pux888
Member#: 8356
02 STi swap
12 WRX limited
Id appreciate a 2 bolt option as well. It may not be optimum, but for where my car is currently and is going, will be an acceptable
compromise.
pux888 is offline   Reply With Quote
Old 02-19-2014, 05:07 PM   #346
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
What kind of genius started that propaganda?
Search is your friend. Many, many, clips floating around.
Old 02-19-2014, 05:09 PM   #347
manitou
Member#: 193757
2006 XTI Limited
What....really?
Here's what they sound like launching my XTI at 25psi with my ST muffler EWG exhaust!
Old 02-19-2014, 05:10 PM   #348
manitou
Member#: 193757
2006 XTI Limited
Haha, you beat me to it but i shared my video clip.
Old 02-19-2014, 08:15 PM   #349
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
What kind of genius started that propaganda? Search is your friend. Many, many, clips floating around.
Just what I herd man. I didn't say it did. I said I thought!
As far as searching shouldn't it be here on the first page or do you not care to sell them that much?
Old 02-19-2014, 08:30 PM   #350
toph
Member#: 78640
14 KTM SuperDuke
15 STi CWP | 02 STi Wagon
20+ on back order sounds like they're selling just fine. And in the first post there are clips. I know it's hard for your ego to admit you sound like an idiot without a rebuttal, but just let it go.
toph is offline   Reply With Quote
Killer B Motorsport Header - Prototype Testing KillerBMotorsport Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 183 11-27-2012 09:10 AM
Killer B Motorsport - HOLY HEADER / Up-Pipe Released! KillerBMotorsport Vendor Announcements 52 03-17-2011 02:34 PM
Killer B Motorsport HOLY HEADER Group Buy KillerBMotorsport Vendor 'Group Buy' Classifieds 35 06-25-2010 02:18 PM
Vf48 Turbo (18g killer?) w/ WRX Install Results P&L Motorsports Inc. Engine/Power/Exhaust 5 03-25-2008 06:41 PM
