Old 11-15-2010, 12:17 AM   #76
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by Homemade WRX View Post
VE is simply equal to the volue of air that is drawn into the engine vs the actual volume of the engine...
VE = actual intake volume / displacement volume
Agreed.
Old 11-15-2010, 03:22 PM   #77
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
You guys are right... I wasn't thinking of VE but rather combustion efficiency.
So the question still stands... why was a/f that far off between tests?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 11-15-2010, 04:13 PM   #78
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
So then look at the plots and logs of a tuned setup before and after RIGHT HERE.
KillerBMotorsport is offline   Reply With Quote
Old 11-15-2010, 04:36 PM   #79
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I was going to say that you were describing something much closer to that...
it's all good.
Old 11-15-2010, 05:25 PM   #80
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
-- Ed
probably cause cobb doesnt have OTS maps for a K&N typhoon intake.....
my scalings of an AEM vs K&N Typhoon dont line up at high MAFv.
its probably a combination of the MAF scale being off slightly and the tune sweeping through different (higher) load cells with the header.
Or there was a leak......but the only place that would cause you to run lean is a leak in the turbo inlet hose.
Another possibility is that the IAM was still at 0.5 on the "stage2 with oem header" pull causing the use of the failsafe fueling table which is richer.
Or, they could have just plotted up the wrong car. The name is different on that car......and the date is 5 days prioir while all the other dates and names are the same.
Old 11-15-2010, 08:03 PM   #81
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Killer B,
Any chance you could design another header with smaller runners? The runners seem to look big in all of the pictures and the collector seems like it would be very turbulent.
Those 4 large pipes flowing into a smaller pipe... i guess that makes sense if you were trying to create velocity... the header still seems to have a decent bit of lag down low.
Have you tried using smaller pipes? any other designs such as the factory JDM header? I know that this style has been done numerous times but if you could use the material you currently are using, make a good alternative that doesnt lag and sell it for less than 700-900$ then you may be on to something... of course, thats if its even possible.
All4bSpinnin is offline   Reply With Quote
Old 11-15-2010, 09:24 PM   #82
Homemade WRX
Member#: 33782
96 bastard child
Originally Posted by All4bSpinnin View Post
Killer B,
I can't comment on their design tests and exacts, however the runners don't look large by any means and the collector is fine in design. The theory and design is sound. I take it you haven't done a lot of manifold design work...?
Old 11-15-2010, 09:44 PM   #83
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Killer B,
^ So you want a 10 year old design based on the 2.0 motor that uses more material that costs twice as much as 304 but you want to pay half as much
There are certainly headers out there with smaller primaries and larger ones. You start playing with simulation software and you find what diameter works best for the goals you have. For us it was OEM location turbos. Our primaries are 1.50 ID.
As far as the lag it's 250-150 RPM then crosses and makes a higher peak. Is that laggy? Compared to a lot of headers that have long primaries this is much better (since longer primaries = more volume to pressurize).
Old 11-21-2010, 11:12 PM   #84
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Old 11-22-2010, 02:41 AM   #85
SlowImport
Member#: 123720
2003 WRX Wagon
Platinum Silver Metallic
Dang, I wish I had the cash to do a direct comparison between my Maddad EL header with their 45mm uppipe and the KillerB setup.
Looks like a quality part, and I love the way EL headers sound on the subarus.
Nice work guys!,
Josh
SlowImport is offline   Reply With Quote
Old 11-22-2010, 08:13 AM   #86
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ I can tell you how that would go but I keep saying, it's not all about power for our products. Reliability, crack free, leak free, etc., etc... Essentially bang for the buck, and a product that will outlast the car.
We like to think the quality matches our other products, and love the sound too
I still have people tell me they don't like EL headers because it makes the car sound like a Honda, and come to find they've never actually heard a Subaru with an EL header.
Thanks for the kind words!
Chris
Old 11-22-2010, 09:30 AM   #87
Homemade WRX
Member#: 33782
96 bastard child
EL subies sound sexy. They start to sound Porsche'ish...kinda. But still too throaty to ever be compared to a Honda.
Old 11-22-2010, 06:04 PM   #88
Chuck H
Member#: 20442
I'm curious how much of the lag could be eliminated with ceramic coating and/or heat wrapping. The hotter you can keep the exhaust gasses, the higher velocity they have, and the faster they'll spool the turbo.
I can't wait to see the results with the SwainTech coated header. I've used them in the past on a non-Subaru and their coating is VERY good and makes a huge difference in how much heat the pipes conduct. Compared to more traditional coatings like Jet-Hot, the SwainTech stuff is night and day better, although you do pay quite a bit more for it.
Chuck H is offline   Reply With Quote
Old 11-22-2010, 06:23 PM   #89
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ I'm a big proponent of Swaintec coatings as well. If there was a larger window of opportunity I would have gone that route for the prototype. Both of the cars in the videos are wrapped, but this winter when the guinea pig is down I'll have the Killer B header/up Swaintec coated.
Old 11-26-2010, 12:36 PM   #90
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the PMs guys!
We really appreciate all the questions, comments, and compliments. It's been years since a ground-up design has come out and we're very proud of the results we've been getting. Almost a full year of design, software simulations, and testing have made the wait worth it Thanks for the support!
Old 12-04-2010, 08:14 PM   #91
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Correct,
I am not a designer and am by no means bashing the manifold... its a quality piece. Just from "looking" at the pictures and comparing this with all of the different headers I have installed in the past it these were just a few things I noticed. Thanks for your input
The most of the same things that were true 10 years ago are still true today. With most headers on the market all each company is doing is re-inventing the wheel so to speak. Your header is a bit different and I commend you guys for that. Its definitely not a new design but the materials used are nice the the quality so far is really good as well.
There will be a bit of lag... as you said, longer primaries take more to fill. I would like to see this manifold design tested against a perrin/amr/maddad,etc... Also, for most upgraded turbo wrx's and sti's this may be a better choice vs the brands mentioned above for the top end.
I'll keep following this thread and am by no means bashing... just thinking out loud.
It sounds like a real suby should!
Keep up the good work
Old 12-04-2010, 08:56 PM   #92
berdugo
Member#: 163108
07 EuroDM STi 2.5L
great video and I love the sounds
I'm not a fan of the rumble sound of Subaru UEL exhaust manifold
berdugo is offline   Reply With Quote
Old 12-04-2010, 11:20 PM   #93
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks guys!
I'm not a fan of the UEL manifold either, even when I had my old GPMoto on there it just sounds better. To me, the sound of the OEM manifold (or UEL headers) is the sound of inefficiency. You don't hear a Porsche with the same engine layout making that burble, and there's a good reason for that.
Old 12-04-2010, 11:41 PM   #94
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Thanks guys!
I agree about UEL and inefficiency
Old 12-21-2010, 09:13 AM   #95
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Someone asked for a clip with a louder cat-back... Thanks to the guys at YimiSport we now have one
Old 12-30-2010, 02:38 PM   #96
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
An how we're tying the header into the NEXT PROJECT
Old 12-30-2010, 05:02 PM   #97
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Thanks guys!
I'm just throwing this out there, but can't you argue that the Porsche has a different manifold design/displacement that gives it a totally different sound than a a 2.5L 4-cylinder?
Subian is offline   Reply With Quote
Old 12-30-2010, 06:06 PM   #98
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Displacement doesn't change the "burble". If it did a 2.0 WRX would sound different from a 2.5 WRX/STi.
Porsche does have a boxer engine and thier manifold has similarities, but the firing order is different, which would make our OEM headers sound completely different, more like an EL. Because of our firing order we have to tie ports from the 2 heads together to get the same effect, EL.
Old 03-27-2011, 05:53 PM   #99
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Just an FYI on our header. V2 now is available and has extra clearance around the oil filter.
Old 03-27-2011, 09:35 PM   #100
gtasti
Member#: 152036
2004 Sti
anyway to change out the V1 header for the V2
gtasti is online now   Reply With Quote
Killer B Motorsport Header - Prototype Testing KillerBMotorsport Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 183 11-27-2012 10:10 AM
Killer B Motorsport - HOLY HEADER / Up-Pipe Released! KillerBMotorsport Vendor Announcements 52 03-17-2011 03:34 PM
Killer B Motorsport HOLY HEADER Group Buy KillerBMotorsport Vendor 'Group Buy' Classifieds 35 06-25-2010 03:18 PM
Vf48 Turbo (18g killer?) w/ WRX Install Results P&L Motorsports Inc. Engine/Power/Exhaust 5 03-25-2008 07:41 PM
