Old 04-06-2011, 03:03 PM   #126
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Originally Posted by Phatron View Post
cant find anything on txs' site....
gotta save those links so you dont have to search again
The first link below is a pdf of Turbo XS that has info about the adapter. The second link is the link for the one that KillerB posted a picture of. Also, a shop in CT that i know the owner created one for a twinscroll Gt30R for a customer very similar to this but for twinscroll. With this option i should sale my FP Red that i just got rebuilt and get a rotated 35R, downpipe and rotated intake and go rotated for good.
http://www.turboxs.com/shop/attachme..._attachment=15
http://www.iwsti.com/forums/engine-p...-adaptors.html
Wil
wil06STI is offline   Reply With Quote
Old 04-06-2011, 10:35 PM   #127
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Yep. Sti-lin also makes them with and without EWG too.
KillerBMotorsport is online now   Reply With Quote
Old 04-06-2011, 10:36 PM   #128
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I think Greddy makes one too. Or, they did for a while.
Old 04-06-2011, 10:58 PM   #129
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I think that for the cost of those flanges and the labor to weld it up, you might as well just have a rotated uppipe made.
aboothman is offline   Reply With Quote
Old 04-07-2011, 08:29 AM   #130
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
For me is probably better to buy this because i have an APS headers and the only way i can get and uppipe to work with a T3 will have to be custom i think. But if you have a regular two bolt flange uppipe you can probably buy an uppipe for the same price that this part will cost. So it depends on what you have.
Old 04-07-2011, 04:10 PM   #131
blue_wrx_chic03
Member#: 34519
03 WRX
WRX blue
i saw the price and it is not bad considering how good it looks. i was thinking of making my own but after i saw how nice it looks i think i will just save my time and troubles and buy one.
blue_wrx_chic03 is offline   Reply With Quote
Old 04-09-2011, 12:31 PM   #132
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I would buy the adapter too. Plus they are available with and without EWG too
Old 09-16-2011, 12:00 AM   #133
GuamSTI
Member#: 210071
04 STI
I have a stock exhaust manifold, i think a stock up pipe. Stock Turbo, catless DP and invidia n5 catless race exhaust. I am running an OTS Cobb stage 2 map and an SPT intake. If I buy your headers what things would I need to change?
P.S. I am running your oil pan and oil pick up such great products.
GuamSTI is offline   Reply With Quote
Old 09-16-2011, 09:04 AM   #134
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Our header includes the manifold and up-pipe. It comes with the v-band clamp, but for the install you would need to provide the gaskets and if you had any frozen turbo studs you might want to grab some of those too.
If you are running a thicker radiator you'll need to trim a plastic boss off the radiator fan shroud (I'm told they are used on the auto), but everything else fits no problem.
We've been having trouble keeping these on the shelf and right now we are waiting on stock to come in from the mill (321 stainless is not run very often), so there is ~4 week wait time and there's already a list started.
Old 09-16-2011, 12:44 PM   #135
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
Hey KillerB, for a VF turbo setup like above is your header/uppipe an appropriate choice, or is it sized & intended for bigger turbos? Seems the VF turbos are easy enough to max out on the top end, and if going bigger on the headers loses a little spool I imagine the gains could be a wash.
northman is offline   Reply With Quote
Old 09-16-2011, 01:28 PM   #136
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Absolutely. The header was designed for OEM located turbos, including the OEM VFs. Obviously the turbo size is what determines maximum power, but if you are tuned you should gain spool.
Here's a car that went from almost stock (cat-back) to a stage II+ our header. As you can see the power down low increased significantly, as did power everywhere in the rev range. On the street the responsiveness was night and day.
Old 09-16-2011, 04:16 PM   #137
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
not denying what you are saying, but there is a big difference between a tuned car and an untuned car, with no header swap, so it is a hard sell to place all the gains due to the header.
I would like to see the same comparison with a tuned stage 2 vs a tuned stage 2 with header, anything like that in your archives?
Old 09-16-2011, 07:44 PM   #138
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
What I was trying to point our was the responsiveness compared to the OEM UEL manifold. Many have been misinformed that you loose low end going with EL, which the graph obviously disputes.
Here's a graph I found real quick. It's same year, same mods different cars different day (5 days apart) and both with OTS stage II tune. The only difference was the Killer B Header.
I could not find a tuned vs. tuned with the OEM VF turbo (only aftermarket turbos), but I did find one with OTS vs tuned. It definitley shows how much Cobb's OTS maps have improved since the early days.
Old 01-24-2012, 08:14 AM   #139
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I was recently asked if anyone else had tested these headers on an aftermarket turbo. Here is a test and review by YimiSports with a Synergy Turbo TD06-20G 8cm...
LINK TO REVIEW
and to those that only care about plots...
Old 01-24-2012, 10:39 AM   #140
DroppedClutch
Member#: 52313
2005 STiOmgWtfBbq20G
2007 MS3 Black
Hmmmm... With the Cosworth cams my low-end torque is weaker than anticipated, looks like this might be a good option to help right that.
DroppedClutch is offline   Reply With Quote
Old 01-24-2012, 10:42 AM   #141
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Make it happen old man. I'm looking to get one as well.
Bishop is offline   Reply With Quote
Old 01-24-2012, 11:11 AM   #142
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We finally have some decent pics too...
Old 01-24-2012, 12:30 PM   #143
Bishop
Member#: 59993
Ass, grass or cash
Very nice!!
Old 01-24-2012, 01:43 PM   #144
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
The headers look nice and seem to perform pretty well....The gains across the powerband seem to be pretty consistant....Just makes me wonder how much better the gain would be on a decent size turbo, say a 35 or 37r....It would probably be pretty considerable....
jdpsearcher is offline   Reply With Quote
Old 01-24-2012, 03:47 PM   #145
gtasti
Member#: 152036
2004 Sti
did the design change from the first batch seems like it did a bit collector looks smaller now
gtasti is offline   Reply With Quote
Old 01-24-2012, 04:00 PM   #146
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Trimmed a tiny bit from the length where it's formed round to match the secondary, but besides than nothing else has changed. Good eye!
Old 01-24-2012, 04:16 PM   #147
gtasti
Member#: 152036
2004 Sti
whats the benefit of this more space ?
Old 01-24-2012, 09:20 PM   #148
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ yes a tiny bit more.
Old 01-26-2012, 11:00 AM   #149
3MI Racing
Member#: 200987
TIC and I still want large diameter versions
Chris, do you plan to do this anytime soon or want to guinea pig? Or should I just go ahead and bite the bullet and do it myself?
3MI Racing is offline   Reply With Quote
Old 01-26-2012, 11:27 AM   #150
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No plans for that. While it does increase low RPM VE/scavenging, I've never seen a large diamater setup that carries that power up high into the revs. Not dropping names, but the popular one right now has big torque and then dies. It's become popular because of the torque gains, but I don't know anyone who likes shifting at 5,000 RPMs to 'stay in the power'. From what I've seen total area gained unter the curve is not stellar.
With a larger turbo, smallish A/R, and relatively low boost maybe that power band creeps upward, but I don't see it being maintained anywhere near the 8,000+ RPMs where you guys are considering.
Just my opinion of course
We can certainly talk about rights to the design or how to work around the details of the patent. Physically, going to larger primaries/secondaries will push the header forward to maintain proper bend radius, plus the collector length grows too. On GDs there's little-to-no room to spare, but on GRs it may be doable.
Killer B Motorsport Header - Prototype Testing KillerBMotorsport Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 183 11-27-2012 09:10 AM
Killer B Motorsport - HOLY HEADER / Up-Pipe Released! KillerBMotorsport Vendor Announcements 52 03-17-2011 02:34 PM
Killer B Motorsport HOLY HEADER Group Buy KillerBMotorsport Vendor 'Group Buy' Classifieds 35 06-25-2010 02:18 PM
Vf48 Turbo (18g killer?) w/ WRX Install Results P&L Motorsports Inc. Engine/Power/Exhaust 5 03-25-2008 06:41 PM
