Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 11-06-2010, 04:00 PM   #1
sk8dc10
Member#: 259786
Chapter/Region: HIIC
Default 2011 STi head unit w/o nav RCA PORTS?
I was wondering if any of you 2011 guys have taken apart the stock head unit withOUT navigation.
Are their any RCA ports on the back?
The stock sound system is alright but alittle bit more wouldn't hurt. =]
sk8dc10 is offline   Reply With Quote
Old 11-06-2010, 08:28 PM   #2
tkturboh4
Member#: 145213
2004 WRX Wagon 5spd
Pop the bezel off, unscrew the headunit and look and let us know.
I seriously doubt that it does. If you are planning to upgrade your system, a headunit should be on the top of that list anyway. The stock speakers are a LOT better than they used to be.
tkturboh4 is offline   Reply With Quote
Old 11-06-2010, 08:42 PM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
No, it won't have aftermarket RCA outputs. VERY VERY VERY VERY few OEM head units have outputs.
What are you attempting (or wanting) to do?
Audiosavvy is offline   Reply With Quote
Old 11-06-2010, 09:12 PM   #4
sk8dc10
Member#: 259786
I took off the radio bezel and removed the four screws and the 2011's do not have any RCA outputs on the back I'll post pics later of the back of the unit.
I'm trying to put a system in my car. Just one 12" subwoofer.
Old 11-06-2010, 09:15 PM   #5
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Then you'll need just one LOC (line-out converter). I always like the SNI-35 from PAC. It has adjustable gains (to lower the sensitivity for more flexibility with amp adjustments).
You'll want a wiring harness for an aftermarket stereo (70-8901 from Metra for most Subarus) and a reverse harness (71-8901 if the previous one works). They will both wire up color-for-color, and you can tie the LOC into the rear speaker wires (green/purple) and the turn-on wire into the Accessory wire (red). It will all be plug-n-play at that point and you'll never have to cut a factory wire
Old 11-06-2010, 10:01 PM   #6
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
sk8dc10 has the non-nav HU, so his Impreza has the newer 20-pin radio harness. So Audiosavvy's wiring tips apply, but you need to use different harnesses (not the 7x-8901).
See my pin-out here.
I now have combined 20-pin forward/reverse harnesses with most or all of the pins connected straight through. Great for adding an amp and/or sub. See my homepage (click on my username).
SVXdc is offline   Reply With Quote
2011 stock head unit wiring question subiebosch Car Audio, Video & Security 10 10-08-2010 09:21 AM
WTB : 2007 STI head unit with Aux Port jmacdonald801 Private 'Wanted' Classifieds 0 07-08-2010 07:15 PM
Cheap head Unit & pioneer Nav. Hoak Interior/Dressup/Audio & Security 0 10-01-2008 10:56 PM
2007 STi Head Unit + AUX port iDRIVElikeAmadman Interior/Dressup/Audio & Security 6 05-14-2008 03:15 PM
Stock head unit, does it have RCA outputs? obxtoy Car Audio, Video & Security 3 07-21-2005 11:17 AM
