Old 11-06-2010, 07:17 PM   #1
nomas81
Member#: 262602
2010 impreza 2.5i
black
Default Im looking for some help with picking the proper Cold Air Intake
which cold air intake do people recommend for a 2010 impreza 2.5i wagon?
I've been looking at:
AEM
K&N
and Perrin.
I'm not sure which one would fit. If anyone has a descent cold air intake on their impreza 2.5i please let me know.
Thanks.
nomas81 is offline   Reply With Quote
Old 11-07-2010, 01:59 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
424wrx is offline   Reply With Quote
Old 11-07-2010, 03:29 PM   #3
SUBIESROCKUKNOW
Member#: 214464
2008 Impreza 2.5i
Satin white pearl
i got a cosmo racing CAI on my 08 2.5i i just painted it blue 2day..
SUBIESROCKUKNOW is offline   Reply With Quote
Old 11-07-2010, 10:08 PM   #4
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
AEM
K&N
and Perrin.
Thanks.
Do yourself a favor and read the CAI/SRI sticky in the Naturally Aspirated forum. CAIs and SRIs let in way too much air for the car and tend to make you run lean. The ECU cannot adjust the air/fuel mix sufficiently and you end up with too much air in the mix. Think about getting a tune to help deal with the extra air if you really want an intake.
The stock intake is already very efficient, and it's also a CAI already. It takes air from the leading edge of the hood. Save you money and go with a decent panel filter. I use the AVO one.
Ogden is offline   Reply With Quote
Old 11-08-2010, 10:39 AM   #5
08imprezahatch
Member#: 247867
08 2.slow
Default stock intake
I could be wrong, but I have heard many times that the stock Subaru intake is very restrictive. Its just with the MAF sensor that readings are thrown off and your car will run super rich below 1000 rpms because the ECU is massively over-estimating the amount of air entering your car.
I was under the impression that with a tune a SRI or CAI could net some decent power gains at higher rpm's (and maybe a loss at lower rpm's).
Thoughts?
And I've heard that the cosmo CAI fits but rubs uncomfortably close to some things. The AVO intake seems like a good bet to me.
08imprezahatch is offline   Reply With Quote
Old 11-08-2010, 01:49 PM   #6
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
I'm nto sure that anyone with an AVO has posted their impressions yet. One member with a Cosmo got his car tuned and discovered that he is running lean. Too much air for the ECU to adjust for.
Read the sticky at the top of the N/A sub-forum. For the 08+ cars, the intake is pretty efficient and sized well for the car (and draws cold air from outside the engine compartment). The only real losses seem to be from the corrugated part of the tubing, which is why folks have come up with a "hybrid" intake that keeps most of the stock intake, but replaces that corrugated section with metal tubing.
You may get power gains (and possibly low-end losses) but, IIRC, the problem is that it lets in too much air for the stock tune to handle. If you want an intake, I would get the intake, get the exhaust you want, put them on the car, and then have it tuned.
Old 11-08-2010, 09:32 PM   #7
nomas81
Member#: 262602
2010 impreza 2.5i
black
Default thanks
thanks for the thoughts.....ideas....and comments.
Old 11-09-2010, 01:27 AM   #8
nairbmik
Member#: 220259
09 2.5i
SSM
Intakes are an absolute waste of money if you're not going to get a tune to go along with it.
Why? Simply put, without a tune the car runs like absolute crap. You'll gain very very small HP numbers, and for the cost of $125+, it's just not worth it.
nairbmik is offline   Reply With Quote
Old 11-10-2010, 01:00 PM   #9
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
i got the cosmo racing intake
thegonz is offline   Reply With Quote
Old 10-07-2011, 11:17 AM   #10
kaja
Member#: 289632
2011 WRX STI
Plasma Blue Pearl
Default Cold Air Intakes
So, it is recommended that if you are planning to add a cold air intake, you should also plan on changing your tuning? Will you see a benefit without changing your tuning? Do you need to upgrade your exhaust as well?
I have a 2011 STI. If I changed to a CAI, what can I expect in terms of additional power? What happens to your mileage?
kaja is offline   Reply With Quote
Old 10-07-2011, 01:28 PM   #11
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Kaja,
I'd ask that over in the engine/exhaust forums. This thead was started with a question about an intake on a non-turbo Impreza. Very different animal than your STI with very different schools of thoughts on intakes and exhausts.
You will eventually get the answers you want here, but you will get them faster in the other forums where I'm sure that your question has been answered already for the 08-10 STIs which will continue to apply to the '11 models. Good luck!
Old 10-10-2011, 03:17 PM   #12
kaja
Member#: 289632
2011 WRX STI
Plasma Blue Pearl
Will do, thanks.
Old 10-10-2011, 07:56 PM   #13
RedDragon08
Member#: 231422
2008 Impreza WRX
Red
I'd go with the K&N
RedDragon08 is offline   Reply With Quote
cold air intake..to but or not to buy pjloyd Newbies & FAQs 4 05-04-2009 05:38 PM
which cold air intake? Evo killerz Newbies & FAQs 44 09-16-2008 09:36 PM
Which Cold Air Intake??? Dirtrider12 Newbies & FAQs 7 02-19-2007 05:22 PM
which cold air intake is the best? chris-man Newbies & FAQs 14 07-05-2005 04:07 PM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
