Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-07-2010, 03:46 PM   #1
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Default Screw Thread patterns
I am finally working on a lathe in my major (Automated Machining Engineering) and want to try my hand at making a few shift knobs, as well as a new short throw shifter. However I don't have the size of thread I need for either.
So if someone can supply me with the following:
- Thread for the shifter knob/short throw shifter
- Size of the pivot ball of the shifter
- Depth of the threading for the shifter
I know I know, I have a shifter outside so you must be wondering why I have to ask. The previous owner bought a shifter that wasn't the right thread pattern so he decided he would crank it down as hard as he could till it would hold, needless to say it spins, wont come off, and the threads are destroyed. So I need to start from scratch with making this.
**JUST ADDED**
I want to make some knobs for some buddies.
- I just wanted to verify the M12x1.25 thread was the same for the 2.5rs and 2.5i 5MT?
- What are the dimensions of the boot collar?
- The WRX shifter and WRX Short Throw shifter both have the same thread correct?
subaru_steve is offline   Reply With Quote
Old 11-07-2010, 05:20 PM   #2
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
I believe the shifter is the same as the lug studs. To be sure try screwing a lug nut on the shifter. 12x1.25 should be right.
To measure the depth of the shift knob just remove the knob and stick a pencil in it. Make a mark when you bottom out. Pull out the pencil and measure from the end to the mark that you just made. Should give you a pretty accurate depth measurement.
Hope this helps.
2006whitesti is offline   Reply With Quote
Old 11-07-2010, 05:23 PM   #3
Member#: 67
1999 Outlasting
the competition.
- Thread for the shifter knob/short throw shifter 12X1.25mm
- Size of the pivot ball of the shifter ~19mm
- Depth of the threading for the shifter All depends on how big the shift knob is. roughly 30mm?
Old 11-07-2010, 05:38 PM   #4
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Hope this helps.
Like I said, can't really take it off and see since its A) Stuck and B) threads are destroyed, haha thanks though
Awesome, thank you!
Old 11-08-2010, 09:55 PM   #5
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Read "Just Added" Thank You!
Old 11-16-2010, 06:46 PM   #6
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Bumpedy Bump
Old 11-17-2010, 08:20 PM   #7
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Anyone have the "Just Added"? Need the Collar Dimensions
Thanks!
Old 11-17-2010, 10:37 PM   #8
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
standby
Here's roughly what I used:
for this:
tobylazur is offline   Reply With Quote
Old 11-17-2010, 10:56 PM   #9
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
^ Thanks Man!
I saw a post of your shift knob somewhere on this forum, I just don't have a shift knob with the boot collar, helps a ton man!
Old 11-17-2010, 10:58 PM   #10
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
no problem. You're just lucky I already had the drawing done. Let us know how it turns out.
Shifter thread patterns!!! WRXDriftR Interior & Exterior Modification 2 08-03-2005 11:53 AM
Correct thread pattern? imprezive Brakes, Steering & Suspension 2 10-09-2002 09:59 AM
Oil filter thread pattern? Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 5 05-26-2002 02:08 PM
thread pattern of engine oil plug inpreza kid Normally Aspirated with bolt-on Forced Induction Powertrain 12 02-05-2002 10:16 PM
thread pattern atcvader Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-10-2001 06:10 PM
