Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-19-2014, 06:56 PM   #401
rex864
Member#: 371854
2014 WRX
Originally Posted by a10495 View Post
hey guys! new to the forum and recently just got a 2014 wrx sedan ! i am not liking these stock headlights so i am going to try this h9 mod. anybody can recommend any brands for the headlights?
links to them would be appreciated! thank you!
-sorry for the edit. but where exactly did you guys file down on the H9 bulb??
did you add the HID kit on the stock Halogen headlights? or did you retrofit them? really considering of doing a PnP kit like you said you did if it doesn't blind anybody .
for the h9 bulb the little tab inside the bulb the one closest to the bulb it self is the one that needs to be filed down.. If you take your h11 bulb out and hold them side by side you will see it .
rex864 is offline   Reply With Quote
Old 02-19-2014, 07:16 PM   #402
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
BWX is offline   Reply With Quote
Old 02-19-2014, 08:14 PM   #403
OrangeRU
Member#: 380700
Hey all quick question, I saw an earlier post saying no one has experienced any burning or overheating yet but has anyone running the 65w H9’s for a while with painted headlights seen any damage to the painted areas?
OrangeRU is offline   Reply With Quote
Old 02-20-2014, 01:10 AM   #404
rex864
Member#: 371854
2014 WRX
I don't Have painted headlight ( I wish I did ) but I have read a lot on the lighting and I have never seen anyone with a issue. Go to the picture part and find people with painted headlights and pm and ask..
Old 02-20-2014, 02:34 AM   #405
Kuros
Member#: 328669
2011 STi boosted FRS
04 sti
I prefer duct taping 2 flashlights to my hood. That way i dont have a bunch of wires to worry about.
Kuros is offline   Reply With Quote
Old 02-20-2014, 04:17 PM   #406
rex864
Member#: 371854
2014 WRX
Are they LED so they last longer? I would be a rebel and use old school flashlights and make the beam pattern different!
Old 03-09-2014, 04:32 PM   #407
lolBBQ
Member#: 291896
'10 2.5i
FWIW I've been running H9's for the past 2 years and my passenger side just now blew. Wiring was ok so it was just the bulb(coil part split). Highly recommended if you're on the fence.
lolBBQ is offline   Reply With Quote
Old 03-09-2014, 05:16 PM   #408
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
I'm impressed that you got 2 years out of your H9's. You must not do a lot of night driving. Mine only lasted about 8 months. Still think the upgrade is worth it.
jr0bb5 is offline   Reply With Quote
Old 03-09-2014, 05:28 PM   #409
lolBBQ
Member#: 291896
'10 2.5i
Maybe I'm just lucky tho I guess 'a lot' is relative. Drive home from work is at night 5x a week about 30 mins a trip.
Old 03-10-2014, 03:12 PM   #410
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
My driver side blew out after a about a year and a half, then the next one to blow was the driver side about 6 months later.
I'm careful to clean the surface of the bulb with alcohol and canned air before I do the final installation. It is impossible not to touch it while modifying the housing. It is also surprising to see how much dirt is on the bulb right from the box, brand new. There is a layer of dirt on there that probably doesn't help with longevity if it isn't cleaned off thoroughly..
I wonder how many people accidentally touch the bulb, and never clean it afterward before installation? Anything left on the surface will blow the bulb prematurely.
Old 03-18-2014, 06:08 PM   #411
TheHunt815
Member#: 375964
2002 Wrx Sti v7 swap
Has anyone tried the led bulb conversion? wondering if this would work for those as well, since heat wouldnt really be an issue, just fitment
TheHunt815 is offline   Reply With Quote
Old 03-18-2014, 09:12 PM   #412
veener79
Member#: 204304
2008 WRX 4D Stage 2
Have not been able to find a LED bulb that has good of light output as a stock H9 bulb.
veener79 is offline   Reply With Quote
Old 03-18-2014, 09:14 PM   #413
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I am not an LED expert but an LED system with enough output to be used as main beam WILL have heat issues.
frederik is online now   Reply With Quote
Old 03-18-2014, 11:32 PM   #414
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
I'm also no expert, and fitment shouldn't be an issue. There is no difference between an LED H11 and an LED H9 (or H/900* whatever) other than the threads/adapter, so no modifications needed.
The main problem with the LED plug and play is, incorrect beam pattern/non usable light. It can't replicate what the halogen bulb does in it's reflector, so it's not a viable option.
Tha Chakal is offline   Reply With Quote
Old 04-16-2014, 10:36 PM   #415
mild7intl
Member#: 381783
2013 WRX
Plasma Blue
Is there any way to modify the female part of the h11 socket so that it can accept a h9 bulb? I don't want to go through the process of filing down every bulb... taking me quite a while!
mild7intl is offline   Reply With Quote
Old 04-16-2014, 11:18 PM   #416
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Are you talking about the "mounting socket" portion of the bulb (where it mounts to the light housing)
Or the electrical socket portion of the bulb where you have to grind out the tiny tab between the contacts?
About the "mounting socket" portion, I did not modify the bulb in any way. You can wiggle it in if you slightly angle it before twisting to lock.
About the electrical socket tab, if you don't want to modify every bulb, I think they only thing you can do is replace the H11 electrical connectors with H9 connectors. You can either cut/resolder or de-pin the H11 and re-pin with the H9. The later is probably a better option.
gsrcrxsi is offline   Reply With Quote
Old 04-17-2014, 10:20 AM   #417
dharel0bs11
Member#: 258998
2011 Outback Sport
Blue Pearl/Steel Silver
You can purchase an H11 to H9 adapter:
http://store.ijdmtoy.com/Heavy-Duty-Headlight-Wiring-and-Ceramic-plug-p/aa1024.htm
Amazon.com: 2 X H8/H9/H11 Extension Adapter Wiring Harness Sockets Wire for Headlight: Home ImprovementAmazon.com: 2 X H8/H9/H11 Extension Adapter Wiring Harness Sockets Wire for Headlight: Home Improvement
dharel0bs11 is offline   Reply With Quote
Old 04-17-2014, 11:49 AM   #418
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I would gladly take a few seconds to trim each bulb instead of adding additional resistance (and voltage drop) with additional connectors splices and solders.
Old 04-17-2014, 03:36 PM   #419
trife86
Member#: 301368
2012 WRX
PBP
Do this!
I got a similar one off eBay for like 8 bucks
trife86 is offline   Reply With Quote
Old 04-17-2014, 11:41 PM   #420
veener79
Member#: 204304
2008 WRX 4D Stage 2
Reading reviews
Not for H9
By S. Wendler on January 22, 2014
Verified Purchase
This states that it will fit the H8/H9/H11 connector. IT DOES NOT. It will fit the H8 and H11 connector, but the H9 has a slot on top and bottom, and these connectors only have the slot on one side. Unfortunately, I bought it for an H9 bulb, so this will not work.
Old 04-18-2014, 12:27 AM   #421
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
My thoughts exactly.
Originally Posted by veener79 View Post
Reading reviews
Not for H9
Verified Purchase
I just bought one out of pure curiosity.
I'll let you know if that reviewer knows what he's talking about or not.
Old 04-30-2014, 03:35 PM   #422
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I got these adapters in the mail the other day. It works fine, all you have to do is mod the one end of the adapter in the exact same way you mod the H9 bulb.. well the opposite way I guess, you just cut out the tiny piece of plastic in the plug that doesn't allow the H9 to slide on, and then you are done.
No more modding every single H9 bulb, you just mod this adapter once. It took 3 minutes. It looks pretty high quality and waterproof otherwise. I think I will use it and see how it works.
$4.19, no tax, free shipping? How can you go wrong?
Old 04-30-2014, 03:43 PM   #423
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
No hate at all, but the point is you are trying to improve lighting by installing the H9 bulbs, but at the same time you add connections and wiring which impact overall resistance and reliability of the circuit.
Increased resistance of the added connections equals voltage drop equals lumens reduction. It might not be a huge voltage drop but the lumen output decrease with voltage is not linear, more like exponential, so I prefer to err on the side of keeping/improving lighting performance. For this reason I would personally trim the bulbs and leave the wiring alone. That's what I did on my bugeye JMDs to install 9011 in place of the 9005.
Old 04-30-2014, 05:10 PM   #424
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Well I will decide whether or not I want to use them after I test them.
Old 05-26-2014, 07:15 PM   #425
a10495
Member#: 382147
2014 WRX
hmm still have yet to do this (lol) but i have a painted housing and halos. will be ordering in a bit! lol i keep telling myself i will then forget
a10495 is offline   Reply With Quote
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 09:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 09:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 07:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 02:01 AM
