Old 11-16-2013, 07:42 AM   #351
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Hard to believe these wires apparently barely get by at 65w. I have a space heater that I run for an hour or more sometimes with wires not much thicker, it pulls 1500w from the wall (AC but still) and the wire barely gets to body temperature.
goregasm is offline   Reply With Quote
Old 11-16-2013, 01:03 PM   #352
usfsfire42
Member#: 242630
.. Flu shot
technician.
Originally Posted by alt14 View Post
If it's just the connector that melted you can get replacement ones for fairly cheap, however if you want the OEM harness from what i'm to understand (I tried to get one for my 07 awhile ago) you can't buy just the harness, you have to buy the entire housing assembly it came from. They might be able to fix it for you at an outrageous price.
**** that. Hopefully I can just get the connector because I am not trying to buy the entire thing
usfsfire42 is offline   Reply With Quote
Old 11-16-2013, 05:19 PM   #353
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Yeah just look up h11 connectors on amazon or ebay, they're pretty cheap
alt14 is offline   Reply With Quote
Old 11-16-2013, 06:52 PM   #354
usfsfire42
Member#: 242630
.. Flu shot
technician.
Could I just buy the H9 connector and then I wouldn't have to file down any tabs or anything and just splice that one in?
You know instead of buying an h11 like stock and then filing down the h9 bulb to fit
Old 11-16-2013, 09:56 PM   #355
alt14
Member#: 271928
2014 WRX Limited
I wouldn't see why not, of course I'm not an electrician but they are both just 12 volt power right? As long as the wire is thick enough, just to be safe maybe put an inline fuse before the connector.
Old 11-16-2013, 10:14 PM   #356
usfsfire42
Member#: 242630
.. Flu shot
technician.
Okay. Well I just bought some cheap one from pep boys and crimped the wires together. Seems legit. Light turned on and seems alright for now.
Old 12-13-2013, 05:54 PM   #357
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
My Phillips H9 bulbs burned out after about 15 months of use. I will replace them the with same. The life isn't great, but the output is worth it.
WRXinpa is offline   Reply With Quote
Old 12-14-2013, 01:10 PM   #358
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
If you read in one of the other threads, my Philips H9 bulbs only lasted me 8 months. I do, however, drive a lot at night so I'm not overly surprised. Was hoping to get at least a year out of them. Even though I'll have to replace them more often, I'm going to continue using H9's bulbs because I really appreciate the extra light output.
jr0bb5 is offline   Reply With Quote
Old 12-17-2013, 10:11 AM   #359
wrb2013
Member#: 344486
2013 WRX
WRB duh
Sylvania h9's only 7+$ on Amazon got 2 coming $21 shipped!
wrb2013 is offline   Reply With Quote
Old 12-20-2013, 10:17 AM   #360
MatthewB10
Member#: 320973
2012 WRX
Ice Silver Metallic
I've had my H9's in for over a year now. No problems at all. Love them. I tried to put H11's back in, because that's the "proper" way of doing things, but there's a noticeable difference.
MatthewB10 is offline   Reply With Quote
Old 12-25-2013, 11:21 PM   #361
Malamule
Member#: 284884
There was a recent sleet/snow blitz here in Northern NJ, I work about an hour from home on a normal day. During this storm event, my car was covered with ice, snow, salt, you name it. In the 3 hours it took me to get home, I burnt through about a gallon of window washer fluid.
Anyway, by the time I got home, my 2008 WRX headlights were about as bright as a two candles flickering in the wind.
I've never been happy about their brightness, when you add road salt, they become almost useless.
I found this thread, and bought the bulbs on Tuesday at Autozone. I used my dremel to wipe out the tab. Slyvania H9s..about $15 each. I put them in today because I had to drive home from south Jersey(130miles) tonight.
Holy crap! It's lit up light I've the brights on, but it's my low beams! They're aimed low...I had people actually lower their brights when coming at me on rt 206, meaning I wasn't blinding them but I could really see the road!
Let there be light!
Malamule is offline   Reply With Quote
Old 12-26-2013, 09:30 PM   #362
corvid
Member#: 300097
holy hell is it taking forever to get the tab down in my Philips bulbs.
I'm thinking dremel time, which bit works best?
corvid is offline   Reply With Quote
Old 12-27-2013, 07:02 PM   #363
Scooby207
Member#: 255687
11 WRX DGM
I used 107 Engraving Cutter because it was the only accessory that came with my Dremel that worked for the job. Jumped around a lot but got it done. My friend said he used 561 MultiPurpose Cutting Bit and said it was the one to use. I'm sure there are others that would work too.
Scooby207 is offline   Reply With Quote
Old 12-29-2013, 02:26 AM   #364
WRXKBC13
Member#: 364390
2015 STI
I used the 100% transparent sylvania h9 bulbs and I didn't notice an increase in light or any slight color variance like other people are seeing. Judging by the before and after photo, they look more dim than the stock h11 bulbs. should I try the Phillips bulbs?
Also, I used a razor blade and it worked great to trim the tab.
WRXKBC13 is offline   Reply With Quote
Old 12-29-2013, 08:02 PM   #365
jr0bb5
Member#: 315353
5MT OBP/DGM
So, do any of you with the h9 conversion ever get high beamed by on-coming traffic thinking you have your highs on? I've had h9 bulbs in my headlights for over 8 months now but just recently started getting high beamed by on coming traffic when I replaced my burnt out h9's with new ones. I'm using the same Philips h9s that I used before, but now I get high beamed at least 2 or 3 times a night. I never touched the height adjustments in the headlights nor do I have anything in my truck that would cause my headlights to be pointed upwards. They're definitely brighter than the H11's but I didn't think that they would blind other motorists.
Old 12-29-2013, 11:17 PM   #366
trife86
Member#: 301368
2012 WRX
PBP
Maybe your headlights need to be 're-aimed I've been using them for over a year on my 2012 WRX and have no issues blinding others
trife86 is offline   Reply With Quote
Old 12-29-2013, 11:38 PM   #367
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
Jr0bb, are you talking about your Impreza or your truck? Most people think trucks have their highs on when they don't, so more lumens would exaggerate that perception.
Tha Chakal is offline   Reply With Quote
Old 12-30-2013, 02:12 AM   #368
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
When I first did H9 upgrade, I had adjusted my aim UP, because it was WAY too low from factory. I got beamed a few times and then adjusted it lower by a couple degrees.
You have more of a chance to glare someone because the H9 doesn't have that opaque part on top of the bulb, that helps with glare apparently. That means you have to pay extra careful attention to your beam aim. Just get up to a nice flat, level white wall, about 20 feet away.. and use some tape to mark the top of the low beam that is projected onto the wall from your low-beams. There a very pronounced horizontal cut-off.
Now adjust it so that the beam is a few inches lower on each side, but still even with each other. Now try out the lights. If it is too low, you will know.. these lights need to be aimed perfectly to get the best out of them, even with the upgrade. There is a sweet spot where they work great, and you will never get beamed from other drivers.
Just make sure to do the adjustment with a full tank of gas, and maybe some weight in the trunk and in back seat if you usually carry stuff/ have passengers.
When adjusted perfectly, your high beams work great too..
https://duckduckgo.com/?q=adjust+headlight+aim
BWX is offline   Reply With Quote
Old 12-30-2013, 02:51 AM   #369
jr0bb5
Member#: 315353
5MT OBP/DGM
My truck lol? You must be thinking of someone else. I would like to own a truck someday as a second vehicle. Maybe when the Impreza is paid off if I decide to keep it.
Old 12-30-2013, 06:52 AM   #370
Tha Chakal
Member#: 372100
Ha, read the section of your previous post I quoted, and you'll see why I thought that :-P
Old 12-30-2013, 12:38 PM   #371
jr0bb5
Member#: 315353
5MT OBP/DGM
Haha... I never even noticed that. That's supposed to say trunk, not truck. Sorry :-P
Old 01-04-2014, 10:58 PM   #372
JDHolliday27
Member#: 208688
09 GH
Just did this conversion using Philips H9 bulbs. Definitely a noticeable difference versus the OEM H11s. Much brighter and whiter. Also replaced the high beams with Philips HIR1 9011s!
JDHolliday27 is offline   Reply With Quote
Old 01-05-2014, 09:14 AM   #373
slimfit
Member#: 90597
2011 WRX Premium
^^I would disconnect the DRLs or else those HIR1s aren't gonna last too long. Happened to me after several months
slimfit is offline   Reply With Quote
Old 01-05-2014, 11:04 AM   #374
fourthbrook
Member#: 362680
2009 Impreza 2.5i
Do you have a light comparison on the 9011s. This is on my list, if the light is way better(I split, baked and painted my lights and did the high bowls too dark) .
Also why discount the drls?
fourthbrook is offline   Reply With Quote
Old 01-05-2014, 11:24 AM   #375
JDHolliday27
Member#: 208688
09 GH
Originally Posted by fourthbrook View Post
Do you have a light comparison of the 9011s. I split, baked and painted my lights and did the high bowls too dark.
I did compare both the low and high beams versus stock after I finished one side of the headlights, but unfortunately I did not take any before/after pics. However, I can attest that the HIR 9011s throw a lot more light down stream and are definitely worth the upgrade. They're also easier to modify than the H9s in my opinion.
The reason the previous poster suggested disabling DRLs is because they run the high beams at a lower wattage, which can lead to the filament burning out faster.
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 08:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 08:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 01:01 AM
