Old 11-25-2012, 07:20 PM   #201
Willy J
Member#: 338886
2010 WRX sedan
My mod was a horror story. Bought a set of H9's off ebay. One blew out in an hour. Took it out and saw that the bulb had cracked off and melted the inside of my housing. Now I gotta replace the inner housing that holds the bulb. FML
Willy J is offline   Reply With Quote
Old 11-25-2012, 08:57 PM   #202
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
cool story bro.
ChesterWRX is offline   Reply With Quote
Old 11-25-2012, 09:06 PM   #203
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
I'm curious how that happened. Did he use one of those 100w bulbs ?
gsrcrxsi is offline   Reply With Quote
Old 11-25-2012, 09:16 PM   #204
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
He bought them on eBay. Could have something to do with it. Sucks either way.
bicycle_wreck is offline   Reply With Quote
Old 11-26-2012, 12:35 AM   #205
chino_487
Member#: 209156
2009 WRX Sedan
SSM
i am thinking of going through this mod as well. just to recap, 65W bulb would be safe correct? i dont want to end up like this guy:
chino_487 is offline   Reply With Quote
Old 11-26-2012, 07:37 AM   #206
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
65 watts is fine. You can always purchase a harness
Old 11-26-2012, 09:43 AM   #207
chino_487
Member#: 209156
2009 WRX Sedan
SSM
what kind of harness? do you have a link?
thanks for your time.
Old 11-26-2012, 11:55 AM   #208
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Old 11-26-2012, 12:23 PM   #209
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
65W is perfectly fine. Again, as I stated above, I ran H9's for 2 years and my connectors look nothing like this. I kept my wiring clean and covered in dielectric grease to keep moisture (read: corrosion) away. Had no problems.
Saying this, a wiring harness, like the TRS bundle, would be great. You'll get the full voltage from the battery to your lights, which will give you that extra couple hundred lumens you lose through loss in the factory wiring harness.
P.Rico is offline   Reply With Quote
Old 11-26-2012, 02:43 PM   #210
Syndr78
Member#: 336966
2013 WRX
Satin White Pearl
Did the mod over lunchtime with the PIAA extreme whites.
I used a small flat head screwdriver which I heated with a torch to remove/melt the tab(s) away. worked pretty good.
The goof up wasthat in my haste, I initially unplugged and tried to fit the H9 in the damn High beam socket--which of is a completely different connector (ridiculous, I know).
As a result, I ended up taking BOTH tabs out from the inside of the new bulb connector, as well as the little tabs on the sides of the new bulb connector.
It still snapped into place quite snuggly--Should I have worries that removing those additional tabs is/may become a significant problem?
Syndr78 is offline   Reply With Quote
Old 11-26-2012, 04:55 PM   #211
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
http://store.ijdmtoy.com/Heavy-Duty-...g-p/aa1024.htm
this link should come up if you google "H11" or "h9" ceramic or heavy duty harness. i'm running these for my H9's. -again, not really needed but i like the extra layer of safety.
check back earlier on this thread. it was discussed (i think).
Old 11-26-2012, 04:58 PM   #212
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
i did the same thing. i broke the wrong tab on one, so i ended up just shaving both tabs inside both bulbs.
*mine are tight, and i did use the dielectric grease and my heavy duty harness are actually a TIGHT fit, tighter than the regular plug so i'm not worried.
Old 11-26-2012, 05:37 PM   #213
Syndr78
Member#: 336966
2013 WRX
Satin White Pearl
I did not use any grease--didn't have any. Is it a big deal, or not so much? Of course there was none present in stock form.
BTW--heating up a small flathead screwdriver and melting away the tab worked pretty damn good as opposed to filing/dremeling...FWIW
Old 11-26-2012, 05:54 PM   #214
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
i care more about the harnesses on my car vs. the wiring harness i linked above.
IIRC, the dielectric grease just makes it easier to remove the bulbs down the line. you can go buy some, it's less than $3 dollars for a little sleeve or tube at an auto parts store and throw it on.
-just like anti-seize on spark plugs. do you REALLY need it? i'm not sure, but it's suggested so i use it.
i'm using heavy duty harnesses on my fogs, DRL's / high beams and my low beams just in case. but i have OCD too.
Old 11-26-2012, 06:50 PM   #215
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
i dont really see how this "protects" anything. the same amount of current will be flowing though the stock harness, and hence, any heat generated will be exactly the same. unless the worry is that the heat of the bulb itself will hurt something?
Old 11-26-2012, 08:05 PM   #216
Syndr78
Member#: 336966
2013 WRX
Satin White Pearl
Well, the drive home didn't impress me like I had hoped. I guess I didn't pay enough attention to the stock light output/pattern to make a legit assesment. Oh well--I'm sure they are at least a little better...
Old 11-26-2012, 08:09 PM   #217
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
The difference is substantial. Too bad you didn't get to realize how dim the stock bulbs are, but oh well - your better off now!
WRXinpa is offline   Reply With Quote
Old 11-26-2012, 08:27 PM   #218
trife86
Member#: 301368
2012 WRX
PBP
huh? .........
ETA, take a screw driver and fish it out. if you're talking about the sleeve that makes the plugs seal tight.
Not sure if its a 'sleeve' but maybe i can fish it out, will try tommorow if not, will provide pics, BTW the UPGRADE IS HUGE, I had HIDS Before in a older car (non correct retrofit) and this blows them away no contest
trife86 is offline   Reply With Quote
Old 11-30-2012, 01:40 AM   #219
SkyeC
Member#: 94323
2016 STI
Just swapped a pair of Philips H9s in today and the difference is huge. Easily just as good lighting as most factory HID cars out there, but maybe not as good as my wife's TSX. Best $20 and 10 minutes I've ever spent on a car.
Threw yellow Nokyas in the high beams, but that was just to have yellow DRLs, not really a performance mod, though the H9+high beam combo is pretty damn bright.
SkyeC is offline   Reply With Quote
Old 11-30-2012, 12:46 PM   #220
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Nice!
Old 12-11-2012, 11:34 AM   #221
NRTmotorsports
Member#: 16517
'13 BRZ
Figured I'd jump in with my .02 as I did this mod about 7 or 8 months ago on my '09. I would recommend this to anyone, light output is so much better. I replaced my bulbs with some Phillips I bought at my local Napa. Everything been perfect since I first did this, no bulb failures or wiring harness issues. I recently unplugged the bulbs just to inspect for any possible damage. Everything perfect, one of the best mods for the money. Don't be scared doooo itttt!!!
NRTmotorsports is offline   Reply With Quote
Old 12-16-2012, 03:27 AM   #222
Sam18
Member#: 340754
2009 Impreza 2.5i
Hi guys, I'm gonna switch my original H11 to H9 this week but was wondering what bulb I should put in my fog to have the best results? Thanks!
Sam18 is offline   Reply With Quote
Old 12-28-2012, 09:19 AM   #223
J.biz
Member#: 191825
2009 WRX Hatch
Did the conversion a couple weeks ago... Light output with H9 seem to be a little brighter then my hid kit.. While driving the light output is way more focused! Very happy!
HID kit
H9
J.biz is offline   Reply With Quote
Old 12-28-2012, 07:27 PM   #224
veener79
Member#: 204304
2008 WRX 4D Stage 2
Wow great shots!
veener79 is offline   Reply With Quote
Old 12-29-2012, 09:01 PM   #225
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
1350 lumens vs 2100. Enough said.
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 08:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 08:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 01:01 AM
