Old 06-30-2002, 10:27 PM   #1
Mops
Member#: 16845
1994 Legacy RS
Navy Blue
Default legacy RS - boot (trunk) leaking
Hey all.
I own a 1994 ('95 model in US) legacy RS with EJ20 twin-turbo engine. I got small problem - whenever it rains, the carpets in my boot (trunk) are wet - and because of humididyt theres unpleasant smell. Theres quite a bit of water getting there every time it rains. I was just wondering whether anyone else had that problem and fixed it - as tere are no visible sings of where it could be leaking. Help is greatly appreciates
thanks in advance
Matthew.
Mops is offline   Reply With Quote
Old 07-01-2002, 12:03 AM   #2
The Real Oaf
Member#: 6608
1996 Legacy Outback
I have a leak-free wagon, but try this:
Using an assistant that you trust, climb into the trunk, with flashlight/torch in hand, & have the assistant close the boot.
With the assistant flooding the rear half of the car with a hose, look for leaks.
This method is the only sure way of finding the leak(s).
Paul
The Real Oaf is offline   Reply With Quote
Old 07-01-2002, 01:05 AM   #3
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
And be sure it's someone you trust!!
Glenn O
nuburu2 is offline   Reply With Quote
Old 07-01-2002, 01:33 AM   #4
sovereignmk1
Member#: 11858
1998 Silver Legacy
"HELP, HELP!!! I cant Get out!!!"
If you have the option, you can put down your rear passenger seats and slide in from the interior to watch for water.
/Mark
sovereignmk1 is offline   Reply With Quote
Old 07-01-2002, 02:29 AM   #5
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Default Another possibility
If you don't see it coming in from the top (the boot), check the fender wells on both sides to see if maybe there is some intrusion coming in there. Spray up and inside your wheel wells with a hose, sort of like your wheels would throw up the water from the road, and then check the wells to see if water has gotten in.
Good luck!
Br, Dale
Subietonic is offline   Reply With Quote
Old 07-01-2002, 09:15 AM   #6
waldrm
Member#: 14552
1999 Outback 5Dr
Dk Blue
Cover the rubber seal with baby powder, gently close the boot and wash around the perimeter with a hose. If the seal leaks the powder will be gone. Could also be a bad rear glass seal or clogged rear sunroof drain tubes.
waldrm is offline   Reply With Quote
2007 Legacy Shift Boot Sidewindor Private 'Wanted' Classifieds 3 06-30-2009 12:07 AM
Clock pod trim and legacy shifter boot Hcaruso4 Interior/Dressup/Audio & Security 1 02-08-2009 02:17 PM
Legacy AWD Gas tank leaks! How to change ??? Emmettjg Legacy Forum 6 12-27-2006 09:18 PM
FS: Legacy shift boot/trim (leather) t3hWIT Private 'For Sale' Classifieds 3 02-15-2006 09:42 PM
Legacy RS dgrallying Legacy Forum 5 06-21-2000 10:32 AM
