Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 11-08-2010, 11:38 PM   #1
juscool
Member#: 192278
Default Which clutch can I use
Hey guys, I have a 98 forester SF5 with a 97 jdm wrx driveline and I will have to replace the clutch real soon. Does anyone know which clutch package will work for me. The car has the stock turbo and 3" exhaust non-catted. i'm pretty much looking for something stockish. Would a 02 wrx work?
Thanks in advance.
juscool is offline   Reply With Quote
Old 11-13-2010, 01:32 AM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Any '02 through '07 WRX clutch will work. I liked the Excedy organic for a stockish feel clutch that lasted a long time.
speedyHAM is offline   Reply With Quote
Old 11-13-2010, 02:48 AM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Since you are going to drop the tranny to swap the clutch out, might want to think about a lighter flywheel.
But yes, stock wrx disc is fine. Might want to go with a better pres. plate though. Just in case you decide to throw some more boost in the mix.
~Josh~
Old 11-13-2010, 08:38 PM   #4
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Make sure you know if its a pull or push type clutch
sense of nature is offline   Reply With Quote
Old 11-13-2010, 08:42 PM   #5
juscool
Member#: 192278
Thanks for the info guys. I was thinking about a light weight flywheel and also the Extedy clutch package. How will I know if it's a push pull clutch or not?
Old 11-13-2010, 11:45 PM   #6
mowgli29
Member#: 203438
I vote for stock WRX clutch, assuming you need a pull-type clutch.
The "exedy stage I" or "exedy organic" might hold a bit more power, but it costs twice as much. Unless you know you need a stronger clutch, stick with a stock clutch: dirt cheap, good drivability, and less shock on the drivetrain.
(FWIW, my stock WRX clutch holds enough power to break traction. IMO, that says something with the grip of 255/40 Star Specs on dry pavement...I've done donuts in 1st and had the rear end get loose in 2nd and 3rd.)
Be aware that a LW flywheel will make launching more difficult and likely add drivetrain noise. I really didn't notice much of a difference between stock and an ACT streetlite....but every bit of weight counts, I say go for it!
The new clutch, whatever you get, should say whether it is pull or push type. As for figuring out what you need, some research should clear that up. I'm willing to bet you need a pull-type, but don't take my word for it.
mowgli29 is online now   Reply With Quote
Old 11-14-2010, 10:11 AM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
its a pull type use a 02 wrx for reference
in subarus the clutch matches the transmission
i am a believer in stock-like clutch strength and material .. changing a clutch is a 4-5 hr job in your driveway, a blown 2nd gear is not the 6-speed is the only place stronger makes sense
Old 11-14-2010, 12:06 PM   #8
mowgli29
Member#: 203438
Say what? I'm running a stock WRX clutch with a 6mt. I know people have gone the opposite way and modified the 5mt bellhousing to fit the larger 6mt clutch as well. Are you referring to pull vs. push?
Old 11-15-2010, 06:18 PM   #9
juscool
Member#: 192278
I'm going to stick with a stock setup. This forester
Is my daily driver aka sleeper. I have a 89 E30 ///M3
With a3.2L turbocharged putting out close to
400hp, so the forester has to remain close to stock.
Which clutch fork to use? Theyre different! (Pics) (04WRX to JDM STi V3 Trans Swap) relliMmoT Subaru Conversions 4 10-31-2010 02:37 PM
Spec Clutches...Can I use my stock flywheel? metoo Transmission (AT/MT) & Driveline 1 10-14-2010 01:05 PM
swapping engine, which clutch should i use? flyguyeddy Transmission (AT/MT) & Driveline 3 09-14-2010 07:28 AM
Which base can I use? snowflowmfg Interior & Exterior Modification 0 01-11-2010 08:36 PM
I know the "Infamous" which clutch should i use thread. I searched want more info. Wrx_Fan_0717 Transmission (AT/MT) & Driveline 7 04-08-2008 03:29 PM
