Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 11-09-2010, 01:31 PM   #1
kaane
Member#: 74006
2004 STI
Default Weird Problem on Swap, Won't Start
I have a weird issue on a 2000 RS with a 02 WRX Swap. When I turn the ignition to on position coolant gauge maxes out, fuel gauge drops to zero and fuel pump doesnt cycle. The car was working fine and it just happened. The wiring was done few years ago.
Also sometimes it does start and both gauges work normally, but when I drive it and it hits boost it starts misfiring bad and ends up dying. Right now I can't even start it.
I am thinking it's a grounding issue, question which ground?
kaane is offline   Reply With Quote
Old 11-09-2010, 03:40 PM   #2
kaane
Member#: 74006
2004 STI
I fixed it Main Engine ground bolt was loose. Runs great now!
Old 11-10-2010, 05:20 PM   #3
TheLordChesterfield
Member#: 234539
How did you find it? Mulitmeter? Or did you just go through and tighten everything?
TheLordChesterfield is offline   Reply With Quote
Old 11-10-2010, 10:57 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I'm guessing he went through and tightened everything one last time just to be sure, and he found the problem.
~Josh~
Old 11-13-2010, 01:13 PM   #5
kaane
Member#: 74006
2004 STI
I started inspecting all the ground points and saw that one was loose.
01 RS/04 STi swap won't start takumi Subaru Conversions 21 06-27-2007 12:00 PM
Swap won't start Mk3Design Subaru Conversions 7 03-20-2007 07:49 AM
Help swap won't start! yebokmj Subaru Conversions 21 04-04-2006 04:12 PM
Utec Experts: Shortblock swap won't start jefersun Engine Management & Tuning 12 08-31-2005 11:29 PM
swap won't start subiedreamin Subaru Conversions 14 08-24-2005 11:08 AM
Message Board Statistics All times are GMT -4. The time now is 02:30 AM.
