Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-09-2010, 07:48 PM   #1
CamTunedSti
Member#: 231697
Default JDM V7 ej207 into my 05 WRX
So im thinking of purchasing a V7 JDM ej207 shortblock with cp pistons and acl bearing, i dont want to deal with re wiring and stuff so my question is will my heads bolt on with no problems? or what other mods would you guys recomend to go with it? i thought of upgrading my valvetrain and maybe a set of mild cams with some porting. and im thinking of probably running a 20g or a fpgreen, maybe even a dom3 im not really sure, i want to make about 350-375 on pumpgas, maybe with meth if i have to. and obviously supporting mods, injectors, fuel pump, fmic, and a clutch. also are the injectors i would need still top feed or would i need sidefeed?
Any input you guys have would be great, i want to get my car running again so im looking to start purchasing parts by the end of the week, let me know what you guys think! thanks a lot!
CamTunedSti is offline   Reply With Quote
Old 11-09-2010, 10:20 PM   #2
Ds baruuuuu
Member#: 4724
01 01RS
brp
yes your heads will bolt up no problems. the injectors will depend on what rail setup and manifold you use if you use your factory 05 rails and manifold you would use top feed
Ds baruuuuu is offline   Reply With Quote
Old 11-10-2010, 01:15 AM   #3
CamTunedSti
Member#: 231697
cool thanks for the reply,
Old 11-10-2010, 03:56 PM   #4
CamTunedSti
Member#: 231697
so as of right now this is what im looking at doing, let me know if there is anything i need to add to this list, please and thank you.
jdm ej207 shortblock, cp pistons acl bearings
jdm oil pump
ej205 master gasket kit (idk if i need all this but thats why im asking)
arp headstuds
stage 1 exedy clutch kit
crower 272 cams
fp 20g 8cm^2
850cc injectors
walbro 255
FMIC? ( i have a big top mount is that enough?)
my car has 60k miles on it, do i need to get a new timing belt kit? thats a lotta money i dont wanna spend but i would like some opinions on that...
Also am i gonna need a fuel rail kit or will stock be enough?
i want to make between 350whp and 400whp on pump gas maybe with meth but i would love to stay with strictly pump gas.
also how high will i be able to rev? i dont know much about the 207 but im putting my heads on with a set of 272 cams. if i can get answers to all these questions that would be awesome! thanks guys!
Old 11-10-2010, 04:21 PM   #5
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
You will likely want valve springs as well. If your heads are shim-over-buckets, you will want to convert to shimless for higher than stock WRX redline.
8k redline is pretty standard for built up heads, should be plenty for a 20G, no reason to really push it.
Timing belt is coming off anyway, now is the time to replace it. No labor cost, just parts. Since a timing belt will typically outlast the time between rebuilds of a forged piston motor, you want a new timing belt. You don't want to have to replace the timing belt mid cycle on the motor. In my opinion anyway.
Concillian is offline   Reply With Quote
Old 11-10-2010, 05:21 PM   #6
CamTunedSti
Member#: 231697
Thanks a lot^^^ do you think that power level is too much to ask for?
Old 11-10-2010, 05:40 PM   #7
Ds baruuuuu
Member#: 4724
01 01RS
brp
not at all. i put down 328hp 298tq on a TD05 20g 7cm. stock ej20 with grimspeed crossover& p&p maifold, ported tvg deletes. 350 sould not be a problem
JDM v8 ej207 into 06 wrx? wrx_ryan Subaru Conversions 5 10-22-2010 10:04 AM
I have some questions regarding - Version 7 v7 EJ207 into USDM 2004 STi STepeci Subaru Conversions 8 09-18-2009 08:26 PM
WTT: JDM v7 EJ207 shortblock for USDM EJ257 shortblock... (Philly / NYC area) TROLL Engine/Power/Exhaust 9 01-14-2007 01:09 AM
will an 02 cluster fit into my 05 wrx? GGA EJ20 Electrical & Lighting 1 11-29-2006 03:54 AM
JDM V7 swap into 2002 WRX, Will it pass NYS inspection?? jonepachek Subaru Conversions 1 08-20-2005 02:25 PM
