Old 11-10-2010, 08:37 AM   #1
35psitsi
Member#: 218811
Default Intermittent Starting Issue
Hey all,
I have an '05 Impreza 2.5 N/A that has been acting weird lately. About a month ago, I was experiencing a misfire issue on rainy/foggy days only. I changed my plugs and wires with new ones and the problem seemed to go away.
About a week ago, I found myself outside the office and the car would not start. It would turn over of course but wouldn't catch at all. I tried to start it 3 times for about 10 seconds a try. I went back in the office to make a call, came back out and it started up right away on the first crank.
Last night I went to get some groceries, came out and it wouldn't start again! I cranked it for 10 second spurts about 5 times in the matter of 10 minutes. No start! I was starving at this point, went to grab a sub in the plaza while a friend I had called was looked for his OBD-II code reader to help. After coming back to the car, it started first crank.
That friend will be coming by tonight with the code reader but does anyone have any ideas that I might want to look for?
Thanks in advance.
35psitsi is offline   Reply With Quote
Old 11-10-2010, 09:41 AM   #2
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
make sure your distributor pack wired are going to the correct sparlugs, i found out the hard way that if you have 2 of them mixed u and d have a battery that is even slightly too weak, it will decide to not start also check the connection and clean both of your battery terminals... just letting you know what problems i have had on my 95 legacy ls na
acanadianreject is offline   Reply With Quote
Old 11-10-2010, 09:50 AM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
A bad main relay could cause intermittent starting problems. When it fails to start, check for spark.
Jessekrs123 is offline   Reply With Quote
Old 11-10-2010, 07:35 PM   #4
35psitsi
Member#: 218811
My battery is brand new and perfect. My plug wires are fine. Next time it happens, I'll be sure to check for spark.
Today it happened again somewhat. It took 6-7 seconds to start. Once it starts, it's perfectly fine. It's just the initial start. When this happened in my old Eagle Talon, my datalogger showed me a dead coolant temperature sensor but it was more of a consistent mis-start then this. I do't have a datalogger for this car and it's being tempermental.
I suppose checking for spark and fuel will be the first thing to try. Unfortunately, one minute it won't start, and the next it's got no issues starting. It makes it hard to see if spark/fuel is the issue when the problem itself isn't consistent.
Old 11-10-2010, 08:15 PM   #5
spinningcain
Member#: 176490
2005 STI
Fuel pump /fuel filter.. Have you changed the filter lately? When it does it turn the key on and see if you can hear the pump prime
spinningcain is offline   Reply With Quote
Old 12-26-2010, 10:26 PM   #6
mkalov5
Member#: 266118
try a new coil. they are known to get hair line cracks in them. if u do get the car to start, spray water on the coil pack and see if u see any arc..if so..bad coil pack
mkalov5 is offline   Reply With Quote
Old 12-26-2010, 11:47 PM   #7
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
if the pacs were wired in the wrong order, the car would run like sh** regardless...he said once it starts, it runs fine...
ThaPuertoRican15 is offline   Reply With Quote
Old 12-27-2010, 12:03 AM   #8
sue's roo's
Member#: 228787
03 wrx
broken 3/4 of the year
Starter contacts would be my bet.
sue's roo's is offline   Reply With Quote
(Halp!) Engine cutout & dies intermittently along with hot start issue DinoGuan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-30-2010 06:30 PM
Intermittent starting trouble during winter months. mikeybo Normally Aspirated Powertrain 1 06-23-2008 11:57 PM
Intermittent starting issues JamiePasson Legacy Forum 2 09-06-2007 09:06 PM
intermittent starting issue JamiePasson Service & Maintenance 0 09-06-2007 11:50 AM
95' impreza intermittent starting problem Outback98 Normally Aspirated Powertrain 0 10-14-2005 10:37 AM
