Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > RavSpec
Old 11-10-2010, 09:09 PM   #1
RavSpec
NASIOC Storefront Vendor
Vendor Sales Rating: (87)
Member#: 26854
2002 Impreza
WRX
Default Ferodo Racing Brake Pads DS2500 / DS3000 / Endurance Race
FERODO Brake Pads Available Here !!
DS2500 - (Street /Club Sport /Autocross)
- STI (Brembo Caliper) - $199 Shipped Front / $90 Shipped Rear
- WRX (4 Pot) Front - $179 Shipped ** stock 06-07 WRX
- WRX (2 Pot) Front - $129 Shipped
- WRX (1 Pot) Rear - $149 Shipped
(Ferodo compound code H)
The DS2500 is currently the best hybrid track/street pad on the market. It features the moderately high bite and solid fade resistance of a track pad, with the relatively low dust and noise levels of a street pad. When used as a street pad, it can produce some squeal on certain vehicle platforms. During aggressive driving the DS2500 is known for its flat torque curve, which means as temperatures go up, the response through the brake pedal remains consistent. If you drive aggressively on the street, do some canyon runs, autoX, and maybe some light track duty on street tires, the DS2500 is tough to beat.
When used on fast, heavy cars on the track with race tires, pad wear rates tend to be higher than some of the full track pad compounds. Under those conditions, we would recommend the Ferodo DS3000 or DS1.11.
DS3000 - (Semi Metalic / Track)
- STI (Brembo Caliper) - $295 Shipped Front / $169 Shipped Rear
(Ferodo compound code R)
DS3000 is one of the most decorated race pads in the global motorsports market, having won in diverse venues from rally to open wheel cars. The DS3000 has high bite and good fade resistance. It has a slightly rising torque curve, which means that as temperatures go up, bite increases slightly. Although the bite of the DS3000 is slightly higher than the DS1.11, wear rates are also higher. If you are doing extended lapping (30 minute+ sessions) or endurance racing, and are concerned about pad wear rates, the DS1.11 is probably the better choice for you.
DS1.11 (Semi Metallic / Endurance Race)
- Ask for Pricing and ETA !!
(Ferodo compound code W)
The DS1.11 is one of Ferodo's latest race pad offerings. It has slightly less bite at high temps. vs the DS3000, but doesn't decompose nearly as quickly under extended heavy use on the track. The DS1.11 is known for its extremely flat torque curve, which means that as temperatures go up, the response through the brake pedal remains consistent. If you want a pad that you can thrash all day without having it burn up or fade, the DS1.11 is a great choice.
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ KW ] [ DBA ROTORS ] and many more!
TEL: 631-586-3520
EMAIL:
RavSpec is offline   Reply With Quote
Old 11-17-2010, 12:25 AM   #2
RavSpec
Member#: 26854
2002 Impreza
WRX
Article Courtesy of Essex Brake , Thanks !
BASIC PAD COMPOSITION
Before jumping into specific pad selection, let’s first take a step back and look at the bigger picture. Understanding the material composition of the four basic pad types, and how those materials behave on our cars, will substantially narrow the sensible choices for any given driving condition.
Brake pads for street cars typically fall into one of four categories. These categories are defined by the pad’s fundamental composition: organic, semi-metallic, ceramic, and sintered.
Organic
Organic pads are made of fibers mixed with fillers and binding resins to hold them together. Some components commonly found in organic pad are glass, Kevlar, and carbon. Organic pads have what enthusiasts consider a ‘mild’ character. They tend to be softer, easier on rotors, and they don’t make much noise. In the US, most OEM’s ship organic pads in new cars because they don’t require a lot of heat to generate friction, or bite. They are therefore safe for commuting in various environments. While these pads offer comfort, their Achilles Heel is a severely limited temperature range. Once they reach their maximum operating temperature, they almost immediately lose their coefficient of friction and burn up very quickly.
The materials used in these pads are the least costly to acquire, as are the tools and processes to manufacture them. Therefore, organic pads are typically the least expensive pad type.
Semi-metallic
Not surprisingly, semi-metallic pads get their name from their composition. Each friction puck contains a substantial amount of metal. Common ingredients are steel wool, iron, or copper, mixed with fillers, friction modifiers, and lubricants such as graphite. On the plus side, these pads have higher operating temperatures than organic pads, draw heat out of the rotors, and do not wear as quickly. On the other hand, they’re more abrasive and tend to wear rotors more quickly, make more noise, produce heavier dust, and many times have very little cold bite. Most race pads on the market today are semi-metallic.
Because the constituent materials, tools, and processes involved are more expensive than those used to produce organic pads, semi-metallic pads are more expensive.
Ceramic
The term ‘ceramic’ has been a hot marketing buzzword in brake pads for the past decade. These pads are created by mixing ceramic fibers, fillers, and bonding agents. The greatest benefits of ceramic pads are their lack of dust and noise. They tend to wear a little longer than organic compounds, and are also a bit more rotor-friendly. While they may have a higher temperature threshold than some of the organic compounds, they cannot compete with semi-metallic or sintered pads for heavy duty use. Enthusiasts who spend a disproportionate amount of time staring lovingly at their 6” polished rim lips may enjoy ceramic pads. Those who prefer to actually drive their car hard may be disappointed with the performance of ceramic pads.
Sintered
While sintered pads have been popular on motorcycles with steel rotors, they remain an emerging technology for automotive use. Most sintered pads are formed from a copper alloy powder. The powdered metal is mixed with other lubricating and wear controlling constituents such as graphite and carbon, formed into the required shape, and then brazed to a backing plate at temperatures as high as 1800 degrees F. ]
Sintered pads have some unique characteristics vs. other pad types. Their nearly pure metal content provides a stable coefficient of friction from cold to hot, meaning they often need almost no warm-up time to produce bite. Since they’re formed at extremely high temps, they don’t fade under extreme use. They also don’t create as much of a transfer layer on rotors, and therefore don’t require a lengthy, traditional bed-in procedure. Since the pads are semi-porous, they can be used in any weather condition: rain, snow, mud, etc.
Because they are mostly metal, the negatives traditionally associated with sintered pads have been increased rotor wear, noise, and the transmission of heat into the calipers.
The materials, tools, and processes involved with producing sintered pads are the most expensive of all current pad types.
__________________
TEL: 631-586-3520
EMAIL:
Old 12-23-2010, 04:01 PM   #3
grey90
Member Sales Rating: (1)
Member#: 167506
2003 PSM Impreza WRX
2005 Wicked White Evo
Which DS2500 pads fit the front and rear on the 2003 WRX?
grey90 is offline   Reply With Quote
Old 12-28-2010, 11:34 AM   #4
RavSpec
Member#: 26854
2002 Impreza
WRX
Give us a call to order them. T: 6315863520
__________________
TEL: 631-586-3520
EMAIL:
Hawk Blue Full Race Brake Pads for RS brakes - new DeusExMachina 1993 - 2001 Impreza Specific Parts 12 04-26-2009 11:19 PM
FS: 04 WRX brakes and axxis Racing brake pads... shumai_boi Private 'For Sale' Classifieds 4 03-03-2005 11:21 PM
wanted: used track/race brake pads abaxter34 North West Impreza Club Forum -- NWIC 8 10-26-2004 10:06 PM
StopTech Club Race brake pad questions ChrisW Brakes, Steering & Suspension 7 05-28-2003 05:36 PM
Racing Brake pads HKscooby Vancouver Impreza Club Forum -- VIC 1 03-01-2001 10:41 PM
