Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 11-11-2010, 03:23 AM   #1
Kamm99rs
Member#: 253793
2005 Legacy 2.5i
black
Default Swapped 99 RS CEL Code (Gas Tank Pressure Control Solenoid)
So I did an 05 STI swap in my 99 RS last week. Everything went smoothly and it run's flawless! I only had two cel codes that came on. One was for a low MAF sensor signal, the other was for a fuel tank pressure control solenoid (from what I remember).
I fixed the MAF sensor signal, and I've heard that the STI tank has a tank pressure sensor that the RS tank does not have. The ecu is wired for the sensor, all I need to do is basically find the correct part and wire it in. It's not necessary and I've been told that it can just go anywhere basically, I just want to get rid of the cel light so I can get it Barred (I'm in CA).
So I came up with the following part number for it: 14774aa601
It's cheaper for me to just buy the sensor than flash the code out so I just wanted to see if anyone knew if that part number I came up with was the correct one. It's necessary for ALL STI/RS swaps so it's either you swap the tank and have the sensor already installed, flash the code from the ECU, do what I'm going to do, or just ignore it so I figured someone would know.
Kamm99rs is offline   Reply With Quote
Old 11-19-2010, 05:12 PM   #2
httrdd
Member#: 224180
What about putting a resistor on the sensor wire?
httrdd is offline   Reply With Quote
Old 11-21-2010, 06:42 PM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
A resistor doesn't work because the ECU is looking for a changing signal depending on the input.
That part isn't necessary for all RS/STI swaps as some RS's (2000 and 2001) already had that sensor installed form the factory.
speedyHAM is offline   Reply With Quote
Old 11-25-2010, 06:15 AM   #4
Kamm99rs
Member#: 253793
2005 Legacy 2.5i
black
Sorry, I was referring to my model. But for future searchers, that's the part if you have a gas tank pressure sender solenoid cel code
Old 12-12-2010, 12:20 AM   #5
scoobylong
Member#: 127087
1999 2.5 RS(swapped)
I'm having the same problem with my 03 wrx swap on my 99rs, but my car's not even running right (sputters at certain rpms). I gotta get a new one for the rs I guess.
scoobylong is offline   Reply With Quote
CEL code P0457: Evaporative Emission Control System Leak Detected (fuel cap) aznfoos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 06-24-2015 06:27 PM
Fuel tank pressure control solenoid sebatsi Private 'Wanted' Classifieds 0 09-23-2009 09:22 PM
Got CEL code 440, Emission System Control Evan J. Kelly Normally Aspirated Powertrain 14 11-27-2008 12:58 PM
CEL and Gas tank problem.. Redemption Service & Maintenance 2 12-27-2007 04:36 PM
P1400 Fuel tank pressure control solenoid valve circuit low input after utec install bozz Engine Management & Tuning 7 07-29-2004 12:47 AM
