Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 11-11-2010, 08:13 PM   #1
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Default 2007/2008 STI = Same R180 ? experts please!
Just wondering if anyone can confirm or deny that the R180 is the same between 2007 and 2008 ?
I know they are both 3.545:1 with Torsen LSD, but are there any other differences that would keep one from being able to install a 2008 R180 in a 2007 STi ?
Thanks.
Team Scream is offline   Reply With Quote
Old 11-14-2010, 12:33 PM   #2
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Nobody knows what if any difference there is here?
Old 05-20-2013, 02:32 PM   #3
chrod
Member#: 214081
2005 Saabaru
Default bump
bump for an answer to this question..........
chrod is offline   Reply With Quote
Old 05-20-2013, 03:46 PM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Im quite certain they would be the same intall wise. I only difference ive seen is the GR/GV etc has longer studs on the back for mounting on the rear subframe. Sort of like say the forester etc... Just had to swap the two studs with ones from any 02-07 impreza, r160, and r180 studs are the same from 02-07... Everything else mounts the same.
Hope this helps.
Ian,
rexworx is offline   Reply With Quote
Old 05-20-2013, 04:08 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
What he said
FuJi K is offline   Reply With Quote
Old 05-20-2013, 04:09 PM   #6
wurlyvalve
Member#: 73330
1998 Legacy BH9
Deep Red
Used to strip sti for group n build. I left prodrive april 07. We had been sent in 08 samples, pre-production, thet were identical. But i never saw the main production line item. I chatted to the guys after i left and they were resolute that it was all the same, toyota had changed nothing.
wurlyvalve is offline   Reply With Quote
Old 05-20-2013, 04:24 PM   #7
wurlyvalve
Member#: 73330
1998 Legacy BH9
Deep Red
From memory, the 06 was 45 deg ramps, the 07 and 08 were 35 deg ramps. The centre diff 07 on was crap, comissioned by subaru and designed with much better judgenent by gkn.
Old 05-21-2013, 11:17 AM   #8
rexworx
Member#: 103232
^^^ 06-07 center diff the same? 08+ any better? 04-05 35:65 split the best I assume?
Old 05-21-2013, 02:46 PM   #9
wurlyvalve
Member#: 73330
1998 Legacy BH9
Deep Red
35:65 was '03-'04 era. The '05 onwards were 40:60ish. From '07 onwards they ditched sintered steel grooved discs for paper/cork friction plates. Much quiter at full lock binding but one rally they were shot! We had to replace the entire centre diff after every rally. The earlier ones were rebuildable. The shfts that held the epi gears eventually drifted out locking the plates so we would re peen them back in.
Old 05-21-2013, 03:02 PM   #10
rexworx
Member#: 103232
Thank you!
Are 2008+ sti engine and tranny mounts the same as 2007- mudbug Transmission (AT/MT) & Driveline 2 04-26-2010 05:21 PM
FS:NY 2006-2008 STi R180 rear diff singincanary Drivetrain 14 12-29-2009 04:16 PM
Fs:CT/ 2007-2008 STI Oil pump 98SubbyLeg Engine/Power/Exhaust 0 09-18-2008 11:57 AM
2008 WRX, 2007-2008 LGT and SPEC-B, 2007-2008 FXT and 2008 STi .COBB ACCESS PORT! RallySport Direct Engine/Power/Exhaust 2 12-12-2007 01:34 PM
