Old 11-12-2010, 05:21 PM   #1
dmilamj
Member#: 240038
2005 Forester XT 5MT
White on Black
Default Spacers (I know) for WRX Wheels on a Foz
I have a '05 Forester and I'd like to put the 06/07 17" WRX wheels on it. The Foz uses a +48 offset, but the WRX wheels are +55.
I'm trying to avoid that sucked in look, so I'm thinking a 10mm spacer would give me an effective +45 offset, which should be close enough to stock to keep handling the same and keep my wheel bearings happy. Is this correct?
(I know that +55 would be better for my bearings...but would reduce my track width slightly..I also know I'll have to replace the studs with a 10mm spacer...)
Also, has anyone attached a spacer to the inside of the wheel, semi-permanently (tack weld or a couple dots of JB weld), then had the wheel balanced? It seems like this would help eliminate the spacer as a potential unbalanced weight. Also would make changing the tire a bit easier. Is there any reason that this might not work?
dmilamj is offline   Reply With Quote
Any recommendations for winter wheels on an 06 WRX? ComradeTony Tire & Wheel 6 10-27-2010 04:24 PM
$950 for wrx wheels/tires... are you on here?! scoby41 North West Impreza Club Forum -- NWIC 28 02-19-2009 08:06 PM
Need tires for 02 WRX wheels on an '00 RS vehicle dingo dave Tire & Wheel 0 08-21-2006 09:46 PM
Largest wheel/tire combo for WRX wagon on stock suspension? well_armed Brakes, Steering & Suspension 3 08-02-2002 08:29 PM
What color lugnuts/locks for silver wheels on WRB WRX? clsmooth71 Interior & Exterior Modification 2 05-20-2002 09:49 PM
