Old 11-13-2010, 10:39 PM   #1
wtfh4xx
Member#: 220059
2004 JBP WRX
STAGE 2
Default Will 245/45/17's fit on 04 WRX?
Like title says.
I have an 04 WRX lowered on perrin springs.
Currently on stock 16's with advans.
I'd like to jump up to a 17" wheel with 245/45/17.
Will this fit?
Not worried if it needs fender rolling, I am willing to do that.
I just have a brand new set of tires sitting in the garage never used.
Figured I might as well get 17" wheels and use em.
Probably Torque's or somethin.
wtfh4xx is offline   Reply With Quote
Old 11-13-2010, 10:42 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
too tall
Old 11-13-2010, 10:47 PM   #3
wtfh4xx
Member#: 220059
2004 JBP WRX
STAGE 2
Damn. Thanks Scotty.
I guess Ill have to resell the tires and find new ones.
And as an afterthought, any main differences between a 17" and 18" wheel on subies?
Old 11-13-2010, 10:50 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
i have no use for 18's
tires(and wheels) are more expensive.....and heavier
no thanks
Old 11-13-2010, 10:57 PM   #5
wtfh4xx
Member#: 220059
2004 JBP WRX
STAGE 2
Thanks again.
That was my thinking as well.
I also think the 18" tires look too skinny. Kinda like a hot girl thats anorexic.
Its just no good. :P
Ill stick to 17's and find some new rubber for em once I move these ones sitting in my garage.
Old 11-14-2010, 11:51 AM   #6
gixxerred
Member#: 234308
04' wrx
my momo 18 7.5's are sexy on my 04 on tein S springs with light fender roll!! i got a set of 2010 wrx rims to put on they are 17, 7's it will be sweet!!
gixxerred is offline   Reply With Quote
Old 11-14-2010, 12:18 PM   #7
mowgli29
Member#: 203438
Originally Posted by Uncle Scotty View Post
too tall
For what? Is it tall enough that it rubs on the strut/spring perch? I can't imagine the proper offset wouldn't fix that problem...albeit with a bit of fender rolling required.
EDIT: ok, nvm...they're taller than I thought! lol. I run 255/40-17, which fit fine, and are ~1/3" taller than 245/40. The 245/45 would be almost 2/3" taller than mine...or .97" taller than the 245/40.
mowgli29 is offline   Reply With Quote
Old 11-14-2010, 12:22 PM   #8
sc00by4life
Member#: 97135
EDIT: ok, nvm...they're taller than I thought! lol. I run 255/40-17, which fit fine, and are ~1/3" taller than 245/40. The 245/40 would be almost 2/3" taller than mine...or .97" taller than the 245/40.
Neither of you really understand tire tire fitment.
a tall tire is just that...too tall. if a tire was hitting the strut, either the offset is too high or the tire is too wide (usually...the offset is too high and that can be fixed with a spacer.
in neither case would a fender roll be required or even necessary.
Old 11-14-2010, 12:45 PM   #9
mowgli29
Member#: 203438
I understand "tire tire fitment" perfectly fine. I simply didn't realize the tire was THAT tall.
Go look at the shape of the spring perches...you'll notice they slant up. Thus, if the tire is just a hair too tall, spacing it out (where the perch is higher) would allow enough room. If that were the case, a minor fender roll would likely be ideal. A 245mm tire is just about as wide as you can go without a fender roll....BUT if you had that same 245mm tire spaced out 10mm more than "proper" offset, you'll rub.
Old 11-14-2010, 03:56 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
no...no they are not sexy
car parts and subarus are NOT sexy
and s tech springs are total junk and should be banned from sale as such
Old 11-14-2010, 04:03 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
bull****....perrin springs are slammer springs and the damn thing would rub like mad
Old 11-15-2010, 10:18 PM   #12
Toyotachaos
Member#: 158073
I had 245/45/17 on my 2005 STi. They fit with plenty of room. It was on stock springs though.
Toyotachaos is offline   Reply With Quote
Old 11-15-2010, 11:18 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by Toyotachaos View Post
I had 245/45/17 on my 2005 STi. .
then your post is meaningless here and you should not have posted
you are just adding useless noise to this thread
stop
Old 11-20-2010, 08:15 AM   #14
Bald_Wrex
Member#: 236005
2000 Impreza 2.5RS
I had 245/40r17 on my 04 wrx wagon. I had to roll the rear fenders hard but the fronts wouldn't tuck unless I had the sedan fenders. If you have the sedan you shouldn't have to do much but if it's a wagon it's a pain. Good luck.
Bald_Wrex is offline   Reply With Quote
Will 245/45/18 fit on 09 FXT? wychk99 Forester Forum 8 03-04-2009 12:52 PM
Will 245/45/17's fit a stock 05 WRX? maxpower_454 Tire & Wheel 3 11-09-2007 01:08 PM
Will 225/45-17's fit on 7.0 or 7.5 wide rims? 99snowhiteRS Tire & Wheel 4 09-26-2007 09:17 PM
will 06 underbody diffuser fit on 04 wrx strongasanoxx Subaru Conversions 1 09-27-2005 09:07 AM
will 235/45 17's fit on a 17x7.5 w/50mm offset? couldnthinkaone Brakes, Steering & Suspension 2 04-30-2001 04:20 PM
