Old 11-14-2010, 02:54 PM   #1
Noek
Member#: 206316
2009 STI StageII
Default GtR uses difft size wheels, why can't we?
Reading that the Nissan GtR comes standard with 20" wheels, however the fronts have a 40 profile while the rears enjoy a 35 series. The fronts are also 9.5" wide wrapped in 255 rubber, the rears are a whopping 10.5" wide with 285!
What gives, I thought difft size and width played havoc with an awd system, or is it just Subarus awd system?
Noek is offline   Reply With Quote
Old 11-14-2010, 03:04 PM   #2
04furesterXT
Member#: 73223
2009 STI
Not when it's designed around the tire sizes.
04furesterXT is offline   Reply With Quote
Old 11-14-2010, 03:19 PM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
First off, the tires are hugely different widths, but they are very close in circumference - only 0.6" difference. One tire is 27.9" in diameter, the other is 28".
Second, it's easy enough to engineer an AWD driveline to deal with different tire sizes, but it's much more difficult to switch between even and staggered sizes. You need to re-gear the driveline to account for the difference.
sniper1rfa is offline   Reply With Quote
Old 11-14-2010, 03:28 PM   #4
4-n-zics
Member#: 228961
2016 4Runner TRDP
Actually, that is only 0.1" difference.
4-n-zics is offline   Reply With Quote
Old 11-14-2010, 03:52 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you really wanna screw up the handling of your precious subaru
i mean REALLY screw it up
play around with different size wheels and tires
Old 11-14-2010, 04:07 PM   #6
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
what you dont want to make your car that naturally understeers, understeer more?
jdmboy is offline   Reply With Quote
Old 11-14-2010, 04:41 PM   #7
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Thanks, but i said 0.6" difference in circumference. You'll note that diameter and circumference are not identical measures.
Old 11-14-2010, 04:44 PM   #8
Noek
Member#: 206316
2009 STI StageII
Thanks man, def clears it up for me. Is the reverse true as well if they ran a setup that was identical for fr and rear? Would it be bad for the driveline?
Old 11-14-2010, 04:53 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
irrelevant....and it would handle in a dangerous manner, I'm sure
the car is DESIGNED......DO you understand what that means???
designed for a particular setup from the factory
deviating too much from THAT without KNOWING EXACTLY what you are doing....you would need a LOT of experience and education to get close to knowing.....is a real bad idea
and again.....the heart of all rice is people trying to compare a 'race car' or 'super ca'r(or near super car, the GT-R is in this category) to a regular, plain jane subaru(or whatever else)
Old 11-14-2010, 05:23 PM   #10
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
the car also has the power STOCK to push wheels and rubber like that....plus you really need a 19 or 20" set up on a subaru? joking right?
SedonaScooby is offline   Reply With Quote
Old 11-14-2010, 05:23 PM   #11
Noek
Member#: 206316
2009 STI StageII
Sooooo......yes?
(stepbrothers)
Old 11-14-2010, 05:50 PM   #12
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Probably. They probably have very little reason to change tire sizes though.
Old 11-14-2010, 06:06 PM   #13
littlewhitewagon
Member#: 103068
11 STI sedan
I have considered doing this, but backwards on my 2011 STi. 10.5" wheel with 275 up front, and 9.5" wheel with 245 out back. I've found some tires that are the same diameter and revolutions per mile. The problem is that we can usually fit 265s all the way around, so I'd be giving up grip in the rear... back to the drawing board. This might be a good setup for autox or gynkhama.
littlewhitewagon is offline   Reply With Quote
Old 11-14-2010, 06:10 PM   #14
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
You wouldn't be the first to do that.
Old 11-14-2010, 06:22 PM   #15
REX8
Member#: 24038
Reading, it's fundamental.
Old 11-14-2010, 07:01 PM   #16
Insuwrxtion
Member#: 181805
2006 STI-silver blur
280ZX-garage bum
I believe that he was mostly referring to the different widths. Like can he run XXX wide up front with XXX wide in the rear like the GTR does.
Insuwrxtion is offline   Reply With Quote
Old 11-14-2010, 07:24 PM   #17
Noek
Member#: 206316
2009 STI StageII
Correct, I have no idea WTF he was talking about, why I ignored his post.
Old 11-14-2010, 07:39 PM   #18
Insuwrxtion
Member#: 181805
280ZX-garage bum
I'm guessing he took it as "if the GTR has staggered 20's, why can't I have staggered 20's". Just a little miscommunication is all, no biggie.
Old 11-14-2010, 07:54 PM   #19
Noek
Member#: 206316
2009 STI StageII
It was just an informative question on why diff awd systems are able to run difft width and circ tires is all, nothing else
Not sure where all the other crap came from
Old 11-14-2010, 08:02 PM   #20
littlewhitewagon
Member#: 103068
11 STI sedan
Yeah, I'm not proposing that I'm innovating anything. I know a bunch of the Japanese track cars do this already and it helps to balance the car at the expense of overall grip. But their cars get driven for a couple hundred miles then get torn down and rebuilt. I put 4k miles on my 2011 STI in the first month...
Old 11-14-2010, 08:20 PM   #21
Noek
Member#: 206316
2009 STI StageII
^ did you own a wrx before that?
Old 11-14-2010, 10:11 PM   #22
littlewhitewagon
Member#: 103068
11 STI sedan
Yes, I had an 06 wagon. 108k miles in under 5 years, and my car spends LOTS of time parked at the airport (about 2+ months out of the year) because of work. My daily commute is already 58 miles round trip without me going out, eating and doing other random stuff. For this reason, I have to keep everything reasonably functional and be reliable all the time. I've only had the wagon towed a couple times, once was for the diff and rear diff taking a dump, and once for a major collision.
Why can't we use a nuclear bomb/dry ice/whatever to stop hurricanes? ANZAC_1915 Off-Topic 5 09-01-2005 10:46 PM
Why can't we use red ink to write papers in school? INFIDEL Off-Topic 8 08-16-2005 07:40 PM
why can't we use stock lugnuts? Poe Brakes, Steering & Suspension 3 02-11-2003 07:26 AM
WHY can't we delete threads anymore? we always used to be able to?????? wrx182 General Community 3 11-26-2001 09:22 AM
Why can't we get these sweeeet arse wheels Ghomer1 Brakes, Steering & Suspension 1 10-12-2001 10:47 PM
