Old 06-27-2011, 09:08 AM   #376
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
The cams would only rust if exposed to water, not a lack of oil. So either you had a defective headgasket, the deck surfaces aren't flat or the install was effed up.
Why so much sealer on the inside lip of the head?
A-man07 is online now   Reply With Quote
Old 06-27-2011, 10:30 AM   #377
08WhiteRex
Member#: 187453
2012 Mulletmobile
^^^Cams will rust if un-oiled and exposed to air.
EDIT: The reason i ask about the cams being correct is because i've heard rumblings that the 08+ have extra galleys that the previous models don't. Lack of those galleys would be lack of oil and bad things for your valvetrain.
08WhiteRex is offline   Reply With Quote
Old 06-27-2011, 10:52 AM   #378
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
I will be super light on the sealant when it goes back together, I honestly dont know why there is that much?? I thought only did thin lines. Obviously not.
binjoau is offline   Reply With Quote
Old 06-27-2011, 07:19 PM   #379
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
So from bad to worse.
When removing my cam gears using the factory subaru tools 2 of my bolts rounded off. 1 sheared and the other came out just fine.
I am now at the stage of having to drill them out but my hardened drill bits barely do anything. Anyone know what kind of drill bit I should use??
I think god hates me.
Old 06-27-2011, 07:53 PM   #380
monkiboy
Member#: 202958
2008 wrx
i've been quietly lurking this thread and i feel for you and admire you are attempting this all yourself.
but why are you assembling this motor yourself? especially after so much trouble and predicaments along the way, it would seem one would feel most confident with a reputable builder/tuner shop doing some/most/all of the leg work, with a warranty to back it, then trying it to DIY it and constantly fudging up and reworking it. maybe if it was an older project car or something it'd be a great way to learn, i dont know...
best of luck to you in your endeavors. i'm sure it's only just a matter of more money, more patience, and more time. try to stay optimistic!
monkiboy is offline   Reply With Quote
Old 06-28-2011, 01:01 AM   #381
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Its quite simple really, I am a car enthusiast. I enjoy working on my own vehicle and learning as I go along. Does everything go correct first time, no of course not but when its all said and done I can say I built my motor myself. I am not fudging anything, as previously mentioned I am following the shop manual, I am spending good money on good parts and not cutting corners. I have removed my cam gear bolts 2 times previously with no problem at all, I even used the factory Subaru tools!
I understand it may be easy to say, why not have a shop build it when you live in DC but where honestly would you suggest I have it done? I live in Regina, SK, CANADA, we are so far from everything that it would cost me so much money it wouldnt be worth it. Just to ship my shortblock alone was $400!!!
Plus I wouldnt trust a shop that works on V8's and Cobalts to build a Subaru motor. I hope you can kind of see my point here, okay I may be being ambitious but I will succeed no matter how long it takes. Plus my first build went fine and worked great for 3k before the bearings in the pos RAW block I had let go......
I did however find out what had caused my HG issue, there was some debris on one of the surfaces, small bits of gravel that had kept the one corner from sealing. I must of missed it I guess when assembling them. It is annoying but not the end of the world. New gaskets will be on within a few days, then I was just thinking of using some crazy glue and lollipop sticks to put it back together?..... maybe even use fudge as a bonding agent?
Haha, anyway, back to working my ass off, breaking stuff and spending too much money but lets face it, its worth it in the end.
Alex
Old 06-28-2011, 10:55 AM   #382
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i like where your head is bro. i built my own crap, so i can only blame myself when it fails.
i go into with the attitude, i'll fix it when it fails, not IF it fails. the longer it lasts the better, but when pushing the limits and not rebuilding after every race is just a bonus when she starts right up.
if i had more money i'd be pushing it harder.
keep up the good work alex.
maxpowr is offline   Reply With Quote
Old 06-28-2011, 11:01 AM   #383
Serkan
Member#: 180514
2004 Sti
Good job Alex. I am with you on doing your own work. I am sure you will get it right this time.
Serkan is offline   Reply With Quote
Old 06-28-2011, 11:16 AM   #384
MartinSTi05
Member#: 145145
2006 wrx STi
I have used two flute solid carbide drills in the past. Also high speed steel drills. The key is not to get the bolts/ bits too hot. The bit will get dull and the bolt will work harden. Use cutting oil.
MartinSTi05 is offline   Reply With Quote
Old 06-28-2011, 12:42 PM   #385
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
I ended up using a blue cobalt drill bit. Seemed to do the trick, I know what you mean about keep the temps down though.
Il be ordering up one new cam gear as it cracked when I tried to undo it as well as a new timing belt cover rear piece. I am just super glad my SB appears to be in good order. Even though parts are expensive etc I should have her back on the road Friday.
Old 06-29-2011, 03:14 AM   #386
ledzeppelin240
Member#: 227951
2004 Impreza WRX
Well I feel bad for you, my problem with my built engine is the spring I have in my Tial EWG, so anyways good luck.
ledzeppelin240 is offline   Reply With Quote
Old 06-29-2011, 06:39 AM   #387
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
^^^^^so what happened with ur wastegate?
sackytar is offline   Reply With Quote
Old 06-29-2011, 01:32 PM   #388
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
So assembly has started again, being super anal this time with everything. With my headgaskets I am using a high tack liquid gasket at the reccomendation from my Subaru tech friend. He said they use it on all there STI's and have had zero problems with them.
Im skeptical but if he has used it 30 times with no issues then it must work.
Old 06-29-2011, 02:10 PM   #389
chadster152
Member#: 281048
^hope it works man i wanna see this thing running strong!
chadster152 is offline   Reply With Quote
Old 06-29-2011, 02:10 PM   #390
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
you'll do just fine...take your time.
no obvious issues, aside from the head gasket?
Old 06-29-2011, 02:46 PM   #391
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
No everything appears good, I did decide to replace both exhaust cam gears as the other one had a tooth missing, probably would of been fine but I am not going to risk it at this stage. I have already assembled the one head and I will finish the other one tonight. Im cleaning everything again to ensure it all good to go.
Old 06-29-2011, 03:25 PM   #392
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
what did you lash the heads to? nothing over torqued...
what headgasket this time? size?
Old 06-29-2011, 06:54 PM   #393
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
studs were done to arp reccomended spec and procedure, 90 i think from memory. This time I am doing the Subaru reccomended specs as I had no problem with it last time. Using OEM STI headgaskets.
Old 06-29-2011, 07:06 PM   #394
Jirv311
Member#: 273528
2002 Impreza WRX
Using OEM head gaskets and torque sequence is a good thing but I'd still stick with the ARP recommended 90 ft-lbs.
Jirv311 is offline   Reply With Quote
Old 06-29-2011, 07:38 PM   #395
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Im in 2 minds about it, i know with my first block i did oem hg and oem specs and it worked great.
Old 06-29-2011, 07:54 PM   #396
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i ment valve lash...my bad.
Old 06-29-2011, 08:36 PM   #397
Copper Rex
Member#: 53721
35R Bugeye
[email protected]
Fwiw, two very reputable subaru shops/builders told me to torque the headstuds exactly to ARP's instructions of 90ft. lbs except the 2 center studs. They like to snug those up just a lil more to 95ft. Lbs. Also use the fsm Alphabetical torque sequence but use ARP's 30-60-90 sequence. Good luck
Copper Rex is offline   Reply With Quote
Old 06-29-2011, 10:59 PM   #398
MartinSTi05
Member#: 145145
2006 wrx STi
Done several with OEM head gaskets to ARP specs they all work... Don't re invent the wheel. The OEM torque values are meant to work with a bolt, not stud that also has a very different modulus of elasticity, and doesn't use the same thread lube. Use ARP instructions! You stated earlier that some debris caused the failure why the hell would you change your torque method if you clearly defined what caused the failure?
Old 06-30-2011, 12:54 AM   #399
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Because I am using the same procedure I did the first time when it worked flawlessly. I used oem gaskets and the oem procedure and had no problems. I decided to go this route.
Fwiw I went and just checked one of the studs, and following the oem specs puts the torque to just about 125 nm according to my torque bar.
If 90 ft lbs in nm is 90 x 1.35 = 121.5 nm. So really the difference is hardly anything.
Should I and could I have followed the ARP instructions yes. Even though I didnt I am hoping approx 3.5 nm is not enough to affect performance. If it does, il go back and redo it again, I just did what I did first time when it worked.
Old 06-30-2011, 12:59 AM   #400
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
valve lash all checked out, which confuses me about my ticking, the only other thing I could think of is it was the hg leak??
The Long Road to Figure Skating: A Build Thread. yankdanger Member's Car Gallery 158 03-13-2015 01:12 AM
Budget 09 wrx engine build in Oklohoma City likeawind Built Motor Discussion 11 12-12-2011 04:29 PM
('08-'10) My car history and small build thread of 09 LR Impreza 2.5i 5mt! sl0wbaru Impreza Forum 4 10-04-2011 05:36 PM
09 wrx build spx19811 Newbies & FAQs 0 03-27-2010 12:58 PM
09 STI build 08-08 or 09 WRX Build 03-09 co09wrx Newbies & FAQs 7 07-16-2009 01:43 PM
