Old 11-16-2010, 11:46 AM   #1
DSMAddicted
Member#: 157976
Default Quick Newbie question on STi wheels for regular WRX
Guys,
I know I can find the answer by searching but I need to help a friend make a quick decision.
My buddy has a 2007 WRX (non STi) identical to this one (even has the same wheels).
He damaged two wheels and tires and I suggested he buys a set of used STi wheels and tires.
Would STi wheels and tires bolt on to his car directly, or is there a bolt pattern issue going on? Anything we need to be aware of before pulling the trigger on a set?
Please let us know, thanks in advance for your help.
-Walter
DSMAddicted is offline   Reply With Quote
Old 11-16-2010, 12:13 PM   #2
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
2005+ sti uses different bolt pattern (won't fit his wrx).... only 2004sti wheels would.
Robin2 is offline   Reply With Quote
Old 11-16-2010, 12:21 PM   #3
beachscooby
Member#: 63530
2005 wrx sti
white
04 STi wheels will fit. 05 and above will not.
04=5x100 and 05=114.3
beachscooby is offline   Reply With Quote
Old 11-16-2010, 12:28 PM   #4
DSMAddicted
Member#: 157976
Thanks for confirming guys.
Is there an aftermarket wheel maker that makes fairly priced and good quality STi wheel replicas with the correct bolt pattern?
Alternatively, would trailing arms and knuckles from an '05+ STi help make these wheels compatible as well as provide a nice brake upgrade?
In other words, what would you do in my friend's shoes? Again, he damaged two of his factory wheels and tires. The other two wheels are fine, but the tires were due to be replaced anyways. Getting two replacement OEM wheels from the dealer is going to rape my buddy's wallet and an upgraded set of wheels makes perfect sense both functionally and economically IMO.
Thanks for brainstorming with me,
-Walter
Old 11-16-2010, 01:43 PM   #5
snowskis
Member#: 222489
2009 WRX Hatch
Not sure how legit this place is. I saw someone mentioning it on another forum. Prices are cheaper than dealer for sure. Some replicas, some OEM.
http://www.finishlinewheels.com/SUBARU/IMPREZA/2007/
snowskis is offline   Reply With Quote
Old 11-16-2010, 04:41 PM   #6
DSMAddicted
Member#: 157976
Thanks man.
-Walter
Old 11-16-2010, 07:01 PM   #7
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
just go aftermarket..... tons of selection out there.... just look in vendor's section in wheel section..... more than he'd ever need.
Old 11-17-2010, 12:14 AM   #8
Durbin_SPT
Member#: 237036
2010 WRX
obsidian black pearl
I would get a set of 04 STI BBS or Enkei RPF1. If i was in your friend shoes.
Durbin_SPT is offline   Reply With Quote
Old 11-17-2010, 01:40 AM   #9
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Anyone actually order from there? I would want the 2008 STI replicas in 5x100 that they have
DrDanimalSize is offline   Reply With Quote
Old 11-17-2010, 12:24 PM   #10
DSMAddicted
Member#: 157976
Thanks for your help guys.
-Walter
Old 12-25-2010, 07:46 PM   #11
bwhite525
Member#: 238451
How about hub adapters? There are many adapters out there that bolt onto a 5x100 hub and have the studs built in (also a 1.25" spacer) that make your lug pattern 5x114. Has anyone used these before/know how well they work? Thanks
bwhite525 is offline   Reply With Quote
Old 12-25-2010, 08:16 PM   #12
sc00by4life
Member#: 97135
they...."work". buy wheels that fit your car (they are out there....).
That amount of spacer always makes me VERY nervous. I wouldn't even consider doing adapters.....do it right once with a hub swap.
Question on cobb AP for 07 wrx JustAnotherSubie Newbies & FAQs 1 02-24-2009 11:50 PM
Newbie question on tire-wheel combo wattpuppy Tire & Wheel 3 10-27-2006 06:15 PM
Question on STI 2.5 and WRX Heads wRxbeater11 Subaru Conversions 4 10-04-2004 11:31 PM
Trade Blue Trunk Lid/STi Wing for Regular WRX Trunk Lid/Spoiler BigStew Rocky Mountains Impreza Club Forum -- RMIC 6 11-17-2003 11:45 PM
STi wing for regular WRX wing jdowrx Interior & Exterior Modification 6 10-19-2003 02:52 AM
