Old 07-01-2002, 06:19 PM   #1
dyswtric27
Member#: 404
2000 Audi S4
endless.night
Question Parallel fuel mod from ludespeed
Hey,
I got the parallel fuel rail mod from tom at ludespeed awhile ago and put it in. I'm just wondering how this thing actually works. Its a "T" that goes into the fuel line coming from the fuel filter. You then run another fuel line over to a some bracket that is on the stock fpr. Now this fuel line goes in just before the fpr, so i'm wondering how does it actually get more fuel to cylinder #3 since it seems to be after the injector?
I'm sure it works, i'm just wondering how and trying to figure it out. Since at the same time i have some low fuel pressures ( i think thats due to a busted cartech, but i'll have to see). Thanks.
Jason
dyswtric27 is offline   Reply With Quote
Old 07-20-2002, 08:00 PM   #2
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
bump...
Im kindof interested in how this works too.
Anyone have an idea of how much fuel the stock rails can flow safely?
With 370cc injectors the stock rails seem to work fine.
Rich L is offline   Reply With Quote
Old 07-20-2002, 09:26 PM   #3
STiTuner
Member#: 5778
09 135i
Jet Black
Default Re: Parallel fuel mod from ludespeed
Originally posted by dyswtric27
Hey,
Jason
it lets some of the fuel pass the other cylinders so it doesn't all leak out through the injectors before it gets to #3. basically it evens out the fuel pressure by moving some of the pressure to right in front of the FPR causing the fuel to back up there.
I think that would be an easy way to kinda simplify it.
brad
STiTuner is offline   Reply With Quote
Old 07-21-2002, 10:42 AM   #4
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
do you have the intructions on how to install this unit? i have the parts from tom but i never got around to putting it in because i didn't want to figure anything out.
KillerTHC is offline   Reply With Quote
Old 07-21-2002, 01:42 PM   #5
Delicious Tuning
Member#: 1990
Here is what the Fuel Rail Conversion looks like. The red line is the added line from the Ludespeed "T" Fitting. The FPR is an aftermarket one with LudeSpeed's Fuel Rail Adaptor which has a barbed fitting for the red line to connect to.
Delicious Tuning is offline   Reply With Quote
Old 07-22-2002, 05:15 AM   #6
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
ooooooh... ahhhhhhh... wanna do that for me when i get back bill?
Old 07-22-2002, 09:05 AM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I did a writeup of this a while ago for RS25.com. Basically, after attempting skywalkers Parallel Fuel Line conversion, my dad, uncle and I came up with something like this.
It is practically the same thing, just that the fuel is transported to right before the left side fuel lines instead of after, to the FPR like the schematic shows. I also noticed a drop in fuel pressure.
http://www.rs25.com/_How%20To/Fuel%20Rail%20Mod.cfm
This has been up for a while now, but I don't think many people have really seen it on the site.
Graham is offline   Reply With Quote
Old 07-22-2002, 09:30 AM   #8
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
The big difference would be that for the Ludespeed parallel fuel mod the intake manifold does not need to be removed.
WRC 555 is offline   Reply With Quote
Old 07-23-2002, 08:50 AM   #9
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Yes but just think, when its off, you could always throw on a red coat of paint to make it look like an STi intake manifold. Plus, you are learning more about your car and its kind of fun, but I understand where your coming from.
Graham
Old 07-23-2002, 10:59 AM   #10
Delicious Tuning
Member#: 1990
Hey Graham,
Great writeup, I never even knew it was there. Well I will be forwarding poeple onto there now for the other version of the fuel rail mod.
Cheers,
~Bill
Series to Parallel Fuel Mod or New Fuel Rails? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-10-2003 10:05 AM
Group Mod: Got a weekend free to do the parallel fuel mod? ATTN: opie sanders South East Region Forum 25 02-25-2003 01:11 PM
Parallel fuel mods Surb00 Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-10-2002 05:50 PM
Cheap way Parallel Fuel Mod wanna ride in a sti Normally Aspirated with bolt-on Forced Induction Powertrain 7 11-30-2002 02:42 PM
parallel fuel mod technozip Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-12-2002 02:08 AM
