Old 07-01-2002, 06:37 PM   #1
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
Default Annoying noise when pushing clutch pedal.. where to lube?
Maybe hopefully one of you guys have had this.
when I push the clutch pedal in even when the car is off, as it nears the floor, there's a annoying slight vibrating 'rubbery' type of noise
i got under there to check it out while i pushed the pedal with my hand, and it seems to be coming from where the linkage goes throught the firewall..
I'm thinking i need some grease somewheres, but I'm not exactly sure where...
any ideas?
I'll take it to the dealer if I have to, as i do have a warranty and what not... but if its a quick fix I'd like to get rid of the annoyance asap
thanks!
Cujo31 is offline   Reply With Quote
Old 07-01-2002, 07:06 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
Clutch creak. It's been talked about before, but I haven't seen the subject pop up recently. Supposedly you just grease the clutch slave cylinder piston (you'll have to have someone push the clutch in for you). I forget now.
But I have the sound you're talking about. I can also feel it when depressing the clutch pedal fully. Haven't taken it to Subaru yet. I may before the warranty is up. Is the slave cylinder covered under the powertrain warranty?
Julian is offline   Reply With Quote
Old 07-01-2002, 07:18 PM   #3
Mops
Member#: 16845
1994 Legacy RS
Navy Blue
I had similar thing in my 94 Legacy RS (jap version)
+ the other problem... clutch pedal was sticking down everytime i reved the engine to abouve 4k rpm (it came out about half way - the clutch was engaged so i could normally drive, but it was really annoying). It didnt make any strange sound tho. Anyways, my friend who is a diesel mechanic looked into it and we replaced slave clutch cylinder - and that fixed it.. but not entirely - still sometimes (very rare) clutch comes up only half way through - mostly when i rev it very high on 1st gear. Probably thats due my not-in-good-condition clutch pressure plate.
Anyways... it's just my fev lines on the topic.
Mops is offline   Reply With Quote
"honking" noise when pushing in clutch califesaver Transmission (AT/MT) & Driveline 7 07-14-2009 03:57 AM
Clutch pedal stays to the floor when car's hot RyansJDMgc8 Transmission (AT/MT) & Driveline 41 09-28-2005 04:52 PM
Strange noise when pushing in clutch? Help! crazee195 Transmission (AT/MT) & Driveline 6 07-18-2005 11:14 PM
"Pshhhhhh" noise when pushing in clutch? Ging Service & Maintenance 11 11-02-2004 07:07 PM
Tranny noise at startup when cold, clutch pedal out... Cosworth Transmission (AT/MT) & Driveline 4 01-09-2002 02:20 PM
Message Board Statistics All times are GMT -4. The time now is 08:49 AM.
