Mid Atlantic Impreza Club
Old 11-17-2010, 11:24 AM   #1
bugeyegrocerygettr
Member#: 238584
2002 WRX Wagon
Soon to be Utec'd
Default New Header and up pipe install. What am i in for?
I got my new header and up pipe today so i will proably be putting them on tonight. Im just wondering how much of a pain in the ass this is going to be since i have never done one on a subaru before. Before everyone starts asking i got all new gaskets, bolts, and up pipe studs. Its not an expensive set up by any means but all the welds look great and i got a good deal on it. Thanks for the help.
bugeyegrocerygettr is offline   Reply With Quote
Old 11-17-2010, 11:55 AM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
exhaust manifold is easy (most of the time), uppipe is a PITA even when you know what you're doing just cause it takes a good amount of work.
Old 11-17-2010, 12:25 PM   #3
bugeyegrocerygettr
Member#: 238584
2002 WRX Wagon
Soon to be Utec'd
I just wanted to know what all im in for or if there are any little tricks that might help me. For the most part im very good with a wrench ive done several engine swaps and have been working on cars since i was tall enough to reach the engine bay with my old man, so the PITA part doesnt bother me too much. I just dont have much exxperience with subarus and with any other make of car there are little tricks that help alot when your doing certian things.
Old 11-17-2010, 01:00 PM   #4
sooshimon
Member#: 34880
If I recall correctly, you will have a hard time squeezing the up-pipe between the engine and some other part of the car (forget which one) as you try to get the up-pipe to the turbo.
When I installed the up-pipe in my old wrx, I think I used Vishnu's trick of unbolting one of the engine mounts (the one closest to the up-pipe) and raising the engine with a jack about an inch to get the clearance I needed.
sooshimon is offline   Reply With Quote
Old 11-17-2010, 01:06 PM   #5
Tut4u2
Member#: 40424
05 STi
Which brand did you get? If its ebay then be prepared for possible fitment issues...ask me how I know.
PB Blaster + breaker = friend
Tut4u2 is online now   Reply With Quote
Old 11-17-2010, 02:42 PM   #6
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Since you're doing both at the same time you have much, much less headache.
Make sure you have all the gaskets, measure the studs (some kits studs are too tall and you don't know until it's time to put the downpipe back on, think about where the O2 sensor goes when you orient the bolts on the header/uppipe flange (you'll want the heads of the bolt on the O2 sensor side - otherwise you'll interrupt an O2 sensor socket's path) and most importantly, you'll want to make sure THEY CLEAR THE SUBFRAME - Some don't and either bend the header or make a GOD AWFUL noise
Abnormal is offline   Reply With Quote
Old 11-17-2010, 02:59 PM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by Abnormal View Post
most importantly, you'll want to make sure THEY CLEAR THE SUBFRAME & OIL PAN - Some don't and either bend the header or make a GOD AWFUL noise
and that thing too.
to make your life easier: take off the dp, turbo, and exhaust manifold in that order. you can try to wiggle the up-pipe out or unbolt the passenger's side motor mounts and jack the engine up a bit to give you clearance.
Old 11-17-2010, 03:31 PM   #8
Boogalo
Member#: 77435
04 WRX Wagon Stg2
'94 Miata Project
just bend the crap out of the temperature sensor that sticks out of the stock pipe and you can twist it out without unbolting the turbo or motor mounts.
Boogalo is offline   Reply With Quote
Old 11-17-2010, 05:04 PM   #9
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
and that thing too.
Don't remove the turbo from the inlet/oil return. Asking for trouble IMO. You can wiggle the up pipe out from under the turbo, or through the crossmember and down.
Though! While you're in the area without an up pipe, it's a good idea to check the condition of that line and it's clamps.
And yeah, check oil pan clearance. If you're going unequal length, non issue. If you're going equal length, it's critical to have the skinny 2.5l STI/WRX pan. Not the wide betty 2.0l oil pan
Old 11-17-2010, 06:43 PM   #10
HarryN
Member#: 250258
2011 Legacy WRX STI
Dark Grey Metallic
Heat wrap the header if you have some.
HarryN is offline   Reply With Quote
Old 11-17-2010, 07:06 PM   #11
SEEK
Member#: 143040
2008 WRX
SWP with some gold
Prepare your anus.
SEEK is offline   Reply With Quote
Old 11-17-2010, 07:57 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Spray all bolts with liquid wrench and listen to Abnormal
KillerBMotorsport is offline   Reply With Quote
Old 11-17-2010, 09:53 PM   #13
bugeyegrocerygettr
Member#: 238584
2002 WRX Wagon
Soon to be Utec'd
Yeah from what i can see it wont be too hard. I think i already have the hardest part done, by that i mean gettin the damn heat shields off bolts were so rusted i thought i was going to have to cut them.......also if i take the intercooler off i dont need to take the turbo off right? Im waiting on a friend of mine to get off work so i can take my car to his house that way we have a heated garage to work in......i will post up in the morning when i get home and say how it went. From what i can see i wont have much problem and PB Blaster is going to be my best friend.
Old 11-17-2010, 10:06 PM   #14
Tut4u2
Member#: 40424
05 STi
You don't need to take off the TMIC.
Old 11-17-2010, 10:09 PM   #15
bugeyegrocerygettr
Member#: 238584
2002 WRX Wagon
Soon to be Utec'd
I have a STI top mount on my car so it over hangs on the sides alot more than a stock one........you cant get to the bolts on the inside of the uppipe with the TMIC on.
Old 11-17-2010, 10:19 PM   #16
Tut4u2
Member#: 40424
05 STi
There you have it then I thought you still had the stocker...
Old 11-17-2010, 10:19 PM   #17
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yeah you can, you just need to become a contortionist Taking the TMIC off will make it easier though. There's no point in taking the turbo out. With the manifold off the up pipe slides right down.
Old 11-17-2010, 10:36 PM   #18
bugeyegrocerygettr
Member#: 238584
2002 WRX Wagon
Soon to be Utec'd
Yeah it will take all of 5 mins to get the TMIC off, im all about making life eaiser lol.......im leaving to go put this stuff on in about 5 mins so we will see how it goes.
Old 11-17-2010, 11:42 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
did anyone mention and O2 sensor socket yet?
Abnormal is right on the install, however some equal lengths do clear the 'big betty' oil pan. So tell us what manifold, unless you are already sure of fitment.
FS: (PA) 4 in 1 Header and Up-Pipe - Brand New traskw Engine/Power/Exhaust 9 02-18-2009 02:02 AM
Header and Up Pipe Install yoseph Mid Atlantic Impreza Club -- MAIC 14 02-18-2008 06:32 PM
Installed '05 STi header and up-pipe Porter Forester Forum 2 05-06-2006 04:52 PM
installing an up/dp myself...what am i in for gloves Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-30-2006 07:25 PM
Header and Up-pipe Install Question T-WREXXX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-28-2004 09:56 AM
